#1 |
Member#: 473523
Vehicle:2004 wrx sti wrb |
![]() Hi Guys,
I'm stuck in a limbo and need you need some expert advice/direction. To preface, i have a iag stage 2 tuff block that is currently on running on a stock turbo. I decided to pull the trigger and upgrade the turbo plus supporting mods to make more power.I'm stuck in the fueling department. Here's the issue, so i bought radium tgv deletes and top feed fuel rails Here's a link for reference Tgv housing http://www.radiumauto.com/TGV-Housin...-EJ-P1708.aspx Top feed rails http://www.radiumauto.com/Fuel-Rails...u-EJ-P631.aspx But I didn't buy the fuel rail plumbing kit because i dont really need the direct mount regulator and fuel pressure gauge. Plumbing kit http://www.radiumauto.com/Subaru-EJ-...its-P1767.aspx So where can i just get the plumbing kit without it? Is there another brand that offers this that would work with my setup? I did see IAG but they also sell it as a kit. Any help would be appreciated. ![]()
#2 |
Member#: 273868
![]() What turbo and injectors are you planning on running ?
What fuel? What regulator do you plan on running ? How will you set the pressure ? |
#3 | |
Member#: 473523
![]() Quote:
pump gas(93). Thought about flex fuel but I don't have any E85 gas stations near me unfortunately I thought the stock setup would suffice in this case I'm not sure yet |
#4 | |
Member#: 328635
Vehicle:2004 STi GTX3076R Rally Blue |
![]() Quote:
Get on summit racing and order them up in the quality/style you like with a chunk of hose that matches the style fittings and have at it. Or just buy the kit. I ordered a pile of fittings and because of the style I went with saved a LOT of money. |
