Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 11-24-2016, 08:30 PM   #676
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Does anyone have part number for the gasket of the metal coolant expansion tank that bolts to the intake manifold?
2slofouru is offline   Reply With Quote
Old 12-16-2016, 07:13 PM   #677
gc8fxt
Member#: 393747
***12479;***12531;***12463;***12288;***12450;***12475;***12531;***12502;***12522;***12289;***12454;***12457;***12540;***12479; 21132AA040
Water tank assembly.
Originally Posted by Gagne26 View Post
Do you have the three parts number so I can see if they have them in stock just in case?
Sorry, very late... but here they are
Translation:
Version D/E models with EJ20G, 20K or 22G engines have 3 types of gasket available.
At the time of changing the gaskets, check the type of the gasket and then order.
Type A
RH 13270AA062 (gasket), 13264AA131 (cover)
LH 13272AA063 (gasket), 13278AA111 (cover)
Type B
RH 13270AA082 (gasket), 13264AA160 (cover)
LH 13272AA082 (gasket), 13278AA140 (cover)
Type C
RH 13270AA111 (gasket), 13264AA190 (cover)
LH 13272AA110 (gasket), 13278AA170 (cover)
Sadly, I don't remember which one was mine; not that that would of helped you last year.
edit** Looking at my pictures from my rebuild, I see that mine were Type A.
gc8fxt is offline   Reply With Quote
Old 12-17-2016, 02:11 PM   #678
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
I'm pretty sure they don't sell that separately. I couldn't find any reference to it online and couldn't find it on any diagram. You just have to buy the whole tank
elislider is offline   Reply With Quote
Old 12-17-2016, 02:40 PM   #679
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
/\ You're correct, I was excited when he posted the part number because I was at work and didn't realize it was the tank part number. It's a shame, because the metal tanks are really nice. I may have to just fork out the money for a new plastic tank instead of gluing the two together. I don't want to risk any leaking with the new sleeved block.
Old 01-18-2017, 01:43 AM   #680
elislider
Member#: 133923
03 Legacy GT wagon
the nice thing is there's a million of them out there so its not hard to find a used one. I think i have a few
Old 01-18-2017, 07:23 AM   #681
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I'm going to buy a new one piece plastic, shouldn't get brittle for a long time and I don't want to risk a leak with the new engine. It will be tough enough keeping the coolant from leaking around the edge of hoses. I may use a different brand of coolant, since the Toyota pink seems to find every microscopic pore to leak from. Honda coolant may be the choice this time.
Old 02-20-2017, 09:28 PM   #682
mrgf8sti
Member#: 410300
Anyone have the part number for a ej20k starter, or know what model usdm starter, if any would work?
mrgf8sti is offline   Reply With Quote
Old 03-13-2017, 05:40 PM   #683
elislider
Member#: 133923
03 Legacy GT wagon
any manual trans (5speed) starter will work
Old 03-14-2017, 12:31 PM   #684
mrgf8sti
Member#: 410300
Thank you!!
Also looking for an o2 sensor. I've read the Bosch 15726 would work, but I rather have a non universal sensor.
Old 05-22-2017, 04:02 PM   #685
JORGERS
Member#: 468107
2001 JF1 Rs GM-coupe
Originally Posted by Jaxx View Post
car gc8d48d
build 5/97
engine EJ20KDW6HE
tranny TY752VBCAA
plug wires:
-#1 - 22451AA793 not in system
-#2,4 - 22452AA682 not in system
-#3 - 22451AA822 not in system
coil pack: 22433AA370 (1) 73.19
maf: 22680AA271 (1) 210.91
power steering lines
-RHD 34610FA091 not in system
-LHD 34610FA100 not in system
ACCEL CABLE (EJ20K LHD): 37114FA070 not in system
boost solenoid: 16102AA091 not in system
map sensor: 22012AA160 (1) 219.39
iac: 22650aa132 not in system
injectors: 16611AA231 not in system
in fender overflow
-tank 45152AA020 20.24
-filler 45132AA010 not in system
-cap 45153AA001 3.39
pvc to block hose 807519082
head gasket: 11044AA355 (2) 27.78
sti reinforced head gasket: 11044AA463 not in system
water pump gasget: 21114AA051 (1)1.93
rear main seal: 806786040 (1) 8.74
cam seals: 806732150 (4) 5.87
valve cover gasget:
-right? 13270AA062 (1) 9.64
-left? 13272AA063 (1) 9.64
-?? 13293AA051 (4) 5.82 (says its for an 05-6 h6?)
-wash rocker cvr (13271AA051 (12 or 16) 2.38
manifold to intake: 14035AA281 (2) 3.32
manifold to throttle body: 16175AA151 (1) 1.70
manifold to IAC: 22659AA060 (1) 3.88
manifold to injector: 16608AA020 (4) 5.22
crank
-(#3 thrust bearing) 12200AA150 364.71
-(#5 thrust bearing) 12200AA2240 272.60
main bearings
-(#3 thrust bearing) 12209AA000 84.80
-(#5 thrust bearing) 12209AA360 133.41
rod bearings: 12108AA290 182.80
rods 12100AA240 52.70
rings: 12033AA730 not in system
head bolts: 11095AA041 7.26
rebuild gasket kit: 10105AA380 not in system
heads
-LH 11063AA742 not in system
-RH 11039AB132 not in system
cams (non STI)
-13032AA240 not in system
-13035AA240 not in system
-13038AA240 not in system
-13053AA240 not in system
cams (STI)
-13032AA390 not in system
-13035AA390 not in system
-13038AA390 not in system
-13053AA390 not in system
Non-RA valves:
-EXH: 13202AA350 13.24
-INT: 13201AA340 9.21
vavle spring: 13217AA160 not in system
rear deck cover
-Up to July 1997: 65510FA001ML not in system
-April 1997 on: 65510FA001OE not in system
Hi, a have a Rs swap to wrx ej20g jdm engine, i need complete gasket kit for all engine.
If you have information on how or where to get it please.
JORGERS is offline   Reply With Quote
Old 05-28-2017, 11:47 PM   #686
91 RS RA
Member#: 457410
1991 Legacy RS RA
Here is a good source of parts and part numbers for a JDM engine
https://partsouq.com/en/catalog/genu...c=Subaru+Japan
91 RS RA is offline   Reply With Quote
Old 08-09-2017, 10:05 AM   #687
1ofakind03
Member#: 472184
Hey guys, been strongly considering buying a 93 jdm wrx. Wondering if you can all help me.
little run down on the car;
was a running and driving wrx about a year ago. The previous owner pulled the motor due to low compression and at the time wanted to clean up the wiring in the engine bay. He got the motor rebuilt, and sold the motor. Now has the wiring all out of the engine bay. He has a 94 wrx wiring harness that he was planning on putting back in as it needed very minor repair opposed to the one he originally took out. But he did have the car running a ej20g with the crappy harness he had in originally.
So now i am contempleting buying this mint wrx.. Thing is im not to sure what ej20g motor will work in the car. Will any ej20g work? Does it need to be a specifc year, model ect? Is there anything else i should consider looking into before i pick up the car? ecu?
Its a very good deal for the car i feel as it has alot of potential to be awesome again, he only wants 900 for the car, has everything else besides the motor, that includes the transmission (unsure of which one though).
Thank you all!
1ofakind03 is offline   Reply With Quote
Old 08-09-2017, 01:39 PM   #688
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Start your own thread. This one is for part numbers, not "Should I buy this car?" questions.
car_freak85 is offline   Reply With Quote
Old 05-09-2018, 01:13 PM   #689
mrgf8sti
Member#: 410300
Any part number for a jdm r160 rear diff cover gasket?
also can any usdm gc axle fit on the jdm r160 drive train?
Old 06-02-2018, 12:57 PM   #690
smoothbagel
Member#: 486698
This thread is amazing. Saved my car multiple times
smoothbagel is offline   Reply With Quote
Old 06-04-2018, 01:53 PM   #691
car_freak85
Member#: 13530
EJ205
Looking for the correct part number for the front o2 sensor for a 1993 WRX Type-RA. I thought I had found the correct part, but the three-pin connector doesn't match the 4-pin connector on my engine harness.
HELP!
Old 11-09-2018, 04:44 PM   #692
gc8fxt
Member#: 393747
If you don't have the JDM Subaru parts software, I recommend partsouq.com. You can enter your Japanese VIN (gc8-05###1) and it will pull up the parts for your vehicle.
I've been using this site for my current RHD Honda Element and for my RHD BP5 2.0GTspecB that's coming soon. Works for USDM and EDM cars as well.
Old 12-24-2018, 11:05 PM   #693
marbintorres
Member#: 495280
hi! do you have part number for the water pump?
(i am just ordering in amazon)
here in my place there is no parts store that caters for old model subarus.
car is: JDM sf5 forester.
VIN:SF5-018862
APPLIED MODEL: SF5A53P
TRIM CODE: 820
ENGINE TYPE: EJ20GDX1NY
marbintorres is offline   Reply With Quote
Old 01-02-2019, 12:49 AM   #694
Foo_Blyat
Member#: 93750
VIN:SF5-018862
TRIM CODE: 820
https://jp-carparts.com/subaru/partl...004&fig_id=035
it shows three different part numbers for 1996;X2111AA040, 1997;X2111AA041, 1998;X2111AA042 but they're all the same just superseded each other .
When that part number is plugged into subaru, the newest USDM part number replacement for it is 21111AA065.
Price is $84 before shipping http://www.heubergersubaruparts.com/...21111aa065.htm . Amazon doesnt have the pump from what i can see
Foo_Blyat is offline   Reply With Quote
Old 01-16-2019, 01:53 AM   #695
Darfin
Member#: 496536
Hey, all.
I bought this GC8 half-cut with an EJ20G, and i'm wondering if there's an internet resource to buy the gaskets and other rebuild stuff for the JDM engine.
All my familiar internet resources don't seem to have kits for the EJ20g that i can find.
Also, i heard that 02-05 WRX head gaskets will work on the EJ20G, is that true? And if so, what other gaskets can translate over to the EJ20G from US motors?
Any help is appreciated.
Darfin is offline   Reply With Quote
Old 06-24-2019, 09:00 PM   #696
frosty_gc8
Member#: 503570
1995 Subaru STI RA
Anyone have numbers for Intake and Exhaust valves for a 1995 V1 STI RA? Bent valves in Cyl 3 and in abit of a bind. Seem to be having a hard time finding any accurate information on this Gen RA specifically.
frosty_gc8 is offline   Reply With Quote
Old 06-24-2019, 09:19 PM   #697
frosty_gc8
Member#: 503570
1995 Subaru STI RA
Originally Posted by Darfin View Post
Hey, all.
Most things to do with your heads will cross reference the same as a EJ25D gasket wise
Old 09-17-2019, 08:53 PM   #698
tleg20k
Member#: 506469
I am working on an ej20k rebuild, but am having trouble finding piston rings. Will the usdm wrx or sti rings work?
tleg20k is offline   Reply With Quote
Old 09-23-2019, 04:12 PM   #699
elislider
Member#: 133923
03 Legacy GT wagon
part number is 12033AA730.
doesn't appear to be listed compatible with any USDM models
this assumes you are using the EJ20K pistons
Old 11-15-2019, 02:48 PM   #700
mrgf8sti
Member#: 410300
Default Front axle
Hey guys i have a rhd ver4 98 sti, with no dccd. Looking for help with the front axles.
Are they the same as a usdm 98 impreza?
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
