Welcome to the North American Subaru Impreza Owners Club Sunday February 28, 2021
Old 11-18-2020, 01:31 AM   #1
Khill4288
Member#: 520347
Default Impreza 2.5i Issues- Please Help!
I have a 2007 Subaru Impreza 2.5i and have been having some problems. A few weeks ago, I was driving and suddenly the check engine light came on, the cruise light started blinking, and the temperature gauge dropped to C. I could’ve sworn I heard something small and metal clink right as it happened. I took it to the mechanic and his diagnostic machine said it was a faulty thermostat. The next week, I took it in to get the thermostat replaced. At some point he came to tell me that it wasn’t a faulty thermostat, there was no thermostat at all. So he puts in the new thermostat and seal, then takes it for a road test. He came back like five minutes later and it was smoking like crazy. He says it’s probably a blown head gasket. The person I bought it from removed the thermostat on purpose to mask the head gasket problem. (I bought it four months ago). They used silicone to seal the thermostat gasket to the engine. He ended up removing the thermostat and trying to redo the seal on the gasket. He also replaced the seal. Since then I’ve been told it’s many different things. There’s no white smoke, it’s not leaking any fluids, my colorant level is normal, the color of the coolant is normal. When I pull out on a hill, it has trouble shifting to higher rpm’s. Other than the CEL/cruise lights being on, that issue pulling out on a hill, and overheating with a thermostat, there are no other issues with it. Without the thermostat it doesn’t overheat at all.
If anyone can help me figure this out I’d be so grateful! Thank you!
Khill4288 is offline   Reply With Quote
Old 01-03-2021, 03:07 PM   #2
09erImprezer
Member#: 520189
What are the codes? You can pull them from the odometer.
If you can't reach over 4k rpms and CRUISE light is flashing, that is limp mode. Gotta check the code to see WHY.
Might be a bad coolant temp sensor, for it to have lost reading on the gauge. Or even a damaged wire.
That is assuming your guy is correct about not being a head gasket problem.
Let us know what you find. There are a LOT of unanswered posts here, not sure why.
09erImprezer is offline   Reply With Quote
