02-16-2022, 08:17 PM | #1 |
Member#: 488985
Vehicle:2009 wrx dgm |
09 wrx with grimmspeed tmic, where to put iat sensor?
While I'm switching to e85 I'm converting to SD and cannot find anywhere to put an iat sensor without getting someone to weld a bung in my tmic, I've searched for hours and came up empty. Are there any "bolt on" options before I take my intercooler to a welder?
02-17-2022, 06:01 PM | #2 |
Member#: 151245
South East
Vehicle:2006 WRX Wagon Silver |
Ask your tuner
Any tuner who has been around the block will probably have experience with this. Ask them the best/easiest way they know of to do this.
02-17-2022, 08:14 PM | #3 |
Member#: 488985
Yea... He didn't really have a great answer for me other than welding my tmic, I guess I have an odd combo to run SD with. I'm willing to do it but only if there isn't a less intrusive way.
02-17-2022, 11:10 PM | #4 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Welding a bung into the outlet side of the TMIC is the standard way to do it. Why does that bother you? It's a reliable place to get a temp reading. The other spot some people put a bung is in the IM itself.
02-18-2022, 06:44 AM | #5 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
Here's where we put ours, but anywhere in this general vicinity should be fine. IIRC the GS unit uses very thick-walled sand cast end tanks. Since you're likely using a small 1/8NPT or 1/9PT (or smaller) IAT sensor, the thick wall of the sand casting should be fine. 3/16" (.1875) is adequate for installing functional NPT threads for this application. If you drill a hole and it's not thick enough, you're no worse off than you are right now. If you do go with a weld bung, we make/sell them for 1/8NPT from 6061 billet aluminum, $3.
Good luck! |
02-18-2022, 08:51 AM | #6 | |
Member#: 488985
