05-05-2020, 08:26 PM | #326 | |
Member#: 30342
Although with Chicago, you probably have to go halfway to Iowa to get to MI with a load that size.
05-05-2020, 08:35 PM | #327 | |
Member#: 153174
SCIC
05-05-2020, 08:47 PM | #328 |
Member#: 66310
South East
Vehicle:2023 korean muscle |
05-06-2020, 10:40 PM | #329 | |
Member#: 5620
Waukesha/Dresser used to be in my backyard. i was disappoint not to see thunder pumpkin orange. it's now owned by GE last i checked. it's been a couple of years since i've been out that side of town so i don't even know if that facility is still running. |
05-08-2020, 11:50 PM | #330 |
Member#: 66310
South East
I may be spending 5 ish weeks running a 13 axle setup hauling windmill parts ( might be blades but im not sure honestly ) out of Menominee Mi to somewhere about 150 miles away.
Should pay decent money since i need to deadhead 1200 miles to Houston to grab a trailer, and then 1300 more miles up to Michigan. Then do the reverse on the way back. Its going to be 13 loads total i believe. |
05-08-2020, 11:53 PM | #331 |
Member#: 92634
RMIC
Cool. I see giant windmill parts on rail cars headed east from Denver now and then. They are just immense.
05-08-2020, 11:59 PM | #332 | |
Member#: 66310
South East
The job i might get likely came in through the erie canal to the port there in Michigan. We are currently doing a different 63 windmill job in OHIO. They are coming into the port near Gary IN and some are going on trucks and some are going on rail. They still need a truck at the end from the rail yard to the jobsite. One of the guys is getting $500 a day to move 63 loads about 5 miles from the rail yard to the jobsite. The ****ty part is there is nothing around there, the nearest truck stop is like 40 miles away. |
05-28-2020, 04:42 PM | #333 |
Member#: 92634
RMIC
https://www.thedrive.com/news/33645/...ad-land-trains
[see link for photos: getting 403 errors] https://www.youtube.com/watchv=S3Z8I4ZZDmM Serial hybrid design with hub motors. So cool. The Sno-buggy's wheels eventually were repurposed on Bigfoot IV and V after a stint in the junkyard. |
05-29-2020, 12:52 PM | #334 |
Member#: 92634
RMIC
Bunch of similar oversized rigs staged last night on I-70. Beams for a new overpass at Quebec St. |
05-31-2020, 05:51 PM | #335 |
Member#: 66310
South East
I was recently hauling a windmill drivetrain to a farm in Kenton OH.
150,000 lb piece that connects the blade hub to the generator. The one road was a little wet and I got stuck. It was my fault and I owned up to it. Apparently they made the road 16' wide and topped it with stone. All the pickup trucks would haul ass through the lake and it kept pushing the gravel further out. I saw that the right side looked higher and had less water. Well I made a bad choice to favor the right side, it was only some loose gravel from the pickup trucks pushing to to the side. Thankfully they had a bulldozer with a winch and I was only stuck for 20 minutes. The blades are roughly 200' long and had a lot of curve in them. I had no idea they were made like that. |
06-01-2020, 06:45 PM | #336 |
Member#: 153174
SCIC
Would have loved to see a video of you getting rescued by the dozer.
Speaking of dozers, do you haul heavy equipment? I recently saw a trailer on the side of the freeway with what looked like a dumptruck that had slipped off the deck, and wondered who is responsible for loading the equipment and what happens if there's an issue with the load during transport. I've seen automobile transport trailer drivers loading the cars at the local carmax, but I can't imagine the same thing applies for heavy equipment as it seems to be a specialty skill. But what do I know. |
06-01-2020, 07:10 PM | #337 | |
Member#: 66310
South East
Before the crane or whatever leaves you need to make sure everything is ok. If it gets ****ed up by the loading crew then they are on the hook. As soon as the loading crew leaves you are on your own. Anything that happens is on you. If the load shifts because of inadequate securement or anything that's on you. The only way you don't get ****ed is if you get into an accident that isn't your fault. |
06-01-2020, 08:20 PM | #338 |
Member#: 67942
International
Vehicle:The Other Land Down Under |
Someone's having a bad day.
We've had a couple of days of heavy rain. Assume he cut the corner and the wheels dug into the mud. https://www.stuff.co.nz/taranaki-dai...s-over-on-sh45 |
06-01-2020, 08:27 PM | #339 | |
Member#: 66310
South East
100% avoidable accident |
06-05-2020, 02:58 PM | #340 |
Member#: 92634
RMIC
06-05-2020, 11:41 PM | #341 |
Member#: 152718
South East
Vehicle:2019 GTI White |
06-06-2020, 12:44 PM | #342 | |||
Member#: 153174
SCIC
06-06-2020, 07:21 PM | #343 |
Member#: 66310
South East
I made it to Reno, they should be done with the trailer Tuesday night. I was hauling a felt liner for a new lining in a sewage line for the Reno waste treatment facility. They pull this liner through the old pipe, inject a resin, fill it with hot water and it essentially makes a new PVC like pipe liner inside an existing pipe.
I had 1600' feet of a felt tube liner. I'm hoping to find a backhaul for the way home. Would be nice to at least pay for my 2600 mile ride back at 5 ish mpg. |
06-06-2020, 08:05 PM | #344 |
Member#: 6030
Vehicle:04 Gold FXT 07 WRB FXT Sport |
Damn hkerekes you haul some giant loads. Good luck finding a backhaul for the way home!!
06-06-2020, 08:25 PM | #345 |
Member#: 66310
South East
If we have equipment that is backhaul friendly we have some help finding loads. With a backhaul I will get 90% of the load as payment. I'm also going to lose another 5% to the lady that finds us loads. She has a lot of contacts and access to load boards.
Hopefully I can make enough off the backhaul to pay for my entire fuel bill. I'm at a big disadvantage though since I'm so heavy. Normal trucks and stepdeck trailers can haul 48,000 easy. I'm gonna be pushing it with 35,000. |
06-07-2020, 06:13 PM | #346 |
Member#: 92634
RMIC
I’ve seen a bunch of work trucks this year (crew cab chassis cab with utility or flat beds) based off of Class 5 underpinnings, Ford F-550 and Ram 5500 the most common. F-450s also pretty common, but only spotted one Ram 4500 thus far.
Still waiting to see an example of the new F-600 in the flesh, though. /shikataganai random joy |
06-08-2020, 05:01 PM | #347 |
Member#: 92634
RMIC
https://www.thedrive.com/news/33935/...n-public-roads
Vid embedded there. A pleasant way to waste 6 minutes and change |
06-08-2020, 05:19 PM | #348 | |
Member#: 253189
South East
Vehicle:2016 SS Black |
Just curious. |
06-08-2020, 08:08 PM | #349 | |
Member#: 66310
South East
It may be net 90 I have no idea and it really doesn't matter, it's only gonna be a $1000 or 2 so whatever. |
06-08-2020, 08:14 PM | #350 | |
Member#: 66310
South East
Go slow and listen to the escorts is all you need to do. |
