11-10-2010, 12:06 PM | #26 | |
Member#: 236349
Vehicle:1993 Impreza OD Green |
11-22-2010, 12:09 PM | #27 |
Member#: 226535
E. Canada
Vehicle:1998 Impreza L (RIP) |
Ok, I answered my own question....
These cams ROCK with boost. HAULLLLL ASSSSS all the way to fuel cut, 6500 RPM. This is at my current rough base tune at 13-15 psi. Did I mention it HAULS ASSSS? I Think Im in love... |
11-23-2010, 09:55 PM | #28 |
Member#: 81633
Vehicle:'98 RS-T Blue |
So what cams did you use?
11-23-2010, 11:46 PM | #29 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Sounds like he left the stock EJ25D cams in it.
cdn, you can find some early jdm turbo cams to put in those heads down the road when you're ready to up the boost. EJ257 valvesprings and retainers are drop in with those heads, and will help stave off float at your desired boost levels. I would suggest going to shimless buckets as well, once you know what thicknesses are going to be needed for each valve. Keep up the good work! Jay |
11-24-2010, 11:16 PM | #30 |
Member#: 194452
Vehicle:The Mr. Wizard |
So what compression are you running now cdn? Glad to hear the car's still hauling ass, you have a rough estimate at what power you have now? (I'm about ready to start my build, as soon as I can extract a broken head bolt ).
11-25-2010, 08:53 AM | #31 |
Member#: 226535
E. Canada
Bang on Storm, Cams are EJ25D, DOHC, came on a '99 Legacy Outback (This engine comes from the factory with phase 2 block, and phase 1 dohc heads).
For my intents and purposes, I will be leaving these heads as is, with the cams Im using, until I see signs of float or other crap. Basically, I was looking for bang for the buck here. I am extremely pleased with the results of boost mixed with this setup, the improvement in response/power over the EJ22 with similar or more boost is eye widening... Kinda stupid on the street now lol... Especially with the temp dropping to freezing around here. |
11-25-2010, 09:10 AM | #32 |
Member#: 226535
E. Canada
I believe its around 8.5:1 now. That is with a Phase 2 EJ25 block and crank (52mm rod journals, #5 thrust bearing location) oem EJ257 rods and oem EJ257 pistons and rings, Cometic .051" (1.5mm) MLS headgaskets, and EJ25D shim over bucket heads (not resurfaced).
Im not sure.. I am hoping for 320 HP at the crank at 15 lbs boost but I will have a better idea when I use the Dynolicious app (like a gtec) on my wife's phone. Just gotta get the car weighed... Good luck! I had 3 broken exhaust studs to remove from these heads before I used them. What I did was weld a nut on each broken stud, and after a few tries, the studs were removed with a ratchet and socket. That only works IF there is some stud/bolt protruding from the deck... |
11-26-2010, 10:33 AM | #33 |
Member#: 214192
South East
Vehicle:2003 WRX WRB |
Digging the build! I own a '99 legacy outback and would love to have more power.
Sorry to ask a noob question, but are the 257 rods and pistons a direct fit for the crank and bore? Also, do you find the emanage blue to be sufficient for your build? |
11-27-2010, 12:38 AM | #34 | |
Member#: 226535
E. Canada
The Emanage Blue does all I need it too, although it would be nice to compensate for large injectors without cutting the MAF voltage the way it does. It is tricky to get the tune perfect, but with some time and the right monitoring tools, such as wideband air fuel gauge and datalogging software, really good results are possible. |
11-27-2010, 12:11 PM | #35 |
Member#: 5218
Jay |
12-09-2010, 12:43 PM | #36 |
Member#: 123295
TXIC
Vehicle:2001 2.5RS w/ EJ257, 6-speed, Brembos |
I've been running my '96 EJ25 HLA heads with boost, only 11 psi though, for a long time. Years. I don't think those heads are the best but they certainly aren't bad. My low and midrange torque is rediculous. I have only a poor tune using an OBD1 EJ22 ecu with no injector correction so my top end power is nonexistent because the car is so rich, but with a tune that should change. The heads and cams aren't the weakest part of the setup though IMO.
Good luck with your project and keep us updated. |
12-09-2010, 02:37 PM | #37 |
Member#: 191514
NWIC
Vehicle:'05 FXT 6spd, 98 Fozzy lifted,'01 RS 6spd |
I run 23 pounds with a 20g, ej22t with phase 1 dohc heads and stock cams. Only mods were port matching the heads to the ej20k manifold. It gets revved to 6.5K on a regular basis, doesn't seem to care. Runs a hydra ems, dyno tuned to 300hp by Phil at Element.
It probably could be more efficient with another set of cams and higher compression but I'll keep what I have for now. |
12-09-2010, 03:01 PM | #38 |
Member#: 226535
E. Canada
See?? The best responses came AFTER I made up my mind, and came to my own conclusions LOL.. Big boost FTW on EJ25D cams...
I was looking at one of my Emanage blue datalogs from when the 2.5 first went in, 4.96V at the MAF! It was well above freezing that day, and boost was only around 12 psi max... So at 16psi in below freezing temps I must be maxing it out... Anyone know how many G/sec the 22680 AA160 MAF is capable of reading at 5V? This is the stock MAF in the 1998 2.2 and 2.5 imprezas and legacys and many ej20 turbo models... |
01-03-2011, 04:20 PM | #39 |
Member#: 123295
TXIC
By the way I wanted to add to this that at redline it feels like I am floating the valves on my 96 HLA heads.
01-04-2011, 02:41 AM | #40 |
Member#: 226535
E. Canada
For anyone who wants this info as reference, Xephyr ran a similar longblock setup as me, very high boost, big turbo...
http://forums.nasioc.com/forums/showthread.php?t=690248 Pay close attention to posts 42, 45, and 49... BTW, I am now at 17 psi peak, 16 psi to redline. Will be increasing that once my Kenne Bell Boost a Spark is installed hehehe... |
01-13-2011, 12:47 PM | #41 | |
Member#: 226535
E. Canada
Stock pistons FTL. |
01-13-2011, 07:59 PM | #42 | |
Member#: 214192
South East
01-14-2011, 01:20 AM | #43 |
Member#: 194452
Ringland or worse?
01-14-2011, 02:10 AM | #44 |
Member#: 226535
E. Canada
Still have to take apart the engine... Burns oil, fills up catch can quick under boost, idles rough, with lower vacuum (~15-16 in/hg), constant misfire codes for cyl 2 and 4, and finally, a smoking oil filler neck.
Looking at Supertech pistons right now, as they seem to be the most cost effective solution, but not to much turned up in my last 24 hours of searching lol! |
01-14-2011, 02:47 AM | #45 |
Member#: 194452
Definitely sounds like leaking serious compression. No nasty knocking or banging? I've got custom wisecos for my little build, ran me 550 shipped. They're due to get here in a week or so, so I can't tell you whether I like them or not.
But I haven't heard of anyone with issues with them other than their circlips failing(Get factory circlips if you go this direction, just to be sure). But the off the shelf EJ257 pistons @ 8.5:1 are 450ish from what I have seen. Here is their catalog. I'm hoping the piston(s) are just cracked for the block's sake. Fingers are crossed for you! Good luck! |
01-14-2011, 09:11 AM | #46 | |
Member#: 226535
E. Canada
01-15-2011, 09:01 PM | #47 |
Member#: 194452
That is good, the piston(s) are still at least in one piece. Have you done a compression test?
01-16-2011, 06:39 PM | #48 |
Member#: 226535
E. Canada
No compression test yet. I dont plan to either. Im going to pull the engine out, remove heads, remove pistons, inspect broken ones, take pics for myself and Nasioc, check bores for damage, order pistons 99.5mm (Mahle Austrailian ADM EJ257 square dish pistons (Thanks theotherguy!!!!!) or Supertech EJ257 pistons. The rest, we will see. Really hoping the bores are good, I do not want to have to bore the EJ25 open deck bores! They are thin enough!
01-16-2011, 08:14 PM | #49 |
Member#: 238539
International
Vehicle:98 RS BDP |
I love this thread, just bought a shortblock out of 99 RS that supposedly has 65k on it and a single spun bearing, looks to be a good candidate but it still needs to be broken down, $100
Looking to run this same setup and I'm interested to hear anyone elses opinions on valve/Valve spring/retainer/whatever swap from the ej257 heads to our EJ25D. Planning on rebuilding some heads to swap in with the Sti swapped shortblock. I won't be going for any crazy whp numbers though. |
01-17-2011, 12:29 AM | #50 | |
Member#: 194452
Boost pressure starting at -20 psi, peaking at 5 psi...whats wrong? | prophet03 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 01-21-2010 07:26 PM |
No boost over 20 PSI | rainmanjam | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 10-10-2005 07:23 PM |
Boost spike all the way to 20 psi | heavyDOODIE | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 12-12-2004 04:09 PM |
Autometer Z-Series, Boost/Vacuum, 30 in. Hg/20 psi., 2 1/16 Mechanical Boost Gauge | lstepnio | Private 'For Sale' Classifieds | 2 | 12-12-2004 11:11 AM |
20 psi overboost on stock boost controller | EricB | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 05-21-2002 10:52 AM |
