Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 07-17-2013, 10:50 PM   #1
lavid2002
Member#: 226864
Default IAT relocation. Who has done it?
Looking for some help on the IAT relocation. I think people are using GM IAT sensors, drilling and tapping the intake manifold right below the throttle body, and wiring it into the MAF sensor plug. Can someone help me out a bit here?
I am good with the drilling and tapping and the wiring. I just need to know what sensor I should use, where I should put it, and what I tap it into.
Thanks everyone
-Dave
lavid2002 is offline   Reply With Quote
Old 07-18-2013, 12:45 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I'm using the gm one. Its in my ic piping after the ic. I used a aluminium 02sensor bung from summit and welded it on. The wiring I cant help you with, I'm using a standalone.
scby rex is offline   Reply With Quote
Old 07-18-2013, 09:58 PM   #3
lavid2002
Member#: 226864
Thanks for the reply. I have no experience with welding aluminum but this might be a good excuse to go get some brazing sticks and learn.
Anyone else with the wiring advice? I'm sure it's as easy as running the sensor to the two wires used for the IAT on the MAF connector if someone knows the pinout for it.
Old 07-19-2013, 10:38 AM   #4
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Maxwell Power installed one on the lower end tank of my friend's TMIC. I wasn't there to discuss location with MPS, but I would think that the intake manifold runner for the #3 cylinder (closest to the turbo) would be the one to be most concerned about...
car_freak85 is offline   Reply With Quote
Old 07-19-2013, 12:41 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
No I don't know any tuners that would want it in the manifold. It heat soaks too much and makes it not accurate.
Old 07-19-2013, 08:22 PM   #6
funk32
Member#: 245787
GD Race Car
I just installed mine and like scby rex I placed it in the IC piping about 10" from the TB and my meth bung is about 5" from the TB.
funk32 is offline   Reply With Quote
Old 07-19-2013, 10:33 PM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
Been doing all of mine like so. Right on the opposite side of the throttle body.
Heat soak is minimal.
sidewayz is offline   Reply With Quote
Old 07-20-2013, 01:04 AM   #8
lavid2002
Member#: 226864
I have only seen these installed in the intake manifold. Plus I have phenolic spacers, and the IAT sensor is insulated from the threads on it. I think I know where to put it. What about the wiring
Old 07-20-2013, 11:06 AM   #9
scby rex
Member#: 104878
02 wrxbastardchild
I know there was a diagram around here that showed what wires to tap into, orange with a stripe and brown I think.
Old 07-20-2013, 02:48 PM   #10
funk32
Member#: 245787
GD Race Car
Old 07-21-2013, 01:55 PM   #11
lavid2002
Member#: 226864
That link is perfect
Thank you very much!
Old 07-21-2013, 09:55 PM   #12
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
No need to tap and weld. Use this one and just thread it into your intake manifold and get the most accurate reading you can. It uses the same calibrations as the GM IAT.
http://www.t1racedevelopment.com/ind...mart&Itemid=72
Ive been using this one with good success.
banshee04 is offline   Reply With Quote
Old 07-22-2013, 11:26 AM   #13
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
What hole are you threading it into? isnt the pcv a 1/4"npt? Or are you using a insulator of some sort as a adapter?
I have the T1 as well...
Old 07-22-2013, 11:38 AM   #14
banshee04
Member#: 179014
'06 WRX/STi
There is a threaded 1/8th NPT hole with a barb fitting in it on the front of the IM used for the EGR/Purge valve. I deleted all that stuff and used the hole for the IAT.
Old 07-22-2013, 12:28 PM   #15
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Oh that one LOL. yeah we dont really delete the EVAP over here. even on the 600whp because race car set ups.
Old 07-22-2013, 05:09 PM   #16
lavid2002
Member#: 226864
Awesome
Thanks guys!
Old 07-22-2013, 10:27 PM   #17
funk32
Member#: 245787
GD Race Car
I have a cosworth manifold so I put in on the IC piping
Old 07-23-2013, 05:01 PM   #18
blubug_768
Member#: 324962
02 WRX
I put the sensor (gm iat) in my tmic where the bov was.
Then for the wiring I put push plugs so I can go back to stock for smog.
blubug_768 is offline   Reply With Quote
Old 07-23-2013, 07:46 PM   #19
funk32
Member#: 245787
GD Race Car
so how are you releasing the pressure?
I have also done that but not for smogg, its just incase I need to swap back for what ever reason.
Old 07-23-2013, 11:10 PM   #20
blubug_768
Member#: 324962
02 WRX
I just let it surge... it sounds neat.
Old 07-24-2013, 03:49 AM   #21
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by funk32 View Post
Fantastic link, thanks for posting this!
Old 07-24-2013, 08:26 AM   #22
lavid2002
Member#: 226864
Old 07-24-2013, 11:45 PM   #23
dub c
Member#: 145069
Keep It Sleazy
I would recommend the GM IAT sensor.
It should be as close to the combustion chamber as possible.
Perhaps you should buy a AOS and use the hole in the manifold housing the PCV valve.
If you have some spare change lying around, the long runner spec c manifold has a hole specifically for an IAT sensor, and you can scrap the TGV's at the same time if you haven't already. You will need adapters for the fuel rails though, somebody around here sells them.
dub c is offline   Reply With Quote
Old 08-10-2013, 09:55 AM   #24
sidewayz
Member#: 5810
2001 S366 2.5RS
Bumping this back up. Been hearing a lot of people saying the iat in the manifold is bad with ZERO proof as to why. It's always a blanket statement.
Been doing it and been watching afrs and all is well. Anyone else?
Also check this
http://www.mrm-racing.se/forum/showp...5&postcount=26
Old 08-13-2013, 02:28 PM   #25
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
Also check this
My tuner (Jason Carberry) asked me to install mine in the intake manifold, just beyond the throttle body, right next to the check valve for the crank. My logic for doing it this way is, if you're at an idle and your throttle is closed, you want the engine temps to be what the manifold temp is since that air is more stagnant and probably heat soaked. Your charge piping or TMIC would have less heat soak and be a couple degrees cooler than the air the cylinders are actually seeing.
Do those couple extra degrees of temperature matter? I doubt it. Do I have proof this is true and not just BS? Absolutely not. That's just all an educated guess on why he prefers the IAT sensor in the manifold rather than the cold pipe/TMIC.
Travisty is offline   Reply With Quote
