Welcome to the North American Subaru Impreza Owners Club Sunday June 13, 2021
Old 06-02-2020, 02:43 PM   #1
shadowcompany
Member#: 189394
9994 Impreza LSX STi
AWD
Default The AWD LSX STi
Note: Do not attempt this swap and expect to lower the engine using factory suspension mounting points. The only way to "lower" the engine is to do a body lift. Inspect and understand how and why Subaru achieved this on the Forester. If this does not make sense, then you will negatively impact handling by attempting to "lower" the engine and transmission.
There are multiple reasons I made no attempt to move the engine relative to the original design.
shadowcompany is offline   Reply With Quote
Old 06-03-2020, 02:02 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Please let us know when you get the corner weights for that thing
Definitely shoe-horned that in there.
Old 06-03-2020, 03:35 PM   #3
shadowcompany
Member#: 189394
AWD
I can only tell you the car weighs less, makes more average power, and continues to climb in peak power past 7,000 rpm.
Most parts on the car are universal. It still uses an STi style clutch.
Old 06-03-2020, 05:28 PM   #4
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Would I be correct in assuming this is built for drag?
Turpid Porpoise is offline   Reply With Quote
Old 06-04-2020, 10:21 AM   #5
shadowcompany
Member#: 189394
AWD
No, this still uses the STi 6MT in the stock location/angle.
Old 06-04-2020, 12:22 PM   #6
Saabaru300
Member#: 334105
2005 WRX Wagon
Ver8 EJ207, 6MT, Red
Well it definitely isn't meant for handling anymore. Slightly higher center of gravity and all that weight even farther ahead of the front axle's. Cool that you are keeping AWD.
Saabaru300 is offline   Reply With Quote
Old 06-04-2020, 02:12 PM   #7
shadowcompany
Member#: 189394
AWD
It does push the design of the car, the stock front axles are set back relative to the fire wall.
EG33 swapped (they are about the same length as the LS with short pulleys) Impreza have been used in motorsport with success. EG33 is no longer a viable swap though and EZ30 suffers from the same issues as the EJ.
The AWD and steep angle of the driveline negates some of the downsides. Stock, Subaru understeer anyway.
There is not a big difference in weight between the EJ in turbo trim and the LS in this car.
Old 06-04-2020, 09:43 PM   #8
Homemade WRX
Member#: 33782
96 3MI Racing
I dig it. Should be fun.
Old 06-06-2020, 04:39 AM   #9
PseudoKirby
Member#: 203835
1998 2.5RS
the LS is over 450lbs
I weighed my fully dressed EJ207 at 303lbs
PseudoKirby is offline   Reply With Quote
Old 06-06-2020, 12:42 PM   #10
shadowcompany
Member#: 189394
AWD
**Edit: Post #22 for actual weights
Depends what you are weighing. Aluminum based LS blocks are ~100 lbs lighter than an iron block. Components such as alternator, P/S pump, water pump, intake/exhaust manifolds, intercooler, turbocharger, clutch, and flywheel can change the weight.
LS aluminum long block dressed can weigh from 425-500+ lbs with GM parts,
LS aluminum block dressed with aftermarket parts (crank pulley, oil pan, alternator, water pump, etc.) can weigh 385-425 lbs.
LS aluminum long block weighs ~350lbs with oil pan but no accessories Correction It actually weighs 310lbs with a Sikky oil pan and crank pulley and less than 350lbs with a subaru clutch/flywheel assembly
LS aluminum short block weighs ~250lbs and that includes the cam and timing chain.
By comparison:
EJ257 DAVCS
Subaru turbo long block dressed with mid frame turbo and EWG ~350+ lbs
Subaru turbo long block dressed, stock ~325 lbs
Subaru turbo long block ~210 lbs
Subaru short block ~100 lbs
For reference a group 35 battery is 35-40lbs and a GTX3076R is ~30lbs. A front mount intercooler and pipes is roughly ~40-50lbs, stock bumper support on JDM cars is 12 lbs.
That is not a big difference when you double the amount of cylinders and more than double or triple the displacement, while keeping the whole Subaru AWD.
The EJ engine is very light in SOHC (1.8-2.5L) naturally aspirated versions, ~200-225 lbs fully dressed. The LS comes with very bulky accessories from GM but many aftermarket parts are available that considerably drop weight.
Last edited by shadowcompany; 12-17-2020 at 02:00 PM. Reason: Correction on weight
Old 06-14-2020, 12:30 AM   #11
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
Shut up & TAKE MY $$
sense of nature is offline   Reply With Quote
Old 07-03-2020, 04:49 PM   #12
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
WhiteZombie is offline   Reply With Quote
Old 07-03-2020, 09:48 PM   #13
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Please tell me that you aren't running a carb and coil-on plug...
Old 07-03-2020, 10:32 PM   #14
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Depends what you are weighing. Aluminum based LS blocks are ~100 lbs less than iron block. Components such as alternator, P/S pump, water pump, intake/exhaust manifolds, intercooler, turbocharger, clutch, and flywheel can change the weight.
By comparison:
EJ257 DAVCS
So how much does YOUR completely dressed LS weigh?
Cool deal keeping the 6mt and awd.
Nice crank damper.
The torque curve has to be fun, no turbo lag.
Not "hating" on the swap, just don't act like you're improving on anything other than parts availability. I live in the south where LS engines are all over the place, and yes they do break in stock form. They have their quirks as well.
Old 07-03-2020, 11:06 PM   #15
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Sweet Christmas, sound clips please!!
JDMJNKY is offline   Reply With Quote
Old 07-05-2020, 02:23 PM   #16
PseudoKirby
Member#: 203835
1998 2.5RS
sorry mate I dont do random numbers from the internet
heres proof in the form of me personally weighing my V7 EJ207 fully dressed with flywheel
https://imgur.com/0CVJCXx
333
and here is someone elses proof in the form of an LS1 on a scale
https://imgur.com/q2eja6p
471 with no exhaust manifolds
Old 07-05-2020, 05:15 PM   #17
hi5.0
Member#: 340456
2013 Impreza
With more weight past the front wheels and higher up, this thing looks to be Audi-like with the power and handling characteristics when driven to the higher n/10ths. Just hope not of the iron block F/R longitudinal I5 variety. That being said, amazing job cramming that engine in there.
hi5.0 is offline   Reply With Quote
Old 07-12-2020, 06:40 PM   #18
Fino
Member#: 417685
'03 V7 STi, 4.44
Sonic Yellow
Just curious, why is an EG33 swap no longer viable? They can still be found for pretty cheap and can handle a good amount of power stock. Pretty much a direct bolt in as well. I was going to go with one of them if my EJ207 ever failed.
Fino is offline   Reply With Quote
Old 07-19-2020, 12:13 AM   #19
shadowcompany
Member#: 189394
AWD
Its a short runner EFI intake manifold called single plane that can use a 4 barrel throttle body, the manifold has fuel injectors and rails. Identical ones are made without injector holes for carb applications. It is just another style of intake.
Carb and coil on plug has its places. You can run more ignition timing and higher intake air temp.
Soon.....
Nice crank damper.
Will have specific numbers when car is finished.
What you can get away with on LS engines is surprising. Cost, power, weight and reliability is the reason it is a common engine swap.
333
By comparison:
EJ257 DAVCS
I agree don't do random numbers. Don't forget the intercooler.
Weight difference between bare long blocks is ~140lbs but that is not a comparison. Apparently its less than I thought.
Thank you. The Audi is similar but their v8 is more compact. Still LS swaps do happen with AWD in audi cars.
It was an option but Subaru no longer produces new blocks or crankshafts for the EG33. There is a limited amount of these engines left and that means either expensive or poor condition.
The EZ30 is cheap and more readily available. Either H6 also require a rework of the exhaust, cooling, and electronics but you don't have to cut the hood or use a transmission adapter. You are limited to motor mounts from an H6 though.
Old 07-29-2020, 12:02 AM   #20
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Good to hear it's EFI. I just have a thing against Carbs.
Old 10-12-2020, 12:04 AM   #21
Myhkael11
Member#: 519317
Coming soon.
Holy crap i would love to drive that thing
Myhkael11 is offline   Reply With Quote
Old 12-17-2020, 12:18 PM   #22
shadowcompany
Member#: 189394
AWD
Long block with oil pan and crank pulley
+clutch/flywheel assembly
Lift Plate
Intake Manifold
Snow "testing"
Old 12-17-2020, 01:26 PM   #23
Absoluteyeti
Member#: 519596
97 Impreza OBS
Red to be white
Thanks for taking the time to weight everything! I've always been curious what the approximate weight was for other projects I've thought of.
Absoluteyeti is offline   Reply With Quote
Old 12-19-2020, 02:08 AM   #24
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
WOW just WOW
Work of art
Im perplexed about motor mounts
Particularly on R side with all that piping and oil pan
Subframe?
I see the Toy Jet coolant collector (I guessing that is part name) with coolant hoses
Where is the cooling part......the radiator cooling fins....I mean
Trophy truck style?
Old 12-19-2020, 09:06 AM   #25
shadowcompany
Member#: 189394
AWD
Mockup of motor mounts, engine mounting, oil pan
The radiator will eventually make it's way to the trunk. I need the space for an intercooler.
