09-25-2011, 10:49 AM | #1 |
Member Sales Rating: (119)
Member#: 212172
Vehicle:14 STI Carbon grey balck |
x2 04 wrx psm and jbp exterior and interior parts
x2 04 subaru Wrx part out
if i forgot something else on the interior or exterior that i did not mention plz mention it on here or pm thanks 02-03 bugeye painted wrb jdm genome sti grill in great condition i am asking 180 obo 02-03 wrx taillights 70 04-05 wrx driver headlights 125 Gfb bov recirculation for 120 oem bov elbow with no rubber hose 50 04-05 wrx scoop splitter 50 rear abs tone ring for $40 05 sti turbo cross member in great shape 125 04-07 wrx/sti bumper foam 30 each x1 front and x2rear x2 brake booster/cylinder 60 I have four front abs sensor 20 each one Rear abs sensor all Sold 02-05 wrx 3:54 diff lsd 180 04 wrx jbp driver side quarter panel from the center of car to roof, tail-lights and the button of side skirt $250 x3 02-05 wrx headers 90 un catted oem up pipe 40 04 wrx down pipe 150 SOLD bosal 3" inch axle back 250 SOLD SS 2.5" to 3" inch mid pipe 100 wrx starter 45 Wrx alternator 50 compressor 50 condenser 50 04 wrx steering rack $120 with inners and outers tie rods a/c lines 50 high pressure side x2 HVAC control $75 x2 maf sensor full box, inlet and sensor 140 wrx scoop rubber seal $10 x3 srs module $80 no accicent passenger airbag no cover $80 no accident x3 psm,wrb,jpb door hinges all 8 for $40 passenger side door cards 50 for both all black from a 04 wrx interior trim pm me for more info x2 3rd brake light 25 Driver rear, Passenger and rear door cards locks/windows switches/trim 45 for all three no drivers combination switch 04 wrx black door cards all set of four 04 wrx rear black seats center fold down top and buttom. rear seats $75 with center fold down arm rest from an 02-03 wrx there blue/black x2 hubs and knuckles front and rear 240 for one full set, 120 for rears 5x100 FRONTS SOLD 04 wrx steering wheel and airbag with red memo logo 160 lateral links 65 x2 t brac 60 x2 rear crash bar $50 each one in psm 04 wrx cluster 12x,xxx for 85 jacks $25 with L arm also have spare tools with bag 25 steering column 04 wrx all four door in jbp for $200 each just shell, window, window regulator, and motor all in great shape Psm all doors, power everything, all four sold spare cover carpet very clean 35 SOLD x2jacks $25 x2 maybe traling arms $50 for both x2 rear crossmember $50 dash 70 with no passenger cover and airbag with all vents front rs crossmember n/a $50 the whole harness, front and back, missing some connection in the front, no pcm $300 misc Bolts x2 awd bare gas tank $90 x2 fuel filler $40 any evap parts rubber lines 1.00 each one charcoal canister box 50 canister purge valve 20 x2 fuel door psm,wrb,jpb $25 x2 control arms $70 one full set, second set driver side passenger SOLD tb mechanical cable $25 hood latch cable $20 x2 04 wrx ps pump with reservoir and rubber lines $140 02-07 wrx/sti ebay CF mirrors bnib one mirror missing 110 shipped just include paypal fees x2 02-04 wrx tmic $35 with sti imprint with no y pipe some fins bent, The other is in mint condition with no bent fins. 02-04 wrx mint tmic from 04 wrx with y pipe in mint condition for 60 x2 02-03 wrx cluster gauge one with 256,xxx $30 and the other 172,xxx $40 x2 cluster surround $15 x2 front windshield surround $20 x2 wrx/sti steering column shaft 60 x2 wrx u joint for steering column 50 x2 wrx abs module $50 04 wrx ecu 100 04 wrx with sunroof hole for 40 x3 02-07 wrx dash 70 with no passenger cover and airbag with all vents x2 02-07 sti/wrx psm sti,jpb wrx,wrb sti/ trunk arms $35 04 wrx jbp trunk and spoiler 250 a set of four black door handles $45 interior x2 wrx jbp/psm torsion bars $40 Plastic engine under cover 40 x1 ps lines $40 for both SOLD one set sold 2x right 04 wrx front knuckles with bearing no rust, bearing has no play spins fine with splash shield, 120 for both has 45,xxx for 70 each with splash shield. plus im open to trade arp head studs, tmic bracket, BBs rims with snow tires 5x100 or 5x114 something that clears brembos, i will think more later. more to list later 20170413_225802 by , on Flickr ej205 long block 1300 5423172401 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 03-26-2018 at 08:29 PM. Reason: Updating |
09-28-2011, 12:46 AM | #3 |
Member#: 212172
Aaahhh... No Sorry
20180303_215220 by Francisco Rivera, on Flickr 20170510_154926 by , on Flickr 20180303_215212 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 03-05-2018 at 03:19 PM. |
09-29-2011, 01:02 PM | #5 |
Member#: 212172
i do but i dont think the are colored they maybe be the black one but i need to double check again will post on here if is colored?
20170915_102702 by , on Flickr 20170915_102634 by , on Flickr 00q0q_5C6KUY0c9LB_600x450_zpsjoswxcmg by , on Flickr Last edited by 93stiImperza; 09-19-2017 at 06:37 PM. |
10-09-2011, 01:57 AM | #6 |
Member#: 212172
i have no side skirts
passenger rear door and headlinear SOLD 20170624_160112 by , on Flickr 20170717_204747 by , on Flickr 20170624_160124 by , on Flickr Last edited by 93stiImperza; 09-19-2017 at 06:41 PM. |
09-29-2011, 01:01 PM | #8 | |
Member#: 212172
wrb the scoop but need to double check k. 20170717_204747 by , on Flickr 20170812_221227 by , on Flickr 20170913_141451 by , on Flickr Last edited by 93stiImperza; 09-19-2017 at 06:35 PM. |
09-29-2011, 06:54 PM | #10 |
Member#: 212172
^i yes i do
20170510_172424 by , on Flickr 20170510_155113 by , on Flickr 20170510_215324 by , on Flickr 20170501_110740 by , on Flickr Last edited by 93stiImperza; 09-19-2017 at 06:40 PM. |
10-04-2011, 05:05 PM | #11 |
Member#: 212172
bump... everybody that pm me for pics will have them tonight
20180130_232615 by Francisco Rivera, on Flickr 20180314_173812 by Francisco Rivera, on Flickr 00p0p_5rC2H4vSH8D_600x450 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 03-26-2018 at 08:26 PM. |
10-13-2011, 07:48 PM | #12 |
Member#: 212172
bump...
20170624_160056 by , on Flickr 00404_2cLoB8dY2oJ_600x450 by Francisco Rivera, on Flickr 20170901_130001 by , on Flickr Last edited by 93stiImperza; 12-04-2017 at 03:34 PM. |
10-19-2011, 01:28 PM | #13 |
Member#: 212172
bumping
20170524_124621 by , on Flickr 20170819_194913 by , on Flickr 20170813_160929 by , on Flickr 20180314_171935 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 03-26-2018 at 08:23 PM. |
10-24-2011, 12:41 AM | #15 |
Member#: 212172
^let me check
front driver door SOLD 20171101_213600 by Francisco Rivera, on Flickr 20171029_213648 by Francisco Rivera, on Flickr 20171029_213657 by Francisco Rivera, on Flickr 20171029_213653 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 12-04-2017 at 03:36 PM. |
10-25-2011, 10:55 PM | #16 |
Member Sales Rating: (3)
Member#: 267250
Vehicle:2007 STI Limited UGM |
Pics of carpet to [email protected] please.
11-02-2011, 12:46 AM | #17 |
Member#: 212172
bump...
20170919_093325 by , on Flickr 20170919_093302 by , on Flickr 20171029_213712 by Francisco Rivera, on Flickr 20171029_213738 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 12-04-2017 at 03:38 PM. |
11-05-2011, 01:41 PM | #19 |
Member#: 212172
pm'd u back no pump
20170509_172245_zpsdchy1ezu by , on Flickr 20171029_214932 by Francisco Rivera, on Flickr 54407116593095173781 by Francisco Rivera, on Flickr 88187607024512599921 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 03-13-2018 at 06:50 PM. |
11-05-2011, 09:38 PM | #20 |
Member#: 212172
Passenger side sold
20180301_173314 by Francisco Rivera, on Flickr 20180303_214306 by Francisco Rivera, on Flickr 20180301_173317 by Francisco Rivera, on Flickr 20180301_173331 by Francisco Rivera, on Flickr 20180301_173333 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 03-13-2018 at 06:52 PM. |
11-10-2011, 07:45 AM | #22 |
Member#: 212172
pm'd bump
20170423_161557 by , on Flickr 20170923_205257 by Francisco Rivera, on Flickr 20171029_231739 by Francisco Rivera, on Flickr 20171029_180513 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 11-27-2018 at 07:46 PM. |
11-11-2011, 12:02 AM | #24 |
Member#: 212172
0^NOPE
SOLD front knuckles/bearing 20171029_173347 by Francisco Rivera, on Flickr 20171110_172435 by Francisco Rivera, on Flickr 20171110_172423 by Francisco Rivera, on Flickr 00404_8nNJdeZfV7v_1200x900 by Francisco Rivera, on Flickr Last edited by 93stiImperza; 12-04-2017 at 03:34 PM. |
Similar Threads | ||||
WTB : 04-05 STi exterior and interior parts | ejh8r | Private 'Wanted' Classifieds | 1 | 07-24-2011 07:29 PM |
FS: 02 Wrx Exterior and Interior Part Out | stiv_5 | Complete Car Part-Out | 62 | 09-08-2010 10:21 PM |
WTB : 04 psm hood and interior parts | hoffmanEstates | MWSOC Private Classifieds | 2 | 08-02-2010 08:31 PM |
LF cheap exterior and interior parts. used or new... | icehockey101 | Private 'Wanted' Classifieds | 0 | 11-11-2008 09:34 AM |
WI WTB: 02-03 exterior and interior parts | 03imprezaRS | Private 'Wanted' Classifieds | 0 | 10-30-2004 03:22 PM |
