Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2020
Old 03-15-2020, 11:13 AM   #1
AndrewPereyra
Member#: 512585
Default 2005 2.5rs no spark
I have a 2005 impreza 2.5 rs the engine blew I bought an 04 engine put stock intake manifold I drilled and tapped the egr valve whole new spark plugs new oil drained gas put new gas crank and cam gears changed ecu distributer changed all the sbf tried immobilizer there is none changed the Maf sensor Checked timing new battery but the car cranks no spark please help need to get this done
AndrewPereyra is offline   Reply With Quote
Old 04-02-2020, 08:57 AM   #2
Shiloh51933
Member#: 498320
2005 Saab 9-2x
Did you ohm out the spark plug wires? You didn't write anything about wires...one of first places to check.
Shiloh51933 is offline   Reply With Quote
Old 04-04-2020, 12:27 PM   #3
AndrewPereyra
Member#: 512585
Yes I changed the entire distributor and wires
Old 04-14-2020, 10:10 PM   #4
jdmjess2
Member#: 513729
Default RE: No Spark
Check fuses with a power probe and unplug a spark plug wire to check to see if there is spark at the coil pack and if there isn't then check your cam and crank sensor plugs to make sure they are plugged in and check the main engine harness connector in the passenger repair by the differential dipstick.
jdmjess2 is offline   Reply With Quote
Old 04-26-2020, 01:20 PM   #5
AndrewPereyra
Member#: 512585
I checked all the fuses but Iím not getting ground to the coil
Old 05-23-2020, 04:28 PM   #6
AndrewPereyra
Member#: 512585
Today I cleaned The grounds on the front of the intake and same thing cranks no spark does anyone know what this could be The car will fire with plenty starter fluid but idles horribly and shuts off the rpms arenít even marked changed the fuel pump assembly has fresh gas
