Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 02-11-2021, 04:06 PM   #1
GAMETIME2121
Member#: 520650
2007 Impreza WRX STi
Default Custom Turbo Relocation - Clocking Compressor Housing
Hey guys!
I'm brainstorming a custom rotated turbo build and I'm playing with some intercooler/inlet pipe routing options. I know there are plenty of bolt on kits that rotate aftermarket turbos but I'm pretty big on DIY and unique stuff.
I'm considering reusing my Blouch Dom 3.0R. Anyone know if the compressor housings on these bad boys are "clockable"? I know the position of the drain fittings is critical, but I'm trying to rotate the compressor housing only and keep the CHRA orientated vertically.
I've reached out to Blouch, but I haven't heard back yet.
GAMETIME2121 is offline   Reply With Quote
Old 02-15-2021, 05:32 PM   #2
T-37
Member#: 175624
0304 WRX WRX
SY WRB
If you're going to use the IWG, it doesn't look like it's clockable based on pics here http://www.bptstore.com/Subaru-WRXST...ger_p_135.html
The IWG bracket bolts to the compressor housing.
If you're EWG, then you could probably do it, but you'd probably need to weld the IWG or change housings if possible.
Old 02-16-2021, 12:52 AM   #3
GAMETIME2121
Member#: 520650
Good point. I have a Tial mvs 38 and ewg up pipe on the way (if this freaking storm would let up, that is) but I was planning to use a Wastegate bracket deal to hold the current IWG closed. Sounds like if I mess with the orientation of the compressor wheel, I'll need to find another solution to keeping the IWG closed.
I'm more interested in how the actual compressor housing is attached to the CHRA itself... I don't see a clamp or bolts holding it in its current position.
Old 02-16-2021, 06:28 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You'd be much happier with your results if you just used a Garrett with a Tial turbine housing. The OEM style IWG turbine housings rob a butt load of performance. If you're going to go EWG anyway, you might as well take full advantage of what it can offer, AND not have to deal with rigging up an IWG closer/bracket setup.
Old 02-16-2021, 11:50 AM   #5
T-37
Member#: 175624
0304 WRX WRX
SY WRB
IIRC Blouch use Garrett center sections on their BB turbos (or used to?). I think that was the case with my 16GXTR.
Edit: no idea if you could get a TiAL style hotside that would fit the turbine wheel though...
Old 02-17-2021, 08:42 AM   #6
GAMETIME2121
Member#: 520650
I figured there would be a pretty significant case for just switching turbos and saving the trouble. I guess I'll have to just pull the turbo and see what works. It sounds like I might be in the market for a more compatible turbo though...
