Welcome to the North American Subaru Impreza Owners Club Friday May 7, 2021
Old 05-30-2020, 03:11 AM   #1
ben_7
Member#: 464522
2020 Subaru WRX STi
Default 2020 STi with 19x9.5 +35 wheels
Hi,
Iím thinking of getting 19x9.5 +35 wheels for my STi because I love the ďpokeĒ look of the wider wheels without using spacers.
If anyone has this setup, I was wondering if these wheels would clear the STiís six-piston front calipers with the wider wheel width and +35 offset?
Would it degrade performance and handling with the wider wheels?
Also, will the standard 245/35 19Ē Yokohama tires fit or would I need 255 or 275 tires?
ben_7 is offline   Reply With Quote
Old 06-02-2020, 09:44 PM   #2
SHOWMECW
Member#: 287861
2011 WRX Limited
Satin White
Interested in this as well.
SHOWMECW is offline   Reply With Quote
Old 06-04-2020, 09:51 AM   #3
Mach V Dan
Member#: 12029
You can't know whether the wheels clear based only on width and offset. The spoke design dictates caliper clearance. Some wheels will fit. Others will not.
No.
Also, will the standard 245/35 19Ē Yokohama tires fit...
Those will be pretty stretched on a 9.5" wheel, and you'll definitely be exposing the outer lip to damage from curbs and road debris. But the tires will fit on.
... or would I need 255 or 275 tires?
We run a 265/30R19 on our car using a +40 wheel, but I'm afraid they'll run into the fenders at +35. A 275 would make that problem worse. I'd do a 255 at the widest given your low +35 offset.
265/30R19 on 19x9.5" +40 Rota Kestrel:
Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 06-05-2020, 03:50 AM   #4
ben_7
Member#: 464522
2020 Subaru WRX STi
Thanks for the reply.
Will a set of XXR 527 or 530 19 x 8.75 +35 or +38 wheels clear the STiís six piston calipers?
Can I use the stock Yokohama tires on the XXR wheels?
Also, I plan to lower my car about an inch or and inch and a half on Tein coilovers, so would I need to roll my fenders if I went with the XXR wheels?
