Welcome to the North American Subaru Impreza Owners Club Monday July 13, 2020
Old 04-24-2020, 08:15 PM   #1
SlowWRX_Owner11
Member#: 513611
2011 WRX Impreza
Dark Gray Metallic
Default Noises when backing up
Iím hearing a loud noise only when backing up is it because of the straight cut gears in reverse?
Also when Iím slowing down in first gear it almost sounds like compression surge and I right?
SlowWRX_Owner11 is offline   Reply With Quote
Old 04-26-2020, 02:40 AM   #2
Hawkeye2006sti
Member#: 514120
Default Hhmmm...
I have the exact same thing going on.. when pulling out of my driveway or in, and maneuvering through a parking lot sounds like my back end is falling off.. I just made a thread on here for it. 2006 sti, and 90k miles only when under like 15mph.. if I am turning a corner in 2nd, or neutral you wonít even hear it ?
Hawkeye2006sti is offline   Reply With Quote
Old 04-26-2020, 03:05 AM   #3
SlowWRX_Owner11
Member#: 513611
2011 WRX Impreza
Dark Gray Metallic
HA not 25 min ago I read your thread. I think my noise or more or less a whirring Iím not quite sure how to 100% describe the noise. But Iím positive itís coming from the transmission and only in reverse and gets louder the higher the rpms in reverse are. It doesnít give me problems I was just curious as to what it was. And for my other noise it sounds like the turbo spooling up... or well down because Iím decelerating?
Old 05-05-2020, 08:37 PM   #4
Padawan
Member#: 406834
Yes, reverse whines due to the straight-cut gears.
Padawan is offline   Reply With Quote
