01-05-2010, 01:22 AM | #1 |
Member#: 10449
NWIC
Vehicle:03 Legacy BH Silver |
Loud clicking/clunking noise while turning.. Any ideas?
Guys:
So I have this little issue with my 2003 Legacy SE wagon. Upon turning I hear a loud clicking or clunking noise coming from the right front wheel. It kind of feels like it's slipping or stuttering. I only of course notice it at slow speeds (upon parking or making a U-turn). Do any of you legacy gurus know what's going on? Please help. The shop said it might be a differential tooth has broke off or maybe an axle issue. Taking it in on Thursday to diagnose.. Any suggestions for an upgrade option as well? Thanks for the help PJ |
01-05-2010, 01:26 AM | #2 |
Member#: 96585
SWIC
Vehicle:05 STI PSM |
My guess would be swaybars/endlinks being loose.
01-05-2010, 06:14 AM | #3 |
Member#: 153374
South East
Vehicle:2001 Outback Wagon White |
Is it kind of a continuos clicking noise? Or is it just a like a single big clunk that happens.
I would say front right CV joint. |
01-05-2010, 08:08 PM | #4 |
Member#: 164
01-05-2010, 10:22 AM | #5 |
Member#: 163816
Tri-State
Vehicle:1999 Legacy Outback Black |
sounds like a CV joint
01-05-2010, 02:58 PM | #6 |
Member#: 153374
South East
Go to the car and look at the front right axle's boots and see if theres grease everywhere or if there is a rip/tear/puncture/hole in one of the two boots (most likely the boot at the hub though).
01-06-2010, 01:52 AM | #7 |
Member#: 227802
Tri-State
Vehicle:1998 legacy outback blue and tan |
cv joint
01-09-2010, 02:46 PM | #8 |
Member#: 10449
NWIC
went to the shop to have it diagnosed.. the think its a viscous coupler issue..
01-15-2010, 08:48 PM | #9 |
Member#: 10449
NWIC
Bump..
Has anyone had or heard of a Viscous Coupling issue..? |
01-15-2010, 08:52 PM | #10 |
Member#: 223892
Tri-State
CV joint my 2002 wrx did that and when i got it fixed it stopped
01-15-2010, 09:00 PM | #11 |
Member#: 10449
NWIC
did it bind a lot before then?
01-15-2010, 09:03 PM | #12 |
Member#: 223892
Tri-State
01-15-2010, 09:20 PM | #13 |
Member#: 10449
NWIC
01-15-2010, 09:30 PM | #14 |
Member#: 10449
NWIC
It didn't bind before that..
01-17-2010, 12:00 PM | #15 |
Member#: 235396
NWIC
Vehicle:1993 Legacy L Green |
Sounds like your CV joint...
01-21-2010, 01:36 PM | #16 |
Member#: 170813
NWIC
Vehicle:2005 Outback Blue |
Happened in my legacy, had to replace the cv joint!
01-22-2010, 11:59 AM | #17 |
Member#: 36735
MWSOC
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
k2snow - auto or manual? If it's auto, I'm betting you have torque bind.
You can do one of two things - the expensive option is to have them rack the car and replace the transfer clutch packs in the transmission and repair duty solenoid C if applicable. The cheaper option, which I have found to work on 3 different subbies (including an 03 Outback) was to drain the ATF, refill with the recommended grade of ATF + a red bottle of Lubegard ATF Protectant. This little bottle reconditions the clutch packs and helps lower ATF temps which in turn protect components. Quick way to see if you have torque bind (AT only) is to insert a fuse (check owners manual for rating) into the "FWD" fuse box on the passenger side of the engine bay, right up by the firewall. This puts the car in FWD mode and allows you to determine if torque bind is the issue. If you put the fuse in, and the scrubbing noise goes away, voila, torque bind. |
01-25-2010, 11:50 PM | #18 |
Member#: 225624
MAIC
Vehicle:1996 Legacy L Audi TT Nimbus Grey |
It is usually your outer CV joint that makes the clunk/click noise. When the inner one is going it's commonly preceeded by "feeling" minor lurching during acceleration. Anyway, spend a little more and replace the whole half-shaft since you'll already have it apart.
12-19-2011, 09:07 AM | #19 | |
Member#: 302645
E. Canada
Vehicle:2005 Impreza RS Red |
2005 Impreza RS Sedan with Automatic
I put in the fuse and the turning noise was gone. I bought a 10OZ size of the Lubegard ATF Protectant on eBay. Roughly how much should I use the Lubegard ATF Protectant? Thanks.
01-10-2012, 07:25 PM | #20 | |
Member#: 302645
E. Canada
No need for the Lubegard in the ATF
Just report back that Lubegard is not required to free the torque bind, just change the ATF by drain and fill and the run for about 50 miles, ATF drain and fill again. Problem solved! The guy on eBay selling me the Lubegard was unable to answer if the Lubegard was any good at all! Luckily I only wasted $12 and the time waiting for it.
01-12-2012, 02:27 PM | #21 |
Member#: 306690
one word
says it all - CV
12-23-2011, 05:52 PM | #22 |
Member#: 31292
NESIC
Vehicle:21 Taco Xtrek XR4 sienna |
My 03 5MT Legacy wagon is doing the same thing. Swapped the (cheap rebuilt rock auto pos) halfshaft for a better quality unit. Still doing it. RF wheel bearing was kinda nasty sounding, so it's getting swapped out now. I hope it's not the center diff....
12-26-2011, 01:50 PM | #23 |
Member#: 246797
NWIC
Vehicle:2005 LGT Wagon murdered |
My '05 LGT would make a click/clunk sound while in turns. It would almost sound/feel like as I initiated the turn something would roll from the inside to the outside and make the noise as it hit the outer fender. It didn't make the "rolling" noise, but had the same timing as if something was rolling/sliding across the dash ect... Wound up being a snapped OEM endlink.
01-10-2012, 04:59 PM | #24 |
Member#: 31292
NESIC
Wasn't the wheel bearings or RF half shaft. Guess I need to double check other half shafts...but the mechanic who did the wheel bearings (which it needed, it's SO much quieter now) said his fiance's Baja munched the viscous coupling/center diff in 90k miles. I'm at 158k and I use it like an F250.
Anybody know what happens when it fails completely? I can deal with temp 2wd, or even gliding to a stop, but would prefer not to have a "lock all four" situation. Thanks. |
01-30-2012, 10:05 PM | #25 |
Member#: 31292
NESIC
Not long after my last post, I found myself with a FWD Legacy, which really sucked in the ice rink that is my road and driveway. A friend got me a used center diff and after a bunch of hours under my car, I now have AWD again. I have 8-10 hours of work in it, but more than half of that was dealing with cutting a hole in the chassis and welding a bolt in place to replace a busted off captive nut to hold the whole cradle assembly. Snapped both studs off the rubber trans mount and had to drill those out, weld in some bolts, and add some metal to create my Group Eh solid mount.
Shifter linkage bushings all disintegrated during the disassembly process, so I had a slop-o-matic shifter for a week while I waited for overpriced garbage and new linkage from Turn In Concepts. On a non-rusty car with a lift? I think it's less than a two hour job. Double that on crappy low jack stands in an unheated garage. Double that again for snapped off bolts and 50 lbs. of sand getting around your safety goggles and making you miserable. |
Similar Threads | ||||
Tech assistance needed.. Legacy clicking/clunk noise while turning.. ?? | k2snow | North West Impreza Club Forum -- NWIC | 4 | 01-05-2010 02:30 AM |
Clunking noise while ... | aerostar | Newbies & FAQs | 11 | 12-22-2007 01:45 PM |
Uppipe Leak? Super Loud Whining/Screaming noise while in boost | chrisfromalbany | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 05-16-2007 09:41 AM |
Clicking Noise While Turning | TheMainFrame | Brakes, Steering & Suspension | 4 | 04-28-2006 07:54 PM |
Clunking, knocking noises while turning? | Geoff | Brakes, Steering & Suspension | 3 | 11-10-2005 11:40 AM |
