04-06-2020, 09:18 AM | #1 |
Member#: 97147
NESIC
Vehicle:2012 wrx gray |
TGV delete install help
Anyone in the Brattleboro/Greenfield area willing to help an old guy with a bad back, do a TGV delete.on an 06 engine? Doc says I need surgery, but won't be able to until this virus dies down. Normally I would tackle this myself, but a helping hand would make it a lot easier and quicker. I would be very grateful for any help.
PM me if interested Thanks
04-15-2020, 09:40 AM | #2 |
Member#: 97147
NESIC
Still looking for help.
05-17-2020, 02:18 PM | #3 |
Member#: 260314
NESIC
Vehicle:2007 STI silver gray metallic |
Have you posted on any Facebook Groups? Type in Subaru. All kinds of options.
Sorry I can't come up and help. I'm 74 and can barely do it myself. |
06-02-2020, 11:25 AM | #4 |
Member#: 97147
NESIC
Tried facebook but kind of got nowhere. I must be too old. Anyway, I did the TGV delete and injectors and now the car will barely start. I've loaded a new MAP and can occasionally get the car to start by holding the pedal to the floor. Won't hold an idle. I really could use some expert help with some hands on troubleshooting. I'm thinking there might be an air leak somewhere, but I can't keep the car running and check the engine at the same time. No codes are showing on my AP. I've changed plugs and upstream o2 sensor. Wish I hadn't started this project, but I'm stuck now.
06-02-2020, 11:58 AM | #5 |
Member#: 450713
Vehicle:2017 WRX Stage 3ish world rally blue |
take the tgv back off and check to make sure o rings are seated correctly
06-02-2020, 12:12 PM | #6 |
Member#: 97147
NESIC
No o rings on 06, just a gasket as far as I can tell.
06-02-2020, 03:13 PM | #7 |
Member#: 97147
NESIC
More information, I just pulled the plugs, coils, and fuel pump fuse. When cranking I'm not seeing a spark at the 2 rear plugs (black connectors). I swapped the coils front to rear and got the same results, so it seems the coils are working but the harness isn't. Seems odd both sides could have an issue. Any thoughts before I pull the manifold and harness out? I probably should first check if the connectors are getting power and check for ground. Anyone know which wires are positive and negative?
