02-02-2004, 05:42 PM | #1 |
Member#: 46070
Vehicle:2003 wrx blue |
what oil?
I use castrol syntec is a good oil? and which is a good oil for the winter?
02-02-2004, 08:16 PM | #2 |
Member#: 10173
South East
Vehicle:2005 WRX STi Silver |
search
02-03-2004, 02:04 PM | #3 |
Member#: 44380
Redline 15w 50
02-03-2004, 03:01 PM | #4 |
Member#: 50399
Vehicle:2002 WRX Sedan Black |
You guys use dyno oil? Hmm I use synthetic but a friend of mine who used to work at a Subaru dealership told me I should switch back to regular... I dunno. The manual says synthetic doesn't it?
02-03-2004, 03:37 PM | #5 |
Member#: 29705
Vehicle:2002 WRX Blue |
I use Mobil 1 synthetic 5W30. Synthetic is impartant in a turbo because it doesn't coke. Do a search. This has been discussed quite a bit.
02-03-2004, 05:22 PM | #6 |
Member#: 42641
South East
Vehicle:2004 GTO Red as Hell |
Just got back from the dealer, just switched to synthetic.....mobil 1 5W30
It does idle smoother. |
02-03-2004, 05:47 PM | #7 |
Member#: 1048
Vehicle:2000 Nothing, thanks to POS thieves. |
redline 10/30 in the winter
redline 10/40 in the summer |
02-03-2004, 05:52 PM | #8 |
Member#: 24621
Vehicle:2006 Legacy GT 2015 WRX STi |
Mobil 1 syn 5W30 (winter)
Mobil 1 syn 10W30 (summer) |
02-04-2004, 12:03 AM | #9 | |
Member#: 21009
TXIC
Vehicle:2008 Sti Blue w/ Gold BBS wheels |
My theory...
In tighter (new generation) clearence motors the thinner the oil is the more you flow thus increasing the cooling effect. The 03 cobra has an issue w/ cooling to one of the heads and the oil passaages being too narrow. Most new motors are calling for 5w20. After reading through the article I switched to Mobil1 0W40. I've been running really hard on my 14-15psi cobra. I have 5w30-40 in the WRX for now. In my RX7 I have to run at least 20W50 because I have a high pressure oil pump. If I run anything thinner than that the oil control seal in the TO4B turbo start leaking and the car smokes really bad. anyway, Mobil1 is the best oil you can buy at a store. but for a WRX running in the winter I would at least use 5W and maybe the 0W depending on how cold and where you are at. Stay away from Penzoil. That oil is pretty much crap. I've heard bad things about castrol, although I've run it in the WRX for a while. I know the RX7 guys say it's the surest way to ruin a rotary. Anyway, if you can afford it, get the royal puple, redline, amsoil. Those oil's are much better made. If you can't get those then get mobil1, if you want to change oil often and save a buck, then you can use 5w havoline or valvoline for a cheap cheap alternative. |
02-04-2004, 04:38 PM | #10 | |
Member#: 53206
Vehicle:2018 Type RA WRB |
Re: My theory...
02-04-2004, 06:33 PM | #11 | |
Member#: 21009
TXIC
Re: Re: My theory...
not sure about synthetic, but regular has lots of wax in it. causes carbon buildup much quicker. |
02-04-2004, 07:21 PM | #12 |
Member#: 27233
Vehicle:2003 wrx Sedona red |
Mobil 1 5w30
02-04-2004, 07:36 PM | #13 |
Member#: 51799
Vehicle:03 wrx wagon silver |
Mobil 1 or Royal Purpal 5w30
02-04-2004, 10:00 PM | #14 |
Member#: 37042
South East
Vehicle:2014 Forester 2.0 XT Marine Blue Pearl |
Mobile 1 10W-30 year-round for me. But I live in South Florida....
-Dtech |
02-04-2004, 10:14 PM | #15 |
Member#: 42082
have you ported your rx7 FC3S??
02-05-2004, 01:33 AM | #16 | |
Member#: 21009
TXIC
not yet
02-06-2004, 01:00 PM | #17 |
Member#: 29052
Vehicle:08 Evo X 03 WRX sold not forgotten |
I still use Mobile 1 5-30 in the winter in WI. But I do warm the car up for about 10 minutes before I leave in the morning-
02-06-2004, 01:14 PM | #18 |
Member#: 25519
Vehicle:2002 WRX Steel Grey |
i use Mobil 1, 15w50, my car is summer driven only.
02-06-2004, 02:34 PM | #19 |
Member#: 43905
South East
Vehicle:02 WRX WRB |
Royal Purple....
02-06-2004, 02:40 PM | #20 | |
Member#: 10276
Vehicle:2001 Impreza RS 2002 WRX, 2012 535i |
02-06-2004, 03:35 PM | #21 |
Member#: 37748
SCIC
Vehicle:O=O Wgn Silver |
i use mobile 1 in mine (stock for now), and i'll probably change it out around 5k (i drive it hard but not all the time). but i've also changed out the diff and trans to mobile 1 synthetic 85w90.
in my ex-import truck i changed to mobile 1 in the trans and diff and noticed when i touched the metal part of the stick-shift it was cool to the touch. before it transmitted quite a bit of heat, actually hot when driven for any length of time. i know that a lot of people suggest neo synthetics for their trans and diff to shift into 1st gear at a higher speed. but, i've been able to shift into 1st at approx. 26mph (just letting it slide in/street driving conditions) without any problems. (almost) any feedback is greatly appreciated. |
02-06-2004, 03:46 PM | #22 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
For those that use Mobil 1 synthetic, how often to you go between oil changes? 3k or do you run it for 5k?
02-07-2004, 12:22 AM | #23 |
Member#: 28896
Vehicle:1994 integra gsr milano red |
I would have to say that 15w50 is to thick for these engines and most new engines on the market. I would at most run 10w30 in these cars. It tends to be older gernerations that are still under the impression that thicker is better. Where i work i still have people coming in and wanting 15w40 in their new altimas.
02-07-2004, 12:35 AM | #24 |
Member#: 17877
SCIC
Vehicle:2007 Exige S Storm Titanium |
I run
5W30 Redline, and I live in Hawaii.
San |
02-07-2004, 01:30 AM | #25 |
Member#: 31938
Vehicle:2003 WRX Blue |
mobil 1 synthetic every 3k miles. usually 5w30 year round (MI)
-S |
Similar Threads | ||||
High HP high reving subarus, what oil pump & thoughts on aftermaket oil pan & baffle? | D Money | Built Motor Discussion | 66 | 05-17-2009 12:13 PM |
Searched, but couldn't find, what oil should I add to the factory oil? | AndrewSS | Service & Maintenance | 6 | 08-10-2005 12:11 PM |
First oil change! = What oil do you use? | Italiano | New England Impreza Club Forum -- NESIC | 7 | 05-07-2003 07:13 PM |
('93-'01) Need advice-what oil filter fits 2002 OBS? | subymamma | Impreza Forum | 4 | 05-19-2001 10:37 PM |
