10-18-2019, 11:45 AM | #1 |
Member#: 507519
Car wont build boost
Hey guys subie newbie here I bought an 04 blob eye with this issue and cant sort it out.
Ok so car runs completely fine pre boost as soon as it gets into boost the car falls on its face and spit out black smoke it will hit about 3psi then shutters bad if I stay in the gas it will build to abput 7psi tons of work done recently plugs ngk copper gapped at .30,coilpacks, fuel pressure regulator, new turbo inlet, used td04, new downstream 02, new fuel filter, Mods list Perrin uppipe Cobb downpipe AEM intake Cobb ap v3 Cheap catback Aftermarket radiator Aftermarket turboinlet Tein lowering springs All new grimspeed couplers Grimspeed y pipe <back of intercooler> I'm really stumped on this any information is greatly appreciated thanks in advance |
10-18-2019, 01:14 PM | #2 |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
Check exhaust parts. Uppipe could be cracked. Turbo could be toast.
10-18-2019, 03:28 PM | #3 |
Member#: 507519
11-23-2019, 09:09 PM | #4 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
take the wastegate vaccum line off and see if it boosts. if it does, its your ebcs or something in that line, if it doesnt, than its mechanical and there is a leak somewhere. also did you change all the coil packs> did you use oem or aftermarket?
11-24-2019, 08:45 PM | #5 |
Member#: 132
Vehicle:GDA- D, GDA-A, VAG-A GDA-A - ShinjiTuned |
10-18-2019, 03:44 PM | #6 |
Member#: 67004
SCIC
But is the turbo spinning and have little work no play, when you installed it ?
10-18-2019, 04:01 PM | #7 |
Member#: 507519
10-19-2019, 01:08 AM | #8 |
Member#: 29292
SCIC
take the wastegate vacuum line off and see if it boosts okay, if it does, then you problemn is the ebcs.. make sure you dont over boost
10-19-2019, 08:18 AM | #9 |
Member#: 507519
10-19-2019, 08:14 PM | #10 |
Member#: 507519
Took vac line off wastegate gate same thing
11-29-2019, 05:22 PM | #11 |
Member#: 29292
SCIC
10-19-2019, 08:30 PM | #12 |
Member#: 67004
SCIC
Get a OEM replacement unless your going to do a tune with a 3 port. As the 3 post is not safe to boost on until they are tuned. I might have an OEM for an 02. Realize they are different for different years. The plug is different.
11-23-2019, 05:55 PM | #13 |
Member#: 452713
Vehicle:02 Impreza WRX Grey |
Could be wastegate. When I got my 02 I couldn’t boost more then 5psi and it would fall on its face at 4500rpm put a new turbo on and the issue was gone
12-03-2019, 11:55 AM | #14 |
Member#: 507853
having the same issue, patiently waiting for some more ideas! Good luck
