03-15-2020, 11:13 AM | #1 |
Member#: 512585
2005 2.5rs no spark
I have a 2005 impreza 2.5 rs the engine blew I bought an 04 engine put stock intake manifold I drilled and tapped the egr valve whole new spark plugs new oil drained gas put new gas crank and cam gears changed ecu distributer changed all the sbf tried immobilizer there is none changed the Maf sensor Checked timing new battery but the car cranks no spark please help need to get this done
04-02-2020, 08:57 AM | #2 |
Member#: 498320
Vehicle:2005 Saab 9-2x Aero Red |
Did you ohm out the spark plug wires? You didn't write anything about wires...one of first places to check.
04-04-2020, 12:27 PM | #3 |
Member#: 512585
04-14-2020, 10:10 PM | #4 |
Member#: 513729
RE: No Spark
Check fuses with a power probe and unplug a spark plug wire to check to see if there is spark at the coil pack and if there isn't then check your cam and crank sensor plugs to make sure they are plugged in and check the main engine harness connector in the passenger repair by the differential dipstick.
04-26-2020, 01:20 PM | #5 |
Member#: 512585
I checked all the fuses but I’m not getting ground to the coil
05-23-2020, 04:28 PM | #6 |
Member#: 512585
Today I cleaned The grounds on the front of the intake and same thing cranks no spark does anyone know what this could be The car will fire with plenty starter fluid but idles horribly and shuts off the rpms aren’t even marked changed the fuel pump assembly has fresh gas
