07-09-2020, 01:50 PM | #8476 |
Member#: 437133
Vehicle:06 WRX Limited WRB |
07-09-2020, 01:51 PM | #8477 |
Member#: 437133
Cusco trunk brace install. Not too bad |
07-09-2020, 01:54 PM | #8478 |
Member#: 437133
Big three kit. Ground kit. OTL coil install. Factory air intake put back in. But the hood doesn’t like to close well with it. Anyone have experience with that? |
07-26-2020, 10:22 PM | #8479 |
Member#: 100127
South East
Vehicle:02 WRX wagon WRB |
today I replaced my leaking passenger side cv axel. I purchased my new cv axel at advance discount auto. The heavy duty cv axel was the most expensive axel they sold at $140 and looks visually different from my OEM original. do you think running two different axels will be an issue? thanks
07-29-2020, 10:46 PM | #8480 | |
Member#: 331131
Vehicle:2001 2.5RS-T Silver..thorn Metallic |
08-03-2020, 01:23 AM | #8481 |
Member#: 3409
Vehicle:98 My FMIC Is bigger than yours. |
Didn't touch it. Yesterday I bought a new radiator, because the end tank blew.
08-03-2020, 11:09 AM | #8482 |
Member#: 437133
Installed rear strut tower brace. That was a pain in the ass. Lol |
08-03-2020, 11:10 AM | #8483 |
Member#: 437133
More rear bracing installed. |
08-05-2020, 08:59 PM | #8484 |
Member#: 180155
Vehicle:05 Jdm Sti 2.0 PSM |
Shifter bushing from tic, kartboy and cusco. Selling a new front sti shifter bushing (kartboy) bought a cusco to replace. |
08-31-2020, 11:29 PM | #8485 |
Member#: 437133
This came in the mail today. Should be an interesting weekend. |
09-05-2020, 10:58 AM | #8486 |
Member#: 180155
Need to do some regular maintenance on the sti and check the suspension have a new sound coming from underneath lol |
09-07-2020, 04:26 PM | #8487 |
Member#: 437133
Out with the old and in with the new. |
09-12-2020, 02:21 PM | #8488 |
Member#: 191476
Vehicle:2005 2.5RSTi 2003/4 2.5TS |
Did a fun thing with the lifted wagon the other day.
09-21-2020, 08:34 PM | #8489 |
Member#: 180155
Cleaned up Jdm fog light lights and new overlays. |
11-03-2020, 09:07 AM | #8490 |
Member#: 264827
Vehicle:2017 Toyota Tundra Black |
I traded it in back in June..
For this... RIP NWIC |
11-24-2020, 09:21 PM | #8491 |
Member#: 30364
Vehicle:2005 Devilish STI Angelic white |
12-09-2020, 11:46 PM | #8492 |
Member#: 180155
New to me oem sti shifter trim for the gd sti 2005
12-18-2020, 11:03 PM | #8493 |
Member#: 3409
Putting the 3.0 back together.
The kid was "helping" me out in the shop, working on an art project. He distracted me while putting cam caps in the thing. Everything was within spec except one. Pulled that one and the one next to it and swapped, and we're back in action. |
01-01-2021, 11:02 PM | #8494 |
Member#: 3409
Got the 3.0 back in the car, it needs a heater core I suspect. I can smell coolant now, whereas I bought the thing with a hole in the radiator and filled it with straight water when I put the new radiator in. I noticed the first time I drove it after getting the engine in that the defrost wasn't working so well, but I couldn't smell anything (yay covid) so a week later my sniffer was working more normally and I could definitely smell the coolant (on recirc).
Anyway, I pulled the 96 in, swapped out an axle that was clicking, a galled wheel stud, and put new sway bar end links on. Now it's time to clean it and sell it. |
01-07-2021, 01:51 PM | #8495 |
Member#: 191476
01-07-2021, 04:06 PM | #8496 |
Member#: 180155
Finally got one, needs to be painted black and ready for install |
01-31-2021, 01:29 AM | #8497 |
Member#: 3409
I picked up an 05 Outback 3.0R last summer from a buddy's sister, she was the original owner. At about 127k the radiator popped, she took it to Terry's, they quoted her almost $4k for radiator and head gaskets, so she wanted to sell it. I offered to take a look and see if I could get it fixed (much) cheaper, she just was ready for a new car after 15 years.
So I bought it, threw a radiator in it, put a couple thousand miles on it, then pulled and resealed the engine, found the heater core leaking - not enough to drip, but enough that I could smell it and defrost was having a hard time. When I pulled the dash apart I found the dealership did a hack job on the air bag recall, stuff not put together right, so I fixed it the right way and got rid of all the rattles they caused, and hooked the ambient (interior) air temp sensor that wasn't working properly. And then I ran USB cables for my dash cam and phone charger/holder. Aaaand then I replaced the lower control arm rear bushing, hub bearing, ball joint, and sway bar end link on the driver's side. No more clunks. Still need to work on the right side. |
01-31-2021, 01:32 AM | #8498 |
Member#: 3409
Today I went to the pick n pull and grabbed a new auto dimming mirror, hook for the trunk floor, and dash end cap that the dealer broke.
02-01-2021, 02:00 PM | #8499 |
Member#: 191476
If you ever need engine rebuild parts, I have a torn down EZ30R with less than 1000 miles on it (rings went bad after the cylinders were washed with fuel). Was planning to replace the rings and reassemble, but think I'm going to move in a different direction with my project. Just about everything (aside from the rings) is minty fresh.
02-01-2021, 08:33 PM | #8500 |
Member#: 3409
Lol, I hope I never do.
But those things disappear quickly from the pick n pull. |
Similar Threads | ||||
What did you do to your Subie Today? Version 3 | TrickNipple | North West Impreza Club Forum -- NWIC | 3796 | 09-07-2011 02:52 AM |
What did you do to your Subie Today? Version 2 | Smoke | North West Impreza Club Forum -- NWIC | 1978 | 05-21-2010 12:43 AM |
What did you do to your Suby today? | BREWPUBEAVER | North West Impreza Club Forum -- NWIC | 1197 | 11-01-2009 12:06 PM |
What did you do to your subie today?! | 07imprezadrifter | General Community | 277 | 06-14-2009 11:42 PM |
