07-10-2020, 03:04 PM | #1 |
Member#: 506430
Vehicle:2009 Impreza sky blue |
Cylinder misfire 4
Recently got a reseal changed my water pump and timing belt clutch, plugs cables and coil pack. Now I’m getting a misfire in cylinder four and I’m stumped. Mechanic replaced coil pack with auto técnica one so I replaced with NGK to keep the plugs and wires in the same brand fixed the issue for 90miles then the code came back up. 2009 Subaru Impreza Hatchback
07-10-2020, 05:48 PM | #2 |
Member#: 21145
Vehicle:2002 Enemy of Aku |
Maybe he should have stayed w/OEM instead.
I presume cylinder #4 is the coil that was replaced? If so, why? Check your coil connections. |
07-10-2020, 08:17 PM | #3 |
Member#: 506430
On mine the wires all lead to a pack that connect all four together. They were all replaced because it was time for service.
