05-10-2019, 07:10 AM | #1 |
Member#: 476041
Vehicle:2014 WRX Black |
3076 gen 2
2014 WRX full STI drivetrain
Tuned by Johnson Tuning IAG stage 3 plus D25 heads with GSC valves / beehive spring Kelford 272 cams 625 head studs ID1300 Walbro 525 Visconti hanger I-wire fuel pump hardwire Cobb rails with -6 feed / return Garrett GTX3076r gen 2 BNM rotated hot parts Cobb fmic At this power the ID1300 were at 94% so power was pulled back to 585whp
05-10-2019, 09:34 AM | #2 |
Member#: 476573
Vehicle:2008 Impreza WRX STi Silver |
Those are pretty impressive numbers for a GTX3076. Which turbine housing were you using? Did you have to increase base fuel pressure so you didn't run out of injector to hit those numbers?
05-10-2019, 12:23 PM | #3 |
Member#: 163648
Vehicle:2002 WRX V9 6mt R180 Brembos |
The first graph is the wrong one. That's the same one you posted in the 6266 thread.
05-10-2019, 12:36 PM | #4 |
Member#: 476041
05-10-2019, 12:38 PM | #5 | |
Member#: 476041
Sorry first graph was the wrong one. 607 were the 3076 numbers . Using the Garrett .82 v-band |
05-11-2019, 12:01 AM | #6 |
Member#: 163648
05-11-2019, 05:44 AM | #7 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
Was that 485whp on straight pump gas?
What RPM do you get full boost at? I've been wondering about upgrading from my GT3076 to GTX3076 so I'm really curious about where the powerband starts with these turbos. |
05-11-2019, 05:44 AM | #8 |
Member#: 140444
NWIC
05-11-2019, 08:22 AM | #9 | |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
Op have you had a chance to take the car down the 1/4 mile? Curious about trap speeds seeing on mine was hitting those mid 90's idc's at the 500whp mark (stock base pressure) on a relatively similar set-up. |
05-11-2019, 05:49 PM | #10 |
Member#: 47143
Its exactly the same, my friend just upgraded only the turbo and tuned today, spool is basically identical on his setup.
05-11-2019, 09:00 PM | #11 |
Member#: 476041
3076 gen 2
That graph only shows the e85 pull but boost is coming in around 3800-4000rpm Base pressure is set at 50psi or 50 at FP differential, I don’t currently recall pressures under load. Have not had a chance to play with the car sadly, to busy on customer cars. The 485 pull was on 93, the 607 was on E60 as we did not drain the tank after the 93 runs. |
05-11-2019, 09:11 PM | #12 |
Member#: 163648
Looks good!
The gen 2 30r really throws down compared to the old 30r. |
05-14-2019, 09:22 AM | #13 |
Member#: 167468
TXIC
Vehicle:2004 STI White-ish |
That is a boatload of power. What boost and/or timing are you running on E85?
05-14-2019, 10:08 AM | #14 |
Member#: 420458
Vehicle:07 WRX STI Urban Grey |
That's some power from a 3076 and 1300cc injectors! Would be a weapon to drive with that fat torque curve! How much boost to make the 600?
05-14-2019, 11:23 PM | #15 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
Very nice, even on 93. I have the G2 3576r with S2 cams and 2kcc injectors, and am hoping for similar numbers. Hopefully my spool isn't much later without avcs.
05-15-2019, 08:48 AM | #16 |
Member#: 476041
11-05-2020, 12:37 PM | #17 |
Member#: 339923
Vehicle:2006 Impreza WRX STi grey |
damn this looks like it would be a perfect setup for my car (trackcross/street/ sometimes autocross)
beautiful car man |
11-07-2020, 04:19 PM | #18 | |
Member#: 140444
NWIC
Full boost at 4k would be fine, that's what I get now. Part of me thinks that I should go smaller though, like a 3071, and try to get slightly better spool and slightly more power. I'm actually pretty content with the power I have now, and like you said the gtX3076gen2 is a pretty big jump. |
11-08-2020, 09:16 AM | #19 | |
Member#: 328635
NWIC
I was asking the OP about the drag strip seeing we have a very similar set-up but I have a gen 1 @26psi and that is a gen 2 pushing 29-30psi. Dyno's are great but if you can get trap #s it seems to be a more helpful reference point. Imo |
