Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2020
Old 06-16-2020, 10:59 AM   #1
Boost.and.freckles
Member#: 508405
Default Can i block this off? What is it exactly
https://drive.google.com/file/d/1skF...w?usp=drivesdk
The smaller of these goes to my aos. The larger connects to the other valve cover and I believe into the block. Can these be blocked off or rerouted or something. I'm trying to clean things up as much as possible.
Boost.and.freckles is offline   Reply With Quote
Old 06-17-2020, 04:54 PM   #2
pcampbell
Member#: 437670
2005 2.5 SC OB
You could block it off .
pcampbell is offline   Reply With Quote
Old 07-08-2020, 12:54 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
You could re-route but I would not block it off, those ports all work together to equalize pressures within the motor from what I understand.
TyranosaurusWRX is offline   Reply With Quote
Old 07-08-2020, 04:35 PM   #4
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
TMIC, FP blue, ELH
One port is the blow-by to the PVC circuit. Other port is the crankcase pressure balance circuit between the cyl heads. You could block off the balance circuit but I would not recommend doing so. You are clearly turbocharged and would need both of those on each cyl head.
Old 07-08-2020, 08:27 PM   #5
pcampbell
Member#: 437670
2005 2.5 SC OB
Most na/t builds just have 1 breather on each valve cover and 1 on the block (stock pcv location).
Turbo pcv setup for the block breather and then T them all together to pull in before the turbo.
Old 07-08-2020, 08:44 PM   #6
Aristocrat Autosport
NASIOC Storefront Vendor
Member#: 384404
MANY WRX, STI, 997TT
wrb
that would be correct for most NA/T builds, but this looks to be either a swap/ na/t with turbo heads and valve covers and not an NA valve cover.
Aristocrat Autosport is offline   Reply With Quote
