Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 01-21-2010, 11:28 AM   #1
prophet03
Member#: 205807
Default Boost pressure starting at -20 psi, peaking at 5 psi...whats wrong?
i have an 03 wrx that didnt have a boost gauge on it when i bought it, i only recently got a gauge and it is only giving me a maximum reading of 5 or 6 psi. im wondering if its the boost controller thats holding it back, but its the stock controller, and my utec has the stock settings on it... it also takes a while for the boost to get to positive psi. my mechanic said to take the wastegate hose off and see if the pressure builds fast, in which case get off the gas. thats fine, but how do i fix it then if that happens.
prophet03 is offline   Reply With Quote
Old 01-21-2010, 12:00 PM   #2
IAmTheSleepySubie
Member#: 204177
2000 OBS with EJ205
is it a decent boost gauge cause the gauge you got could be bad.
any other mods on the car?
and is that 5 psi at full throttle?
if i stay under 1/4 throttle or so it stays right about 5psi
IAmTheSleepySubie is offline   Reply With Quote
Old 01-21-2010, 04:15 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Wastegate boost should be at least 8-10 psi. Sounds like your gauge is screwed up. Especially if it's really reading -20psi at any time (-20psi is physically not possible,) though I suspect you're misreading the units, it should be +20mmHg vacuum, not -20psi.
If you have a UTEC, presumably someone tuned it at some point? They should have calibrated the MAP readings when they did it. Log the UTEC and what does it say for boost pressure? If you're at approx sea level, even the UTEC's default calibration should be close enough to tell the difference between 12 psi (stock boost) and 5-6 psi. Log and look at WOT ~4kRPM.
Concillian is offline   Reply With Quote
Old 01-21-2010, 04:17 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
stock boost controller? you mean the ecu? sounds like you are dealing with someone else's halfass returned to stock hack job.
I wouldn't take the wastegate hose off and run. It only takes a split second to ruin an engine. one thing to consider, with the stock turbo, the wastegate spring is at least 7 psi. you should hit that no matter what your controller (either the ecu or standalone) is trying to do. There is simply no way to open the wastegate at a lower pressure.
Old 01-21-2010, 06:56 PM   #5
prophet03
Member#: 205807
i thought about it being a bad gauge, but aparently its supposed to make vaccuum at idle, but 20? 5 psi at full throttle and no, the boost controller is separate from the ecu, ecu controlls the boost controller. anyway, wats the probable cause for it? more than likely the gauge?
Old 01-21-2010, 07:03 PM   #6
drummerboy827
Member#: 124720
2009 WRX Hatch
Can't believe no one's asked the obvious yet..
How's the car running?
If your engine was actually only getting 5 psi of boost from the turbo, you would know. It would be slowwwww...
drummerboy827 is offline   Reply With Quote
Old 01-21-2010, 07:10 PM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
It would help if you could post some details:
o what brand and type (mechanical? electrical?) of gauge is it?
o where did you tee off?
o what units does your gauge read in? a value of -20 would be about right for vacuum at idle in inches of mercury (in-Hg)
o what conditions are you measuring the boost? you need a good bit of load (e.g. a hard 2nd gear pull) to hit full boost
UkNuck is offline   Reply With Quote
Old 01-21-2010, 07:22 PM   #8
prophet03
Member#: 205807
I have headers, upipe, tbe, intake, turboxs utec, thats about it. i hope its just the gauge, so its easy and cheap
Old 01-21-2010, 07:26 PM   #9
prophet03
Member#: 205807
the engine runs fine, its just as you said slow at higher rpms, 3500+. its a prosport mechanical gauge, measuring boost in all gears, reaches max psi in 3rd, 4th, and 5th. yea sorry, just easier to write -20 psi lol, yes, 20 in-Hg
Sti Peaked at 1.2 Bar or 17.5 PSi of boost why hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-31-2007 07:24 PM
Gears 3-5 slipping, whats wrong? Agkelos Transmission (AT/MT) & Driveline 9 07-29-2005 03:29 AM
Defi Boost Gauge @ 14 PSI Peak? W/O Boost controller... STi_Pete Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-03-2002 09:30 PM
Misfiring When at 17.5 psi and 20 F mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-04-2002 08:05 PM
I get full boost 15.14 psi Peak in first and Sec. Gear??? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-17-2001 04:51 PM
