Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 09-09-2020, 08:53 AM   #1
silverwrx19224
Member#: 500246
17 WRX
Default Compressor surge? Wastegate flutter? Something else? WOT ticking
Over the past week I have been hearing a fluttering noise while WOT and under boost only 3-6k rpm. I didn't know where to look so I thought might as well inspect every aftermarket part I put on.
The other day I took all of parts off and inspecting any silicone for rips or tears and made sure all clamps were tight.
The noise was still there.
The video below is a short 3-6K pull in third gear. Any idea what this noise is and what can be done? I've read a lot of posts and am not sure what is causing it. One dude had a tear in his turbo inlet hose and the other completely replaced his turbo.
You can hear the fluttering noise like a leaf or playing card flapping.
Mods:
MAPerformance Stage 1+ Intake and Tune
Perrin Charge Pipe
silverwrx19224 is offline   Reply With Quote
Old 09-09-2020, 11:32 AM   #2
WMTwrx15
Member#: 501927
Sounds like an exhaust leak
Check your exhaust manifold to cylinder head bolts
They are known for coming loose
Hope that helps
WMTwrx15 is offline   Reply With Quote
Old 09-09-2020, 12:53 PM   #3
idiosyncrisia
Member#: 448185
2016 WRX
Yeah, I agree with exhaust leak. They can sound pretty damn raspy when they happen. I developed one at a track event and it was louder than what you have, but a bit similar.
Pretty easy to check for too!
idiosyncrisia is offline   Reply With Quote
Old 09-09-2020, 01:34 PM   #4
silverwrx19224
Member#: 500246
17 WRX
Hope that helps
Sounds like that might be it. I just saw another FA youtube video with a similar sound after searching exhaust leak.
I am going to inspect the bolts and buy some new gaskets and see if that works.
I have a magnaflow competition catback that I am pretty sure I can no longer get gaskets. Are there any products that can be used for sealing exhaust leaks?
Old 09-16-2020, 07:51 PM   #5
silverwrx19224
Member#: 500246
17 WRX
You both were right but the noise is still there. Did a suds test with a leaf blower and soap.
Proof of exhaust leak (sorry about the ****ty photos):
Cracked gasket
Large bubbles by the down pipe
Seems like I fixed an issue but not the one I was trying to resolve. I’m pretty defeated right now honestly because I think it took me about 8-10 hours. The bolts wouldn’t come off without an extractor and a stud came loose. I had to go to subaru parts department three times during this ****ty job.
Anyone have any idea where this sound could be?
Old 09-16-2020, 08:02 PM   #6
WMTwrx15
Member#: 501927
Check the bolts for the header to the cylinder head
Old 09-16-2020, 08:15 PM   #7
silverwrx19224
Member#: 500246
17 WRX
I sprayed that area and didn’t see a leak
Old 09-18-2020, 11:18 AM   #8
silverwrx19224
Member#: 500246
17 WRX
You were right, I was missing a bolt.
Took 5 minutes.
Old 09-18-2020, 12:48 PM   #9
killadawg
Member#: 424203
2016 WRX STage ??
Dirty
OMG, I've battled this so many times.. I'm running headers and have replaced my bolts so many times it sucks!! lock washers, special bolts etc.. I finally got it.. for now...
killadawg is offline   Reply With Quote
Old 09-18-2020, 12:55 PM   #10
standardtranny
Member#: 450713
2017 WRX Stage 3ish
world rally blue
http://forums.nasioc.com/forums/show...20some%20cars.
theres a recall for that, my 17 wrx wasn't affected but it looks like yours was
standardtranny is offline   Reply With Quote
Old 09-18-2020, 01:09 PM   #11
killadawg
Member#: 424203
2016 WRX STage ??
Dirty
Yeah Dealership refuses to touch my car unless I remove the non-stock items.. LMAO.. I have to remove everything under the hood!! Headers must be removed to tighten the exhaust manifold bolts (to an exhaust manifold I don't have anymore..)
Yeah I saw this bulletin update, yet this is my 2nd engine and 2nd set of headers and 3rd turbo... I don't qualify for free work. lol Pay to Play, gotta tighten my own bolts!
