Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 08-05-2020, 05:43 PM   #1
TougeRenner
Member#: 138762
10 Forester
Dad mobile
Default Looking for someone to talk to about BAR Engine change/swap process.
Hi,
I am looking to talk to someone about the BAR engine change/swap process.
I can read, I can search and I generally understand what is required but the questions I have are more... nuanced
The two main questions are to in the two model years that I am looking at for my "change/swap candidate" there was not manual transmission option.
If I show up to the Ref swap completed with all related smog equipment from the "donor", but with a manual transmission is that going to be an fail automatically? Or am I going to have to make it automatic to get a BAR sticker then swap to manual later.
If the manual trans is not already an automatic fail, if I show up to the Ref with a manual transmission and all the Auto Trans trouble codes in the ROM permanently disabled, is that an fail even if the OBD readiness monitors for smog check are on(OK).
TougeRenner is offline   Reply With Quote
Old 08-06-2020, 11:19 PM   #2
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
If you believe everything here then the answer is any modification of the stock ECU is a no-no. Otherwise that's all I got. It was much easier in the old days when the trans had a separate TCU.
NutBucket is offline   Reply With Quote
Old 08-06-2020, 11:39 PM   #3
murrdogg24
Member#: 50586
64 Impala
If you have to ask the question, I think you already know the answer...
Edit: So glad I don't live in CA anymore
murrdogg24 is offline   Reply With Quote
Old 08-08-2020, 12:52 AM   #4
Shinji N
Member#: 3987
1998 2.5RS
https://www.bar.ca.gov/pdf/Smog_Chec...ence_Guide.pdf
Adding a link for reference
It's impossible to answer your question without specifics.
non-OBD2 car receiving OBD2 engine
The transmission and evaporative systems will be allowed to remain in the
recipient vehicle configuration, but must function appropriately
OBD2 receiving OBD2 engine
All emission system configurations must be in the original emission control
system configuration as the donor vehicle, including, but not limited to, the
transmission, evaporative system, exhaust, and intake
For your second question, I had to have a dealer generate a checksum and certify that my ECU was not modified. The Ref used that checksum when the checked my ECU to verify that it was unmodified. If disabling those codes modifies the checksum, I bet they would fail you.
Any reason you've picked an automatic only engine? I'm guessing you're going with a 6 cylinder?
Shinji N is offline   Reply With Quote
Old 08-08-2020, 01:15 AM   #5
TougeRenner
Member#: 138762
10 Forester
Dad mobile
Thanks, I've read through that and nothing popped out at me.
Truth be told it's not a Subaru, although I've tossed around H6 swapping my 2010 forester, but I know that this community has had successful BAR swap inspections.
My swap is OBD2 to OBD2. I am considering to attempt a 2000/01 Ford Explorer 5.0L(...not the coyote) into a 2000 ford ranger. It is 99% plug and play, however the expo 5.0 were auto only, and the 5.0L manuals in the F150 disappeared long before 2000. From my research my if I don't connect an auto to the ecu loaded with the 2000/01 expo 5.0 rom it will pop some transmission codes. Seems some in "free states" just flash to different map or just delete the codes on the Expo rom with the use of like a accessport device with a accesstuner race like level of editing.
I was not expecting someone to talk openly about what I was asking about in a thread like this but you never know.
Edit: ...Auto, then manual from the sounds of it...
Old 08-08-2020, 06:47 PM   #6
subaru_gc8
Member#: 29292
2004 WRX wagon
you can always call the ref and ask them
Old 09-18-2020, 11:47 PM   #7
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
Vehicle engine/transmission has to be either the same model year or newer. If you have a 2000 ford ranger and you swap a 2009 ford ranger engine/trans it will pass BAR/REF inspection.
This was still valid back in 08 when I was in the process doing my swap. Call the BAR and ask them, I was on the phone with them almost every other week making sure that my car would pass.
Good luck.
HighRevimpreza is offline   Reply With Quote
