04-24-2020, 08:15 PM | #1 |
Member#: 513611
Vehicle:2011 WRX Impreza Dark Gray Metallic |
Noises when backing up
I’m hearing a loud noise only when backing up is it because of the straight cut gears in reverse?
Also when I’m slowing down in first gear it almost sounds like compression surge and I right?
04-26-2020, 02:40 AM | #2 |
Member#: 514120
Hhmmm...
I have the exact same thing going on.. when pulling out of my driveway or in, and maneuvering through a parking lot sounds like my back end is falling off.. I just made a thread on here for it. 2006 sti, and 90k miles only when under like 15mph.. if I am turning a corner in 2nd, or neutral you won’t even hear it ?
04-26-2020, 03:05 AM | #3 |
Member#: 513611
HA not 25 min ago I read your thread. I think my noise or more or less a whirring I’m not quite sure how to 100% describe the noise. But I’m positive it’s coming from the transmission and only in reverse and gets louder the higher the rpms in reverse are. It doesn’t give me problems I was just curious as to what it was. And for my other noise it sounds like the turbo spooling up... or well down because I’m decelerating?
05-05-2020, 08:37 PM | #4 |
Member#: 406834
Yes, reverse whines due to the straight-cut gears.
