Old 11-19-2020, 06:14 PM   #26
Winterhawk
Member#: 463763
2002 WRX Sedan
Originally Posted by 86Dreams View Post
Its about 1200 iirc, Its well worth it it completely changes what the car can do. And there really isnt any other option besides a 2015 sti rack is there? And even tho thats cheaper its going to be harder to accomplish. What kept me from it was the .5 inch spacer, i wasnt sure where to source it. And having to trim the inner tie rods(?) made me lose some confidence.
The 15 rack requires the spacers, modifying the sub frame, tie rod triming, best to put in later ps pump and bracket, new lines and/or fittings, plus some having leaking issues, etc. No thank you, I'll take this one or even a 2004 STi rack, knowing it's a bolt in and forget about it.
Winterhawk is offline   Reply With Quote
Old 02-18-2021, 12:41 PM   #27
TimStevens
Member#: 4817
Bumping this up, about how long does shipping take to get these?
And can anyone comment on steering resistance with this rack? More or less than stock? I prefer a quick but light feel, if makes sense.
Rack on my 04 needs to go and I'm sorely tempted, but a bit concerned about things being too quick for the street.
Thanks!
TimStevens is offline   Reply With Quote
Old 03-09-2022, 03:28 PM   #28
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
12.9@103MPH EJ205 4EAT
bump... its that time again. I need to replace my rack on my bugeye STI and was wondering about these.
It looks like I need to make the whole thing meanin source the bellows, inner and outer tie rod ends? i had terrible luck with Moog inners and it ended up ****ing up my 2005 LGT rack so much so where I'll need to replace that one as well...
back to the bugeye... since its a quick rack and requires no modification like the 2015's to fit this seems doable but the cost is up there for an uncomplete rack you know?
I sent them a message this morning, my time. I hope they respond quick.
iNfEk is offline   Reply With Quote
Old 03-09-2022, 03:41 PM   #29
bhmax
Member#: 347233
I got one recently for my 05 WRX since the slow steering bugged me. Way too expensive, but no other option that slaps on easily. Very happy so far. I got some Mevotech inner tie rods.
bhmax is offline   Reply With Quote
Old 03-09-2022, 04:30 PM   #30
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Mevotech, I have used their LCA's and I'm happy with them.
I may need to look into their inners then. I may just buy OEM inners and outers. We will see. this will cost a pretty penny LOL
Old 03-10-2022, 08:43 AM   #31
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
I bought the PRS rack last year for my '05 STI. It was a great, smooth transaction and the rack made a big improvement in the car. Swapping it out was a bit of an adventure, as my subframe decided to liberate two of the four captive nuts used to hold the rack in place, which was a lot of work and $$ to fix. But, that's not the rack's fault, that was a ****ty design by Subaru.
Once I had the subframe fixed, I really have enjoyed the faster rack. It took a little bit to get used to, but now that I am used to it, it's a huge improvement.
I wound up buying all OEM inner and outers during the swap, they weren't too expensive and had held up well on the track.
RyanC is online now   Reply With Quote
Old 03-10-2022, 10:15 AM   #32
bhmax
Member#: 347233
One thing to watch is to make sure you know which rack of theirs you need. My 05 WRX is 5x100, but I needed their "5x114" rack. I hadn't really looked at mine much so I didn't know the differences. The brief searching I did said that the rack style was changed over at some model year, possibly 05. The 5x114 version also requires for you to send in your old one for exchange.
I also had one of those captive nuts come off. Drilled it out and put in a helicoil type insert. Put in a Chase Bays reservoir/line kit also.
Old 04-24-2022, 01:40 PM   #33
WUC555
Member#: 529774
2000 GC8
Did you end up receiving a response from them?
I messaged them a few days ago and no reply so far
WUC555 is offline   Reply With Quote
Old 04-24-2022, 02:04 PM   #34
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
No. I just got a view and that was it.
Old 04-24-2022, 02:13 PM   #35
WUC555
Member#: 529774
2000 GC8
Thanks for letting me know.
In the same situation. They've viewed it but not responded.
A bit dissapointing.
Old 05-06-2022, 09:33 AM   #36
WUC555
Member#: 529774
2000 GC8
Btw I did get in contact with them. So they are still around.
