Welcome to the North American Subaru Impreza Owners Club Sunday January 17, 2021
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Accessories & Misc
Old 03-27-2014, 03:47 PM   #51
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Available!
2008 to 2014 Coolant Overflow and Washer Tank AKA: Dual Reservoir
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is online now   Reply With Quote
Old 03-27-2014, 03:48 PM   #52
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Available!
__________________
vs.
Old 03-31-2014, 06:11 PM   #53
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Both styles in stock and available!
__________________
vs.
Old 04-01-2014, 11:44 AM   #54
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I keep getting emails if these are available yet... YES!!!
__________________
vs.
Old 04-26-2014, 09:35 AM   #55
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Couple left in stock. Next batch is in production
__________________
vs.
Old 04-28-2014, 11:27 AM   #56
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Install...
If the car has an air pump it will need to be removed for the install. Remove it from the bracket where it mounts to the engine and disconnect the air tubes that go rearward. Also the electrical plug needs to be disconnected. After the reservoir is installed the air pump is dropped down into place. The air tubes need to be pushed rearward for it to drop down (then slid onto the ports), but they are pretty flexible. If there is no air pump on the car, ignore the above.
A bolt is supplied that threads into one of the threaded holes on the bottom. For GD fitment it goes into the rear threaded hole, for GR fitment the front threaded hole. This bolt head fits into the hole the OEM tank's plastic peg fit into.
Pic 1 shows the grommet being removed from the OEM washer tank. This will need to be installed into the bottom of the KBM washer.
Pic 2 shows the elbow assembly. One end has a long tube the other has a spacer. Insert the elbow side that has only the spacer into the OEM grommet that was installed into the bottom of the washer tank.
Pic 3 shows the "h" pump tube assembly fitted to the pumps that are removed from the OEM washer tank.
Pic 4 shows the pumps attached to the hanger and both tube assemblies connected.
Install tips: check the tube lengths and pump placement to assure they run in a downward direction from reservoir to pump. This will help any trapped bubbles escape and prime the pumps. If you test the pumps an no fluid comes out don't panic. Driving the car a short distance is enough to persuade any stubborn bubbles to make their way out.
__________________
vs.
Old 05-27-2016, 05:21 AM   #57
choi0706
Member Sales Rating: (10)
Member#: 126548
fitment on gc8?
choi0706 is offline   Reply With Quote
Old 05-27-2016, 01:54 PM   #58
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The GD version may fit if your fuse box, battery and factory washer tank looks like this...
__________________
vs.
Old 11-10-2016, 02:37 PM   #59
ebo03
Member Sales Rating: (1)
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Subscribed.
ebo03 is offline   Reply With Quote
Old 01-04-2017, 10:53 AM   #60
2012mciga
Member#: 420812
Is there a reason this won't fit on a 2007 WRX?
2012mciga is offline   Reply With Quote
Old 01-04-2017, 03:43 PM   #61
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The version shown in post 51 will fit models back to 2002, and maybe other years as well
__________________
vs.
Old 01-17-2017, 11:44 AM   #62
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Verified to fit up to the current 2017 model year
__________________
vs.
Old 01-25-2017, 09:13 AM   #63
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Going to be moving to a flatter/textured finish. Pics coming soon
__________________
vs.
Old 12-08-2017, 01:54 PM   #64
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Back from the dead. The pics in here were dead or outdated. We've been using a new textured finish for some time now, and have are now etching our logo/text as well
We make a version for every model WRX & STi from 2002 to the current model year.
Strut mount version for 04-05 WRX & STi models:
OEM location version covers ALL WRX & STi models from 2002-current model year:
__________________
vs.
Old 05-18-2020, 02:12 AM   #65
AcquaCow
Member Sales Rating: (46)
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Have you guys ever fit one of these to a GC chassis? It doesn't have the stand-offs the GD has, curious if you've seen anyone fab up a little bracket to adapt it?
I'm still trying to find a good coolant overflow option for my RSTi after years of searching and I keep coming back to this...
Thanks!
AcquaCow is offline   Reply With Quote
Old 05-28-2020, 12:47 PM   #66
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks!
Your timing couldn't be better. We recently send one to Bucky, who has been in the same boat as you. Pretty good work around for getting our 08+ setup to work on his GC...
__________________
vs.
Old 05-28-2020, 03:37 PM   #67
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
https://www.youtube.com/watch?v=UkRLbuDug38
Aah, I've already looked into that model, won't clear at all with an 04+sti motor and upgraded radiator. I was referring to the older model that bolts into where the factory windshield reservoir lives, the 02+ model.
Thanks,
Dave
Old 05-28-2020, 04:37 PM   #68
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks,
Dave
Did you try fitting one?
I don't recall what year STi engine Bucky is using, but it is a US STi swap, and I believe he's using a thicker aftermarket radiator as well (I want to say Koyo-R).
The GD strut tower mount won't work, he tried that first. There were mounting and interference issues that would have required hacking up the unit and making a custom mounting solution. Was more work than it was worth. I honestly thought there would be no way the 08+ version would fit considering how short the front of a GC is, AND with the thicker rad. There's not much room between them. OEM motor mounts and it would likely touch during launch and aggressive gear changes.
All that being said, this is all coming via third party... I don't have the car in front of me, and have minimal expeience with GCs.
__________________
vs.
Old 05-28-2020, 08:24 PM   #69
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Yeah, my Mishimoto is a bit thicker than his koyo, esp with the factory fan shroud that I have on mine.
I can't even fit the stock overflow...been living with a tiny overflow that is designed for FMIC kits that's just a few oz too small for the amount of expansion in my system
I have a mishimoto overflow cylinder that is larger, but I don't have a great place to mount that either due to the smaller and more-cramped GC engine bay, but I guess I have to revisit that and maybe figure out how to mount it on the passenger side of the car where there's more room...
A battery relocation would also solve most RSTi engine bay space issues =)
https://i.imgur.com/KKzNZL6.jpg
Thanks,
-- Dave
Old 05-28-2020, 10:51 PM   #70
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
This isn't a cheap option, but have you considered using a different radiator. I say this for a couple of reasons. The obvious one is that the overflow/wash tank problem would be solvable. The other is that those radiators don't perform that well, and REALLY don't on the GC chassis cars where ambient airflow out the back is further choked by the lack of space between fan shroud and engine.
__________________
vs.
Old 05-29-2020, 03:04 PM   #71
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Maybe if it dies, but my mishimoto has been going strong since 2012 with no issues and my temps are great. Hottest temp I saw all last summer was 207F, and that was really beating on it on a 95F day.
Old 08-02-2020, 08:46 PM   #72
senorlechero
Member#: 456224
Do you know if these will fit an 06 Forester XT?
senorlechero is offline   Reply With Quote
Old 08-04-2020, 10:11 AM   #73
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Will not, but our next batch may. Keep an eye out
__________________
vs.
FS : WeaponR Coolant Overflow/Washer Tank 02wrxbugg Engine/Power/Exhaust 4 04-12-2011 11:39 PM
F/S:VA; STi coolant and washer tank with pump moorebl Engine/Power/Exhaust 5 01-02-2010 02:39 PM
Coolant Not Recirculating Correctly Between Lower & Upper Reservoir Tanks chuglobal Service & Maintenance 13 10-13-2009 09:21 PM
WTB:Windshield washer reservoir/tank caesar Private 'Wanted' Classifieds 2 07-07-2008 01:33 PM
Weapon R Coolant/windshield washer tank Legacy777 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-20-2006 09:57 PM
