12-31-2011, 11:24 AM | #1 |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
2007 WRX hood keeps popping open on highway. Please help.
During my drive from Denver to Steamboat my hood popped open on the highway 4 times. Luckily the safety latch catches it before it smashes the windshield. It would happen when driving between 55 and 65mph.
This happened to me once before as well. It seems to happen when there are high headwinds. It's just the stock hood and I am 100% sure it's shutting all the way. Has this happened to anyone else? Is there any way for me to fix this?
12-31-2011, 11:28 AM | #2 |
Member#: 253560
South East
Vehicle:'83 Subaru GL Wagon |
I've noticed my hood shaking at speed but never opening. Is the latch broken or worn down?
12-31-2011, 11:29 AM | #3 |
Member#: 117767
RMIC
It looks fine to me but I'm definitely no expert. Is there a way for me to tighten the latch?
12-31-2011, 11:33 AM | #4 |
Member#: 225570
South East
Vehicle:09 wrx 79 trans am 462stroker |
How cold is it there? When it gets realy cold here in wisconsin my hood latch wont lock all the way and it will pop. If i can i pull it in the garage or else just spray it with some wd-40 and work the latch and it works. try that
12-31-2011, 11:36 AM | #5 |
Member#: 117767
RMIC
It was about 45-50 degrees during the drive up yesterday so it wasn't that cold. I'll try to take some wd-40 to it I suppose.
12-31-2011, 11:46 AM | #6 |
Member#: 79643
Vehicle:2021 STI TE Terminal black pearl |
Clean it out really well, grease it up when your done.
12-31-2011, 11:49 AM | #7 |
Member#: 117767
RMIC
Will do. Thanks!
12-31-2011, 12:48 PM | #8 |
Member#: 33868
Vehicle:2003 wrx srp |
Is there any accident history on this car? Look in the manual for the datums on the firewall and the front fenders.
12-31-2011, 12:52 PM | #9 |
Member#: 275056
Vehicle:07 civic ugm |
mine wouldn't close all the way one day so I sprayed some sea foam in the components and it worked out
12-31-2011, 12:55 PM | #10 |
Member#: 166834
Vehicle:2002 WRX WRB |
white lithium grease on the locking mechanism. done
12-31-2011, 01:04 PM | #11 |
Member#: 192147
Vehicle:2007 STI EfiLogics 422whp 421wtq fpgreen |
mine does this in the cold also.
12-31-2011, 04:36 PM | #12 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
Do you have adjustable rubber cushions? You could try turning those down. Also, test it after you close.
01-29-2021, 08:21 AM | #13 |
Member#: 497677
Vehicle:2018 WRX Premium WRB |
Didnt mean to resurrect this one from the dead too much. but this morning on my drive into work, my hood popped open on the highway. Here is New England, its about 9°F with a wind chill of -10°F. On highway going about 85, the hood popped up but luckily the catch held it in place until I could get off my next exit. I was scared to **** regardless.
This thread mentions that really cold temperatures play a role on why this happens. Does this still happen to others with the 2015+ WRX? I have an 2018 with no mods under hood and haven't opened trunk in a month. Wondering if I should get it looked at or is it an isolated incident? |
Similar Threads | ||||
Car died on highway...need help | autocannon05 | Service & Maintenance | 6 | 07-23-2007 11:24 PM |
keep having this code P0457...PLEASE HELP ON HOW TO FIX IT | baon_27 | General Community | 1 | 02-14-2007 11:53 PM |
My hood keeps popping up, why? | kellie00 | Interior & Exterior Modification | 17 | 01-17-2006 01:05 AM |
Warning, Hood popped open on freeway. | Alfaneggio | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 04-30-2004 07:31 AM |
Help please, a pr0n ad keeps popping up on my work computer out of nowhere.. | STR8OUT | Off-Topic | 20 | 12-15-2003 04:30 PM |
