03-06-2019, 05:47 PM | #2951 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
30 miles is pretty reasonable. My commute is 18 miles each way and there are chargers at work. Even if I didn't charge at work it would still significantly reduce gas usage.
03-06-2019, 11:45 PM | #2952 | |
Member#: 92634
RMIC
Vehicle suggestions for shikataganai (CN: Bought a ****in' Pacifica)
https://electrek.co/2019/03/06/tesla...ty-efficiency/
V3 Supercharger unveiled. V2: 120 kW peak. Power sharing between stalls so lower peaks if someone charging next to you. Air cooled cables. V3: 250 kW. Water cooled. No power sharing. 250 only possible on long range Model 3 from what I can gather, pending a software update. V2 installations will get a bump to 145 kW but won’t get redone as V3 per this announcement, so for new sites instead. What does 250 kW look like? Quote:
03-07-2019, 12:29 AM | #2953 |
Ethon
Member#: 221885
NWIC
Vehicle:2050 Ivory Tower Ivory...duh |
1000 miles of range per hour of charging in a model 3?
:warning I am about to pull some back of the envelope numbers straight out of my but: 75kWh model 3 = 325 miles so 325miles/75kWh = 4.333 miles/kWh So lets say the upcoming eF150 is only half as efficient as the current model 3, so 2.15 miles/kWh Lets look at a dollar/kWh chart. Screw their line, it is nowhere near a polynomial fit to the points on the graph, something that would be a better fit but still be asymptotic and run into some basic physical and material challenges will have $100/kWh packs by 2023-2024? The model three battery pack weighs around 1054 lbs at 75 kWh, about 14lbs/kWh. Given the weight/power density curve a 2024 pack should weigh about 2/3 as much per kWh so lets say 14*2/3 = 9.3 lbs/kWh in 2024. Lets give the 2024 eF150 Long Range a 250kWh pack, it would weigh about 2340 lbs, say a truck weight of 6500-7000 lbs with the new battery and motors and loosing the previous drive train, liquids and cooling systems. Getting 600hp and 1000tq would be easy now, real easy then, so 0-60 is sub six seconds, possibly quite a bit less and given the extra weight of the vehicle the relative weight of towed things will be less so much better towing performance and it will fairly conservatively have a non towing range of around (2.15miles/kWh)*250kWh= 540 miles that will by then be able to charge on the new current Tesla standard in 1 hour and on the upcoming 350kW/h Charge America system in 40 min. Given that the first eF150 comes out in 2020, I'll bet you will be able to buy a self driving eF150 XLT 302A SCrew with the range and power numbers I mentioned above that will charge on a 350kW/h charger in 40 min for $70K- $60K after incentives and dealer discount in say 2025? Ladies and gentlemen, the 2025 familE Truckster available on approved credit with a 3.5% APR 120 month mortgage for $593/month.* *I suspect it will actually weigh 500 lbs less, cost $10,000 less, have a 650 mile unloaded range and a sub 5.5 sec 0-60 time. Last edited by etothen; 03-07-2019 at 11:11 AM. |
03-07-2019, 09:47 AM | #2954 |
Member#: 92634
RMIC
I approve of back of napkin calculations. I know you didn't intend it but you mixed usage of kWh (capacity) and kW (energy) a few times. I totally agree that with the trends in price there'll be an inflection point within the next decade after which it'll simply make more economic sense to go electric for all of the things.
03-07-2019, 11:08 AM | #2955 | |
Ethon
Member#: 221885
NWIC
03-07-2019, 11:50 AM | #2956 |
Member#: 16840
Vehicle:17 4Runner |
I do think in 5 years the range and capabilities of the machines will be pretty amazing.
I'm training myself for an electric car now by letting my phone go below 50% charge before plugging it in a couple days a week. |
03-07-2019, 11:58 AM | #2957 |
Member#: 92634
RMIC
Sign that I live in a yuppie neighborhood:
On way to drop off kid at bus stop there is a 4 way stop. Inclusive of mine 3 of the 4 ways had Model 3s at them. Then at the bus stop a Model X drove by. And as I left the bus stop I passed yet another 3. |
03-07-2019, 02:37 PM | #2958 | |
Member#: 30342
5 sec 0-60, 120mph top speed, and 50KWh quick change battery pack so I can make an electric rally car. |
03-07-2019, 05:37 PM | #2959 | |
Member#: 16840
That would be a cool project to have sit in your garage for 10 years. |
03-07-2019, 05:40 PM | #2960 |
Member#: 30342
03-07-2019, 06:37 PM | #2961 | |
Member#: 92634
RMIC
https://arstechnica.com/cars/2019/03...bly-dangerous/
03-07-2019, 06:49 PM | #2962 |
Member#: 92634
RMIC
Related: https://jalopnik.com/heres-another-d...-of-1833123703
I use it responsibly. It’s far too easy to abuse it, though, as this extreme example shows. The cat’s already out of the bag but it would have been better ultimately to mandate Super Cruise type driver awareness tech before these level 2 systems were unleashed. |
03-07-2019, 08:05 PM | #2963 |
Member#: 90804
SCIC
Thanks for saving the rotten dinosaurs for my gas tank
03-08-2019, 12:42 AM | #2964 |
Member#: 16840
03-08-2019, 02:12 PM | #2965 | ||
Member#: 92634
RMIC
I test drove two vehicles at CarMax today because why not? (And because it scratches my “what if?” itch.) Both were Lexus LXs, so like my old Land Cruiser but plus a gen and one and two refreshes, respectively. 2014 Lexus LX 570 This one felt beat. Nanny wasn’t kind to it up at the Aspen house, perhaps? Scratches and scuffs on interior, needed an alignment, smelled of either old smoke or old thick perfume. Drove as I remember my old 100 Series, for better or worse. Slow steering ratio, long hood, very smooth and quiet. Old style dashboard wasn’t endearing—more vertical and visually imposing than modern designs. Verdict: Meh, particularly for this example. 2016 Lexus LX 570 Only glimpsed its Alien maw once so wasn’t scarred. New interior is worlds nicer than the old in style and layout. Lower cowl height with stuck on screen is a good overall compromise. Mousy thing was annoying and the system’s response laggy. Millions of buttons and knobs on center console. Nice open pore wood textures but the wood on the steering wheel didn’t wear well at all. 8 speed mated to 5.7L is a lovely, smooth drivetrain. Verified cruise is stop and go (Full Speed Dynamic Radar Cruise Control in ToyoLexus lingo). I didn’t play with the stereo but I’m sure the Mark Levinson is superb. Verdict: the 2016+ LX is what I wanted my Land Cruiser to be, for better or worse. But is that what I want? I do want something bigger than my 3 ultimately and it would make for a great ski day vehicle as did my Land Cruiser. Saner 3 row AWD alternatives abound but are just so… normal. I still will likely plow on with my Tesla upgrade path plans but was nice to knock these off my list—recall that I do enjoy doing this, after all. |
03-08-2019, 02:20 PM | #2966 |
Member#: 16840
What kind of price did they have on the ‘16?
03-08-2019, 03:21 PM | #2967 |
Member#: 92634
RMIC
Listed at $63k. https://www.carmax.com/car/16650912 KBB says dealer value for those options and miles should be $62-69k. |
03-08-2019, 03:33 PM | #2968 | |
Member#: 16840
Wish it didn’t include a picture of the front end. |
03-08-2019, 04:05 PM | #2969 | |
Member#: 92634
RMIC
My wife is the voice of reason and reminded me just now that an LX would have the same drawbacks as the Land Cruiser had: - if kid car seats 3 wide in the second row (barring funny foldable designs like the IMMI GO) then 3rd row access is very difficult, as in awkwardly climbing into the high rear of the vehicle - 3rd row on Land Cruiser and its variants is pretty useless, particularly with regard to legroom. This is exacerbated when one puts a car seat back there So maybe Tesla will surprise me and throw in a useful magic 3rd row on the Model Y, like with built in jump seats a la the discontinued Model S option . Or maybe we will try our luck next season as a family on ski trips with Nokians (and auto socks) on the FWD PacHy. Or maybe I’ll go conventional once more. |
03-08-2019, 04:06 PM | #2970 |
Member#: 303030
BAIC
Vehicle:2009 STI DGM |
Just nut up and get a damn x (probably repost from page 1). The 3 and the Y are not going to be your magic unicorn.
03-08-2019, 05:53 PM | #2971 | |
Member#: 92634
RMIC
This comment is called for, yes. But I don’t like the X. I am a fickle beast and enjoy unicorn hunting, perhaps more so than eating the damn unicorn-like animal in and of itself. |
03-08-2019, 06:52 PM | #2972 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
If Tesla had just put normal doors on the X and priced it 10% more than the Model S, it would be a runaway success.
03-08-2019, 07:20 PM | #2973 |
Member#: 90804
SCIC
Actually this is true. Those rear doors are stupid and unnecessary on a family vehicle.
03-08-2019, 09:21 PM | #2974 |
Member#: 7887
Vehicle:2023 Tangerine 2023 3 Cylinder |
Just to pile on, the X is ugly AF and has Rube Goldberg doors. It looks like an egg and every one I see has the rear spoiler in the up position driving around at city speeds.
03-08-2019, 09:27 PM | #2975 |
Member#: 82470
NWIC
They stopped making them active spoilers early on, that's why they all look like they're stuck in the up position.
