Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 10-09-2014, 09:29 PM   #51
rustylegasy5787
Member#: 379621
1995 legasy
green with a black roof
Default what year was the car
Originally Posted by sense of nature View Post
^ This , I have done a 255 case w/ Sti internals, N.A heads & ran over 20 P.S.I. The cams kinda choke after 5 k tho
what year was the car and what kind of computer did you use .i wnt to do this same build i have a td04 sti top mount intercooler.2004 fxt block and piston rods and crank i was gonna pull sum heads off of a 98 wagon i found in my buddies junk yard have them port and polished triple cut valves slap them on and drop it in wit a few littil gauges boost gauge air fuel gauge oil pressure gauge fuel pressure regulator and the blow off valve what else do I need not looking to run a hole lot of boost 10 psi at moste .thank you im gonna keep reading this form
rustylegasy5787 is offline   Reply With Quote
Old 10-09-2014, 09:48 PM   #52
rustylegasy5787
Member#: 379621
1995 legasy
this is the most helpful thread for my build that I'm doing the 257 with the 2.5d heads and the 25 D intake
Old 10-10-2014, 07:03 PM   #53
no694terry
Member#: 220816
2018 Exotruck
I run 19psi on ej25d hla heads. I have 97 cams in them, they have the offset exhaust lobes. My power curve is pointed towards the moon when i hitvthe rev limiter. I would think the heads are good for 7k. I think the ej25d cams may even be identical to ej20k cams. But dont quote me
no694terry is offline   Reply With Quote
Old 10-13-2014, 09:52 PM   #54
99obsport
Member#: 403878
I remember reading the same thing about the ej25d heads being identical to the ej20k heads; can't claim it to be fact as this is a vague memory from when I was researching a hybrid build. But there is a difference in stock redline between the 2 if my memory serves me right. Isn't the 20k stock redline 8k?
99obsport is offline   Reply With Quote
Old 10-13-2014, 09:54 PM   #55
99obsport
Member#: 403878
Or is it 7500? Been a while since I researched all this.
Old 10-14-2014, 11:32 PM   #56
08impreza2.5isport
Member#: 369847
2007 Legacy Spec.B
There were 2 ej20k's, one shim over bucket and one shim under bucket. STI was the shim under bucket and wrx was the shim over bucket I believe. From what I remember, the wrx ej20k was just an updated ej20g. The wrx ej20k had a 7500rpm redline and STI ej20k was 8000rpm. Ej25d cams are very similar to ej20g cams and I believe the head casting is closer to the wrx ej20k.
08impreza2.5isport is offline   Reply With Quote
Old 10-16-2014, 08:15 AM   #57
no694terry
Member#: 220816
2018 Exotruck
Here's a log from this mornign with my stock ej25d heads and stock 95 ej22e block. I switched to boost-thru MAf the other day and have been loving it. I used to get a lot of boost taper because of my IAC. Now I'm peaking at 20.2 psi and only taper to low 19's. This 4th into 5th gear and my rev limiter is 6250 so I try and shift before 6, but you can see its showing no sign of letting up on flow up top. My work PC doesnt play well with the window so from the top
Green = Throttle %
Dark Blue = Duty Cyle %
Light Blue = MAFv
Red = RPM
Yellow = timing
Pink = AFR
Old 03-06-2020, 02:10 PM   #58
Nelson Veloso
Member#: 455548
I am sorry my english skills are bad.
In short, is it possible to use pistons and connecting rods of the ej255 or ej257 engines on the ej25D?
Do you need any adaptation? Which joint to use?
My Ej25D is from the second phase and I would like to leave it with 300hp.
Nelson Veloso is offline   Reply With Quote
Old 03-06-2020, 03:55 PM   #59
no694terry
Member#: 220816
2018 Exotruck
bad thread to ask but if you ej25D is phase 2, is it a Ej254? in the US we didnt get DOHC Ej25 past 99 except for the Ej255 and Ej257, both turbo
In 99, Some Legacies here had a Ej25D with a phase 2 block and Phase 1 heads. That motor you can possible put ej255 rods in, all previous EJ25D motors had smaller crank rod journals and a #3 thrust bearing. While it's possible to throw a Phase 2 crank into a phase 1 motor, it's not ideal
Old 10-05-2021, 04:10 PM   #60
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
'99 EJ25D heads, 97(?) EJ22E stock block, ~17 PSI from a TD04... She effin' loved it. I was limited to 6200, so it kept pulling hard till redline. I've read the cams die off hard after 6500, and that's where the 20g/20k cams come in. I was never able to find any...
Whoops, forgot to check the date
SoCoNoHa is offline   Reply With Quote
Boost pressure starting at -20 psi, peaking at 5 psi...whats wrong? prophet03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-21-2010 07:26 PM
No boost over 20 PSI rainmanjam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-10-2005 07:23 PM
Boost spike all the way to 20 psi heavyDOODIE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-12-2004 04:09 PM
Autometer Z-Series, Boost/Vacuum, 30 in. Hg/20 psi., 2 1/16 Mechanical Boost Gauge lstepnio Private 'For Sale' Classifieds 2 12-12-2004 11:11 AM
20 psi overboost on stock boost controller EricB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-21-2002 10:52 AM
