03-25-2020, 11:32 AM | #1 |
Member#: 493764
Vehicle:2019 WRX Limited Ice Silver Metallic |
Tomei Unequal Length Headers for FA20DIT?
So I was under the impression that unequal length headers are impossible to use on the FA20DIT due to the twin scroll turbo, then Tomei puts this out. What's everyone's thoughts? I'm not looking to buy or anything, just starting discussion on it. Here's the link..
http://www.tomeiusa.com/?p=15773
03-25-2020, 11:59 AM | #2 |
Member#: 395275
RMIC
Vehicle:2012 STi SWP |
Going to get a lot of hate here, but to me it appears you'd get the boxer rumble back from those.
They do look like an UELH design, so I'm curious if they actually perform decent. |
03-25-2020, 12:12 PM | #3 |
Member#: 431550
Vehicle:2016 WRX ALL THE STAGES |
UEL Headers are worse... More just for the rumble SwAgz I guess. Way better performance and efficiency out of EL headers.
03-25-2020, 12:15 PM | #4 |
Member#: 428511
Vehicle:2016 STI |
well you are kind of taking half the benefit away from the twin scroll, but otherwise it won't harm anything.
but agreed with waddlz there are going to be some outraged people on this topic |
03-25-2020, 12:18 PM | #5 |
Member#: 480524
Vehicle:2015 WRX Black |
Sounds amazing, less efficient. I wouldn't run it but that's just my opinion. Im sure some tuners would also not recommend it
03-25-2020, 12:20 PM | #6 |
Member#: 487500
Vehicle:2018 WRX |
An equal length header should perform better regardless of turbo design. Certainly the car isn't going to implode on on itself by using a UEL header with a twinscroll turbo.
The question is, are some enthusiasts willing to sacrifice performance for sound, my bet is the answer is yes. This product will likely fit a demand. Being new to the Subaru community, I was slightly disappointed that my 2018 wrx didn't have the signature rumble, but function over form I guess... |
03-25-2020, 01:01 PM | #7 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
This is absolutely hilarious
03-25-2020, 02:13 PM | #8 |
Member#: 493764
Oh yeah I'm sure people are going to be hating big time. I guess if you just want the sound and don't care about efficiency they're the product for you. Oh well, I'm not trying to spend $800 for less efficiency but better sound.
03-25-2020, 03:17 PM | #9 |
Member#: 428511
Vehicle:2016 STI |
you ain't seen nothin
Try saying you don't need to slam redline 15 times on a new motor to prevent cylinder glazing and it's going to be like when the Iraqis pulled down that statue of Saddam in an angry mob |
03-25-2020, 04:38 PM | #10 | |
Member#: 487500
Vehicle:2018 WRX |
Maybe it will be enough to offset the losses of the UEL design? |
03-25-2020, 04:52 PM | #11 | |
Member#: 431550
Pretty sure i remember reading a thread by one of those 2 where they mentioned the stock headers were pretty good and difficult to improve on for the cost. IMHO, if you replace the stock headers it should be for EWG killer B set up. Stockers are good for everything else. |
03-25-2020, 05:04 PM | #12 | |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
The 'burble' that is unique to USDM turbo EJs (Impreza, Forester, Legacy, Outback) is due to the UEL manifold that Subaru uses in their base model performance trims. The good stuff from Subaru mostly goes to UEDM and JDM, and since they are the top tier performance cars, they get the EL manifold from the factory for the performance enhancing benefits. |
03-25-2020, 05:04 PM | #13 |
Member#: 233053
Also on the videos about the perrin equal length it stated no tune was required for gains
03-25-2020, 05:28 PM | #14 |
Member#: 512261
Vehicle:2015 Wrx Galaxy blue |
I also would like to see a dyno comparison between stock and the tomei uel
03-25-2020, 06:13 PM | #15 |
Member#: 447898
BAIC
Vehicle:2022 Tesla M3P 2019 STI CWP |
Wow, this actually happened. Did April Fools' come early?
No video or sound clip to hear the UELH "rumble"? No dyno charts showing gains (or rather losses) compared to the stock header? Their own advertisements pretty much say all there is to say... ELH = Efficiency & Power OR UELH = a symphony of colliding exhaust pulses & inefficiency .. pick one. Take away the advantages of an equal length header and a proper twin scroll turbo setup.. and you end up with slower spool, worse transient response, a narrower powerband, reduced fuel economy, and so on.. all while spending $700+ to do it And increasing the chances of unequal cylinder exhaust pressures & EGTs.. and detonation/knock. Keep in mind that that the EJ257's UELH allowed for shorter primaries due to the turbo's location. This UELH is actually increasing the length (also diameter & volume) of the primaries reducing the exhaust velocity. Sadly, I'm sure a lot of people will fall for this gimmick despite tuners advocating against them. Many FA20DIT owners value Ron's opinion.. so maybe this will help: "Equal length headers are better, especially on a twinscroll turbo. Slip joints will leak over time. Everyone used to dream about having twinscroll equal length setups on EJ's and very few people did it because it was so expensive. And now that we are given it stock, companies are doing this and making single scroll turbo kits." A local Subaru tuner, Travis @ Snail Performance, responded with: "Waste of money." Edit: Also note this is a Tomei USA product. http://www.tomei-p.co.jp/tomei-brand/ http://www.tomei-p.co.jp/news/info/1990/ Last edited by WRXnick16; 03-25-2020 at 09:37 PM. |
03-25-2020, 06:51 PM | #16 |
Member#: 233053
I haven't done headers on this car yet but watching the videos alone it looks like a pain in the butt. I like the rumble but not sure I would go thru that headache if it losses power.
03-26-2020, 10:12 AM | #17 |
Member#: 454531
I just ordered a boat load of parts for my 16 wrx. (turbo back exhaust, AOS, Boost controller, AP, TGV/EGR deletes, Short shifter, shifter bushing,shift stop, hardware kit for the jpipe) ive been researching a header that i want and as much as i miss the rumble, how do you put efficiency up against sound? i dont get it lol
03-26-2020, 11:44 AM | #18 |
Member#: 480524
There's a video somewhere out there on youtube of a fa20dit with UEL headers. Sounded great but, well lets just wait for the dyno charts.
03-26-2020, 11:47 AM | #19 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
Patiently waiting for some internet clout god to install this without a tune and blow his motor then rant about how bad the product is on YouTube.
Tell me I'm wrong. |
03-26-2020, 12:06 PM | #20 |
Member#: 447898
BAIC
Yes. You no longer have the advantages of an equal length header or twin scroll setup.. and you're also stuck with the "restrictions" of a twin scroll turbine housing without utilizing any of the benefits
So lose. lose. lose. Not to mention you're also sacrificing reliability of the manifold itself compared to the OEM or Killer B header (welds, material, slip joints, etc.). I'd also much prefer the OEM manifold with the OEM heatshields or the Killer B header with SwainTech coating compared to wrapping a header on a daily driven street car... And then there's the merge collector.. even in comparison to Tomei USA's equal length header:
Tomei: Killer B: Although, Tomei's collector does at least look better than Perrin's: Given the similar pricing.. it's a no brainer if you feel the need to upgrade the OEM header. Last edited by WRXnick16; 03-26-2020 at 12:12 PM. |
03-26-2020, 12:09 PM | #21 |
Member#: 395275
RMIC
yeah but
how wide is Killer-Bs? That Tomei is WIDE |
03-26-2020, 12:16 PM | #22 | |
Member#: 447898
BAIC
Definitely produces an unusual FA20DIT torque curve like suspected. Torque comes on later and falls off sooner. More reminiscent of the EJ257 (blue) than the FA20DIT (red): And stage 2 Killer B (red) vs OEM (blue): At 3k rpm, it's easily down 70+ wtq compared to a standard stage 2. It makes that wtq figure ~1,000 rpm later @ 4k rpm. Some of the loss is likely due to the CVT, but it appears to even be down 50+ wtq @ 3k rpm compared to a Cobb stage 1 CVT. But you can get a subtle "rumble"? Last edited by WRXnick16; 03-26-2020 at 02:06 PM. Reason: Added dyno charts |
03-26-2020, 12:26 PM | #23 |
Member#: 198281
03-26-2020, 02:09 PM | #24 |
Member#: 395275
RMIC
03-26-2020, 02:15 PM | #25 |
Member#: 460907
RMIC
Killer B didnt even put a graphic to show their tubing is WIDE!, clearly it's impossiblce for them to match Tomei's precision.
