Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 08-21-2019, 11:30 AM   #1
bizzlezx10r
Member#: 439586
2015 WRX
ISM
Default Cleaning exhaust tips? (In/Out)
I bought my WRX a month ago with the SPT exhaust already on it. Sounds great but they look absolutely terrible. Also when I get on it I’m getting a lot of sulfur smell.
I’ve been watching videos on how to clean it but I feel like none of exhausts in the videos are as bad as mine. Has anybody attempted to clean the inside of the exhaust with a wire wheel attached to a drill?
https://imgur.com/GgCBwTx
https://imgur.com/JuP6R07
bizzlezx10r is offline   Reply With Quote
Old 08-21-2019, 03:08 PM   #2
joesstripclub
Member#: 461015
2017 WRX
I would start with some metal polish like mothers. You can also get their powerball or whatever attachments they have now, which is a foam polishing pad that attaches to a drill and is made for polishing wheels, but would work great on the inside of exhaust pipes. A wire wheel will ruin your tips for sure. You may have to step up to steel wool if the polish doesnt cut it.
joesstripclub is offline   Reply With Quote
Old 02-11-2020, 07:09 AM   #3
Angela626
Member#: 511580
That's true
Angela626 is offline   Reply With Quote
Old 05-23-2020, 01:25 PM   #4
Dubclutcher
Member#: 515015
Will be installing my invidia q300 tmr. Thanks for the helpful tips to keep the quad babies clean!
Dubclutcher is offline   Reply With Quote
Old 08-21-2019, 03:15 PM   #5
gfxguy
Member#: 316583
2014 STI Hatch
ISM
My SPT exhaust was also in pretty bad shape when I bought it. I was able to restore it with some Meguiars Ultimate Compound and a Mother’s PowerCone.
gfxguy is offline   Reply With Quote
Old 07-12-2021, 10:02 AM   #6
aprtunedb5a4
Member#: 315332
2020 WRX STi Limited
I second this as its exactly what i do as well to clean mine, also I like to then wipe it down with a microfiber cloth on the outside of it afterwards to give it that extra love.
aprtunedb5a4 is offline   Reply With Quote
Old 08-21-2019, 03:32 PM   #7
bigbenp
Member#: 216142
'04 & 11 STi's
'10 & 14 Foresters
On my first STi, I used 0000 steel wool to clean up the soot and then shined it up with Nevr-Dull. Took some elbow grease, but it looked nice afterward.
bigbenp is offline   Reply With Quote
Old 08-22-2019, 09:10 AM   #8
gaugeof12
Member#: 132859
2015 WRX
CWP
Pretty similar. I used a green kitchen scrub pad along with the steel wool and then w/e metal polish i had on the shelf in the garage.
gaugeof12 is offline   Reply With Quote
Old 09-15-2019, 06:08 PM   #9
seattleslow
Member#: 189722
2003 WRX Wagon
Rally Blue
I wish I thought of that. I kept scrubbing, and scrubbing, and scrubbing with chrome cleaning products. That must shave a lot of time off.
seattleslow is offline   Reply With Quote
Old 09-16-2019, 09:50 AM   #10
bizzlezx10r
Member#: 439586
2015 WRX
ISM
I'm bout to hit it with that 4 Grit if it keeps being so stubborn as it is.
Old 08-22-2019, 03:25 AM   #11
brylemr
Member#: 414507
I use Flitz Metal Polish and a Daytona Speedbrush to clean the inside.
brylemr is offline   Reply With Quote
Old 08-22-2019, 09:13 AM   #12
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Mother's metal polish.
Be careful of green scotch pads, they can put scratches into polished tips.
jasonwrx86 is offline   Reply With Quote
Old 08-22-2019, 11:00 AM   #13
bizzlezx10r
Member#: 439586
2015 WRX
ISM
Thanks everybody!
I don't think the exhaust is polished. Does anybody know what material it is from the pictures? It almost looks like the same material that exhausts from early 2000's street bikes were made out of. Like that dull, heavy metal.
Old 08-22-2019, 12:45 PM   #14
TifosiWA
Member#: 489993
2019 WRX STI LTD
Pure Red
Originally Posted by bizzlezx10r View Post
Thanks everybody!
IIRC, the SPT exhaust systems are stainless steel with brushed finish, that's why you will never be able to get it to shine like you can with polished SS or chrome exhaust tips.
You can clean it with any of the above mentioned products, personally, I use Blue Magic (https://bluemagicusa.com/) that are readily available at most auto parts stores.
TifosiWA is offline   Reply With Quote
Old 09-09-2019, 02:43 PM   #15
MarcWinkman
Member#: 479018
2018 STi Limited
Crystal White Pearl
I use a little bit of Hoppes No. 9 (bore solvent that can be had from any gun shop or the hunting section of your local sporting goods store) with a green Scotchbrite pad. Get some of the solvent on a shop rag and let it soak onto the surfaces you want to clean for a couple of minutes then scrub clean with the Scotchbrite pad. Simple, inexpensive solution, and a large bottle of bore solvent will do the task many times over. To bring back some luster, I use Adams Metal Polish. Makes my exhaust tips look new again. In full disclosure, I do have polished stainless tips on my Cobb exhaust, but either way, this methodology will also work with the brushed tips on the SPT exhaust.
MarcWinkman is offline   Reply With Quote
Old 09-17-2019, 11:14 PM   #16
TriAxis 6
Member#: 377862
Superclean @ 3:1 let dwell for a few mins. Agitate with a stiff bristle brush and rinse. That should get the schmutz off. Then I’d go after it with a higher quality metal polish like angelwax alchemy
TriAxis 6 is offline   Reply With Quote
Old 11-06-2019, 09:45 AM   #17
mng17
Member#: 492482
2017 WRX
some fine steel wool, simple green, and a lot of patiences
mng17 is offline   Reply With Quote
Old 11-10-2019, 01:47 PM   #18
GC8RA
Member#: 202923
Recently used this method also
GC8RA is offline   Reply With Quote
Old 11-12-2019, 05:36 PM   #19
gt58
Member#: 483720
2004 sti
jbp
simple green then #0000 Steel Wool then used some leftover Brasso I had laying around. applied it by hand and let it sit for a while. came back and cleaned it off. next day went out and bought mothers mag and aluminum polish and a mothers powerball drill attachment. that really really made it shine. midpipe portion closest to the downpipe was still discolored from the heat. axle back portion looked practically brand new
Edit: this was a blitz nur spec R catback btw.
gt58 is offline   Reply With Quote
Old 05-13-2020, 08:10 AM   #20
cory045
Member#: 514704
+1 on the #0000 steel wool
cory045 is offline   Reply With Quote
Old 11-20-2019, 03:20 AM   #21
futureboy40
Member#: 508542
eagle one never dull
futureboy40 is offline   Reply With Quote
Old 11-27-2019, 10:29 AM   #22
WhiteRX09
Member#: 321304
2013 WRX
Bar Keepers Friend works wonders.
WhiteRX09 is offline   Reply With Quote
Old 01-08-2020, 08:28 PM   #23
Scorpius
Member#: 370806
2019 WRX/STI DGM
23 Nissan Frontier Pro 4x
Imatrythisoneout.
Scorpius is offline   Reply With Quote
Old 01-30-2020, 10:38 PM   #24
jakesubie
Member#: 511228
2017 Subaru WRX
Red
I've always been able to just wipe my exhaust tips clean with a microfiber cloth and optimum no rinse. I guess it helps that I do it every week or two, every time I wash my car.
jakesubie is offline   Reply With Quote
Old 11-27-2019, 08:43 PM   #25
mxbowler95
Member#: 482136
2018 STI
Another one for Eagle One NevrDull for your case, it will clean them in no time.
Use the Mothers Mag & Aluminum Polish if you get them shined. I personally use both on my cars, Eagle One first then Mothers.
mxbowler95 is offline   Reply With Quote
