03-29-2020, 12:35 PM | #1 |
Member#: 279525
Vehicle:06 Fxt |
Inline fuel filter; still need fuel dampers?
2006 forester xt. Swapped in ej257; vf48
Hello all, i noticed last week while replacing a worn out walbro fuel pump with an AEM one that there was absolutely no fuel filter in the fuel pump housing. None in the engine bay either. So since i purchased my car 2 years ago and 30k miles later, no fuel filter. I have not had/ suffered any adverse affects as of yet. Car pulls hard, no misfire etc. Im going to be purchasing an inline fuel filter, sorta like the ones the Golan products or Fuellab offer. In the engine bay, both on the incoming and return fuel lines there are oem fuel dampers (the round black thing). If i install the inline fuel filter, should i just not use the fuel damper on the incoming fuel line where the fuel filter will go? Or stick with the fuel damper and fuel filter all in one line? Please advise thanks.
03-29-2020, 12:55 PM | #2 |
Member#: 78389
NESIC
Vehicle:06 Spec-b tsm |
The filter is the screen or sock attached at the bottom of the pump housing. That's all Subaru has used since they did away with inline filters in most models around 2003
03-29-2020, 01:13 PM | #3 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
The oem filter on the newer models is between the pump output and the fuel hanger fitting. The pump inlet sock on bottom is only for larger particles, to keep the pump from being damaged. Definitely make sure you use a filter on the output side...either right after the pump or in the engine compartment. The injectors have internal screens, but those will only last so long before being clogged. I would leave the dampers.
This is the style that was used up to 2007/8 https://www.ebay.com/itm/OEM-2002-20...UAAOSweqJbKWVy |
03-29-2020, 05:24 PM | #4 |
Member#: 279525
Vehicle:06 Fxt |
The sock on the fuel pump housing just filter out big items i believe 30 microns or more, from entering fuel pump and damaging it. Thats not a fuel filter per se.
03-30-2020, 01:16 AM | #5 | |
Member#: 108051
AKIC
Vehicle:2005 WRX STi WRB |
03-30-2020, 09:25 AM | #6 |
Member#: 409332
Vehicle:2005 LGT ABP |
I'd keep the pulse dampers if at all possible. The car will run without them and may even feel fine, but your fuel system will get noisier. The real question is how bad the resonances get and if it's enough to impact AFR. I had leanout issues on account of pulse dampers and a nasty fuel system resonance, but that was with big injectors in OEM rails so YMMV.
03-30-2020, 05:46 PM | #7 |
Member#: 279525
Vehicle:06 Fxt |
^^if its just a matter of reducing noise then I'll get rid of them.
03-31-2020, 02:01 PM | #8 |
Member#: 108051
AKIC
The dampers are there to dampen the pressure waves when the injectors open and close. The fpr and filter alone act as a damper. They're only there because the filter is in the tank and not in the engine bay. Like on an older wrx.
03-31-2020, 06:51 PM | #9 |
Member#: 90539
South East
04-01-2020, 01:06 PM | #10 |
Member#: 279525
Vehicle:06 Fxt |
Ok, if the in line fuel filter (besides filtering) acts as a damper then ill go that route, end the redundancy and not use the fuel damper when i add the filter.
04-01-2020, 01:54 PM | #11 |
Member#: 108051
AKIC
05-28-2020, 06:47 AM | #12 |
Member#: 279525
Vehicle:06 Fxt |
05-28-2020, 11:07 AM | #13 |
Member#: 515162
finally I found a forum where a lot of useful information
06-04-2020, 11:59 PM | #14 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
I have a 05 FXT converted to inline fuel filter, removed dampers on the engine bay side. No issues for the past 8 years.
