08-10-2006, 01:37 AM | #26 |
Member#: 114182
Vehicle:2003 toyota corolla RIP wrx, damn u bambi! |
At 65 mph, I was at 2700 RPMs roughly on my new Impreza WRX TR 5 speed.
02-06-2021, 04:05 PM | #27 | |
Member#: 510671
SCIC
Vehicle:2006 WRX Gray |
Good to know! I always thought the STi six speed had the sixth gear as a sort of overdrive gear. I am a bit of beginner here - what is the advantage of having more shorter gears as opposed to fewer taller gears ? |
02-07-2021, 08:31 PM | #28 | |
Member#: 395793
Vehicle:2005 92x Aero Beige |
In track use it will keep you in the power band with each shift. Longer gears may drop the RPMs too much and move you out of the efficiency range of the turbo when up shifting. This is road course type use. For 1/4 mile people prefer longer gears for less shifting. |
03 WRX 70 mph = 2750 RPM | Cautionjump | Transmission (AT/MT) & Driveline | 4 | 06-04-2007 11:12 AM |
Minimum RPM in 6th? | map34251 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 12-11-2005 03:17 PM |
05 STi fuel cut in 6th gear pulls | Timmy Burns | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 11-19-2005 04:48 PM |
What Speed @3900 RPM in 6th gear? | x Neo x | STi Forum Archive | 18 | 07-07-2003 08:16 AM |
