Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 03-25-2016, 02:51 PM   #26
Tgui
Member#: 44771
Originally Posted by Matt K View Post
so what did the 4l80e swap cost, aside from the tranny itself? Looks like xmember, flexplate, TC? Wiring? Anything else? Custom driveshaft?
I have a '95 silverado tbi 350 with 196k miles on it with a 4l60e. It shifts remarkably well given its age, but when it goes I'd like to 4l80e it if it's not prohibitively expensive.
I got my 80e for $400 and probably would have worked fine without the rebuild.
xmember, your GMT400 is easier. Drill new holes in frame and push xmember back.
TC/flexplate, maybe. I had a 4l80e in my 93 truck from the factory with the same 350 TBI. I'm thinking a stock 80e might just bolt up for you. I had to do all that because of LS engine differences.
If yours is a 4x4, you need a diff size input in the xfer case to fit the larger diameter output of the 80e.
Tgui is offline   Reply With Quote
Old 03-25-2016, 03:01 PM   #27
VpointVick
Member#: 93193
'03 325iT
Mysticblau
'03 325i touring (wagon).
As it sat last summer.
Bought this time last year and have been taking care of minor things to make it more up to date, like putting in a Dynavin N6 head unit/nav, and cleaned up for DD duties, replaced front seats burned up in it's former life in the AZ sun and replaced grilles and headlight lenses putting in some angel eyes while I was there.
Next up, wheels and tires and an M Tech II body kit to make it look like less of a grocery getter. Will look a lot like this for a while -
Next step will be buying salvage M3 and performing an engine, trans, and suspension swap doubling my horsepower and getting rid of the autotragic, then the final phase will be welding the flared M quarter panels on and mating the M's flared fenders to the wagon fenders so that the M front sheetmetal will fit, full repaint in the original Mysticblau, and possibly an interior color swap as I think the black/Imola red combo would look a lot sportier than the current beige.
VpointVick is offline   Reply With Quote
Old 03-25-2016, 03:05 PM   #28
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Reading Vpoints post is like reading an erotic novel.
50 shades of Mysticblau
Old 03-25-2016, 03:10 PM   #29
Matt K
Member#: 45204
16 you don't
respond to danger
my truck is 2wd so I think i just need to adapt the driveshaft. Sounds pretty straightforward.
Matt K is offline   Reply With Quote
Old 03-25-2016, 03:11 PM   #30
VpointVick
Member#: 93193
'03 325iT
Mysticblau
When I started planning the project I'd planned on going Laguna Seca blau when it came time to respray, but this blue is hot.
Old 03-25-2016, 03:17 PM   #31
Tgui
Member#: 44771
It looks great as is.
Old 03-25-2016, 03:21 PM   #32
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
I had a 74 BMW 2002 that I got form an Uncle after it sat neglected for 10 years, got it running. Sold it and bought my Datsun.
1964 Datsun 1500
Got it delivered in September and drove it as is until I had to put it away for the winter. Over the winter I have removed the push bar thing on the front bumper, replaced the leaky and hacked up exhaust manifold. As soon as it is warm it is off to the shop to get a exhaust fabed up and carbs tuned.
1972 Vespa Small frame 90cc
Was bought new by my Aunt, I was given it in pieces. I had someone reassemble as small engines scare me. powder coated all the tan pieces, converted from 6v to 12v. Original crank and housing. Fun and scary to ride at the same time. Max speed is 42 down hill with the wind at your back.
car_cursed is offline   Reply With Quote
Old 03-25-2016, 03:21 PM   #33
Tgui
Member#: 44771
Originally Posted by lemming View Post
My main project right now is my old 2003 Fr0d Rustang. It's actually at a shop right now because I need someone to fabricate the hot side of a turbo system for it.
Over the last few months, I pulled out the 4.2L turbo V6 I was using, as well as the transmission. I installed a GM LQ4 (6.0L iron block truck V8, similar to LS1) and played around with different accessory and manifold combinations until I figured out what would give me optimal clearance, did bit of a hack wiring job to get the GM ECU working for now (although I may eventually go standalone) and got the transmission mounted.
When this is finished, I'm going to be using a custom built longblock based on the LQ4, but with forged pistons, forged rods, better heads, a wilder cam, and better fasteners throughout. I am going to use a Tremec T56 Magnum as a transmission, and it's looking like my best option for a turbocharger is a Turbonetics 7875 ball-bearing unit. The goal is to hit at least 6-700 wheel horsepower.
I'm stupid enough to do this because I like the car. I've had it since it was new, and it's still in decent shape cosmetically. It has very extensive suspension modifications, halfway decent brakes, and a Torsen diff.
Inactive projects:
I did a bunch of suspension crap to my 2013 Mustang GT and then stuck a supercharger on it.
My Forester has a bunch of STi stuff in it, has all the body lift stuff removed, and is actually somewhat enjoyable to drive now.
This is amazing btw. Wow.
I'm shooting for shy of 600hp. Its a big floaty SUV, cant get too stupid!
Old 03-25-2016, 03:23 PM   #34
Benhart21
Member#: 149617
Current projects are:
1995 Camaro Z28 currently undergoing a 383 stroker swap after the head gaskets gave up and a pushrod decided to pop out from under the rocker and went down into the block. The new 383 is in, backed by a built 4L60E after the car torched the stock and two remans. I've just need to plumb all the lines and figure out how I want to tackle the stupid Opti-spark.
1984 VW Vanagon that needs a transmission/shift linkage overhaul, new carpets, seat covers and an exterior respray. My dad bought it almost 30 years ago and gave it to me when he decided to downsize. Holding on to it for sentimental value.
2000 4Runner that I'm using as my DD. Currently lifted, bigger tires, skid plates, rock sliders, and in the process of adding extra LED lighting. I should be done messing with this thing after I add some projector retrofitted headlights, steel plate bumpers with a rear tire carrier, and possibly the TRD supercharger.
I'd like to add another motorcycle to the stable since I regret selling my CBR 600RR a couple years ago, but other things have priority.
Benhart21 is offline   Reply With Quote
Old 03-25-2016, 03:25 PM   #35
Tgui
Member#: 44771
4l60e, you do a beast sunshell and all that?
Old 03-25-2016, 03:37 PM   #36
BEN04WRX
Member#: 249658
2013 WRX hatch
Oh wow car_cursed love that '64 1500. great buy sir!
BEN04WRX is offline   Reply With Quote
Old 03-25-2016, 03:40 PM   #37
Fish
RIP Sirkbac
Member#: 869
1984 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
I still have my tarp covered 1990 engine swapped (1.8L) miata..
thinking of just dropping it off at a Miata specialist, with a short list of things to address. writing a check and getting my miata back rather than buying some commuter car to get my STi out of the commuter role.
I just don't have time/motivation to troubleshoot the issues with it anymore.. but I kinda want it back
Fish is online now   Reply With Quote
Old 03-25-2016, 04:04 PM   #38
Benhart21
Member#: 149617
Pretty much. It's the Performabuilt Pro Street 4L60E that supposedly has a custom sun shell of theirs in it, but it looks just like the beast. It was holding up well before the motor gave out, and it's supposedly good to 500whp.
Old 03-25-2016, 04:53 PM   #39
02fastWRBLUE
Member#: 52590
Switched from cars to bikes a couple years ago-
Sold: 2008 STi Stage 2+ (fun DD until the piston rings went)
2001 Honda S2000---2.4L-Turbo 510whp/400TQ on low boost (15psi) pump gas tune +105ishWHP for every 5PSI above that. Car was immensely fun, but I had nightmares of needing new trans/diff/axles/etc. every few years. Ran on all season tires all year round, just because they were cheaper to replace than drivetrain components.
1987 Honda Civic SI----100K miles, stock, fun, original. clean. sold it for double what I paid for it.
And no pics on photobucket, but I'm currently rebuilding a 1981 Honda CB750 and ride my 2014 Honda Grom like it's my job.
02fastWRBLUE is offline   Reply With Quote
Old 03-25-2016, 05:11 PM   #40
Hondaslayer
Member#: 4562
2005 Adventure van
Somebody missed the point
Talks about what he had, barely mentions what he's working on.
Old 03-25-2016, 05:12 PM   #41
tobylazur
Member#: 150289
2006 SV650, 05 CTSV
1972 Travelall
It was suppose to be this:
But, after having a baby and buying a house within 6 months of each other, it's been put on the back burner. I don't have the money or the time to put into it right now.
It needs to be rewired, as it's a patch work of splices, needs painted, needs a new head liner and window/door seals, and needs a few gaskets on the engine and trans that seep and occasionally drip. I'm waiting for either a decent 4x4 frame to pop up, or a full truck that I can swap my good parts over to. It could also really use a 4 speed trans.
Here's how it sits now:
Mainly just try to keep it running and driving as best I can for right now. It's having an issue getting fuel at the moment.
tobylazur is offline   Reply With Quote
Old 03-25-2016, 05:15 PM   #42
Benhart21
Member#: 149617
Dug up a few pics of mine.
Old 03-25-2016, 05:17 PM   #43
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I'm just as surprised and titillated.
Way, way harder than expected.
We're one 70s Firebird away from full on North Florida rednecking.
OrbitalEllipses is offline   Reply With Quote
Old 03-25-2016, 05:31 PM   #44
lemming
Member#: 250066
'06 Forester XT
'03 Rustang LQ4 Turbo
The problem is that I keep leapfrogging myself. I turbocharged the V6, made ~400-450 whp. Bought the GT mostly-stock with 50K on the odometer, and it felt slow in comparison, so I stuck a Roots blower on it. V6 car felt slow again, so now I'm trying to get a little more power than the GT (although I should find it easier to "pedal" it with the turbo).
I don't even have a use for any of this. At this point, I am just doing it because I can.
lemming is offline   Reply With Quote
Old 03-25-2016, 09:14 PM   #45
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
Yes sir!
The 4l80e is needed as a 4l60e will grenade behind lots of TQ in a heavy truck. It took some rewiring and ECU hacking to get it to work.
Pffff.. A 4l60e will grenade cruising at 55 in an empty truck
Calebz is offline   Reply With Quote
Old 03-25-2016, 09:31 PM   #46
Obnoxio
Member#: 44009
2001 Toyota Tundra
red/bird poop
Same here.
Obnoxio is offline   Reply With Quote
Old 03-25-2016, 09:54 PM   #47
Smalls
Member#: 137028
1963 Impala.
She currently sits, with minimal work being done, until I can build a garage. 100% complete car. All of the chrome is there and in fantastic shape. The rust looks bad, but is very minimal. I don't know what I'm going to do with it yet. I couldn't let 25ft of Merican' steel go to waste.
Was part of a Widower's estate. They were going to junk what was left. A buddy and I scooped this up and the Cadillac. 4 doors for more whores.
Smalls is offline   Reply With Quote
Old 03-25-2016, 10:49 PM   #48
zombiekiller
Member#: 167010
The 66 Galaxie that I will finally get back to this year, after having it sit for 3 years.
The body is coming off of the chassis, onto a cart and off to the body shop while i sell the current running gear, rework the chassis and drop a coyote/6 spd in it. It's also getting c6 z06 brakes , coilovers and a watts link.
Just got this. In the midst of collecting parts for it. its getting some bits from the R version, long tubes/ exhaust, trans/dif coolers, full suspension treatment, r Spec forgelines, some dyno time and some other doodads.
zombiekiller is offline   Reply With Quote
Old 03-26-2016, 03:56 AM   #49
Ghostwhite
Member#: 254958
Dually, barely fits. Its messy
Ghostwhite is offline   Reply With Quote
Old 03-26-2016, 05:22 PM   #50
shiplemw
Member#: 203905
Love the Galaxy. What kind of engine and suspension for that dually?
shiplemw is online now   Reply With Quote
