Tire & Wheel Forum sponsored by The Tire Rack |
12-02-2019, 01:32 PM | #1 |
Member#: 186084
Vehicle:2018 STI SWP |
Need quick help with possible tire pull
I just got Michelin PS A/S+ tires put on my 18 STI. (15k miles).
The car is pulling slightly toward the passenger side, which demands constant minor adjustments. When I apply more throttle, the car pulls more. I noticed that the tread pattern on the passenger side is facing a different direction than the tread pattern on the driver's side. HOWEVER, all four tires are marked "outside." Should I bring this to the attention of the tire shop?? This doesn't seem consistent. The arrows in both pictures are pointing toward the front of the car: Driver's side tire: Passenger's side tire: The tires have about 1,000 miles on them so far. I'm looking for some quick advice so I don't start to get uneven wear. Is this the source of my problem? Why are they both designated "outside."
12-05-2019, 04:46 PM | #2 |
Member#: 497200
BAIC
Vehicle:2019 WRX Cool Gray Khaki |
Those are asymmetrical tires, tread pattern on the inside and outside are different. If they all say outside facing out, then they are mounted correctly. You should probably have your alignment checked.
12-06-2019, 12:31 PM | #3 |
Member#: 186084
I had the car aligned by Subaru a couple months ago. It drove straight prior to this. I did a little homework and this may be a common issue.
