02-22-2021, 11:58 AM | #1 | |||
Member#: 518830
RMIC
Vehicle:2009 WRX dark grey metallic |
TGV Delete plugs for data logging DIY
Hey, I struggled to find good posts for the 5 pin TGV deletes to use the plugs to data log with. I've got a 2009 WRX, so this only applies to that and check your own wiring diagrams and all that....
https://i.imgur.com/DQSfMyV.jpg I made this handy color chart for the people like me that can read something and twelve seconds later forget which pin went where. https://i.imgur.com/ou1TRJv.jpg ECU pin out to make sure I had ground and power right. https://i.imgur.com/Hly0IGC.jpg Proof if you don't believe me! Now the challenge was- the iwire services connector plugs (which are nice quality BTW) don't have the same color scheme. So you have to look at which harness wire matches which connector plug wire and then connect that appropriately. In this case I hooked up an oil pressure sensor and a wideband O2 analog output- both 0-5 volt. https://i.imgur.com/idaRupg.jpg https://i.imgur.com/LHzynPX.jpg In this case- oil pressure- 5v input is red, ground is black and signal is green. So green connected to the iwire red, black to black and red to iwirie white with red stripe. Next the wideband https://i.imgur.com/tOwAhw5.jpg brown was wideband voltage signal which connected to iwire red black was ground which was also iwire black. https://i.imgur.com/yWYCrO5.jpg I borrowed the sensor scaling from the romraider forums but named it "Wideband O2" http://www.romraider.com/forum/viewtopic.php?t=6430 Quote:
I'm still figuring out the scaling for my oil pressure sensor. I borrowed this for a 150 psi oil pressure sensor from the romraider forums and then changed it for a 100 psi sensor I have. I saw this thread https://www.romraider.com/forum/view...p?f=33&t=15528 and they used Quote:
So I used Quote:
Last edited by GeoNV; 02-22-2021 at 01:07 PM. Reason: trying to get image links to work |
02-22-2021, 12:03 PM | #2 |
Member#: 518830
RMIC
Not sure why the embedded image links aren't working. hosted on nasioc image server.
02-22-2021, 03:23 PM | #3 |
Member#: 515308
FYI, u can depin the connector and repin to something more accessible like a random set from junk yard
02-22-2021, 03:33 PM | #4 |
Member#: 518830
RMIC
true- sometimes we pay for convenience for sure.
02-22-2021, 04:31 PM | #5 |
Member#: 520062
Seems to concur with this:
https://forums.nasioc.com/forums/sho...uto+meter+2246 I just installed the Autometer 2246 on the TGV left... works great. |
02-22-2021, 04:38 PM | #6 |
Member#: 518830
RMIC
I wonder how I missed that in my search- Thanks.
