05-29-2020, 01:01 PM | #1 |
Member#: 414056
New Fuel Pressure Regulator Problem?
I installed a Tomei Type-S FPR on my 2002 wrx with the stock fuel rails. I have the adjustment screw backed all the way out on the FPR and cannot get the pressure lower than 4 kg/cm2 (this is what the gauge reads) or 57psi. When I attach the vacuum source it will go down to about 3.5 kg/cm2 or 50psi. Is this okay? I know a custom tune will be in order for these pressures, but if I could get the pressure to the stock 43.5 I would be happier.
05-30-2020, 06:30 PM | #2 |
Member#: 414056
Today I removed the return line and put it straight from the regulator into a gas can to see if there was a return line restriction. Sane pressures. Any help?
05-31-2020, 09:49 PM | #3 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
maybe the diaphram?
05-31-2020, 09:51 PM | #4 |
Member#: 414056
Turns out I bought a knock off on accident. Getting a real one on the way and will see what results I get.
06-01-2020, 11:30 AM | #5 |
Member#: 29292
SCIC
06-06-2020, 05:44 PM | #6 |
Member#: 514969
TXIC
Vehicle:2005 WRX Aspen White |
Have you gotten the new / real regulator? If so have you fixed your problem?
06-06-2020, 05:45 PM | #7 |
Member#: 414056
Yes, with the genuine regulator I was able to set proper fuel pressure.
06-06-2020, 10:18 PM | #8 |
Member#: 514969
TXIC
