#1 |
Member#: 159057
Vehicle:2004 ts wagon aspen white |
![]() so i bought an 07 sti steering wheel a while ago and used this thread http://www.scoobymods.com/forums/ins...steering+wheel to use my 04 cruise control (remote on/off button), recently i had an urge to figure out how to get the 07 cruise control (on/off button on arm) to work, so this is my first diy
![]() *cliff notes: splice green-blue from cruise control button to black on 07 cc through black clockspring wire(?) for trigger mechanism, provide power to red on 07 cc, easy? ![]() 1. this wiring diagram is a good reference to start from http://i42.photobucket.com/albums/e3...eschematic.jpg 2. for comparison ![]() 3. first locate the following a. cc plug under airbag *note the blank spot - that's how we will trigger the cc ![]() b. clockspring connector(?) *to get to this connector, follow the arrow in the picture above* then cut the black wire to splice with green-blue from the 04 cc button in the next step ![]() 4. on the back of the 04 cc button, locate the green-blue, then cut and splice about 12" of wire to connect to the black wire cut in previous step *ignore the other three wires (i terminated them) ![]() 5. cut all the wires as close to the 04 cc as possible, use the wires to connect to the 07 cc according to this picture *i used a spade connector on the black so i don't lose the ability to disconnect it ![]() 07 cc wiring functions for the curious - green = 12v - yellow = set - white = res *red and black are for triggering the cc, one is 12v and one connects to the trigger 6. reconnect everything *so the black from the 07 cc is connected to the black going into the clockspring and spliced to the green-blue from the 04 cc button (you can see this in the bottom left below) ![]() 7. enjoy ![]() ![]() hope this helps, good luck
diy! cruise control mod! 07 sti steering wheel into 04 ts! | antho! | Interior & Exterior Modification | 60 | 06-24-2022 03:40 PM |
FS : 07 sti springs, 04 wrx springs | shsjr89 | SCIC Private Classifieds | 8 | 02-16-2012 06:26 AM |
Does a 06-07 cruise control button work on an 04? | WrexT | Interior & Exterior Modification | 4 | 07-08-2008 06:54 PM |
Motor Swap: 07 STI into a 04 STI | rainmanjam | Subaru Conversions | 11 | 06-07-2007 01:03 AM |
Cruise control from 93 SS into 95L | vica153 | Electrical & Lighting | 9 | 09-07-2006 11:50 AM |
