Old 09-16-2020, 12:33 AM   #1
alexmartynyuk
Member#: 191967
2005 EVO VIII
open source tuning subaru
Default Merpmod speed density
Any merpmod users on here? How is your idle? I just started tuning a friends hawkeye using the merp mod patch. Trying to get the car to run full speed density and i'm having difficulty to get the car to idle. For those of you that are using the merp mod in full speed density mode did you have to modify the engine load smoothing factor? Did you have to modify any of the alpha idle control tables? My problem is the car doesn't wanna idle worth crap, really difficult to scale VE down low because it keeps hunting and is really unstable and stalls frequently but sometimes just randomly settles and idles fine. I created a thread on romraider attaching logs and my map along with the ecuflash definition. Thread is here: https://www.romraider.com/forum/view...p?f=37&t=17598
A little bit on the car
07 hawkeye
Rom A2UJ000J merp mod patched
Freshly built short block using new case halves
Stock cams and stock sized valves
FP Black 8cm
Walbro 255lph with pressure relief mod
FIC 1000CC
Agency power rails with stock fuel pressure regulator
APS 73mm CAI
I fully tuned the car on maf before trying to switch to speed density, on maf the car ran fine for the most part. The only idle issues I had on the maf tune is it hunted a little after hot starts or after resetting the ecu but I didn't spend too much timing getting maf dialed in at idle so I figured it was because of that. Im hoping people are still using the merp mod patch, hoping to avoid going cobb just for speed density. Any input would be much appreciated!
alexmartynyuk is offline   Reply With Quote
Old 10-05-2020, 01:22 AM   #2
benflynn
Member#: 515308
Running merp but not sd, hybrid mode was created for idle If u still run the MAF for iat. From 15yrs of other sd tuning experience, it’s lean in the ve map around the area it’s bouncing, usually adding 10% over that whole area will calm it down enough to start dialing it in. This would come up when the tune was trying to maximize the mpg. I have never tried to correct this with out live tuning and map tracing, I imagine it’s a pain
benflynn is online now   Reply With Quote
Old 10-07-2020, 01:19 AM   #3
alexmartynyuk
Member#: 191967
2005 EVO VIII
This was my original concern. However I have since switched to running dimemod patch which I didn’t even know existed up until a couple of weeks ago. Since switching to dimemod the car is running full speed density with iat still in the maf and so far idle is mint once warm. It hunts a little when warming up when the coolant is cold so I need to address warmup enrichment after VE is fully scaled which it nearly is. By the way this dimemod patch has insane features! It has:
Launch control that can be set to fuel cut or ignition cut or a mix of both.
Auto rev match
Rolling launch
Antilag
It has capability of controlling methanol injection
Map switching
Hybrid maf/speed density
Full flexfuel capable
All on a stock ecu. It does cost money but in my opinion still worth it and you still use ecuflash to edit the map as well as romraider logger to log. For those interested definitely worth checking out. As for why the car hunted idle and stalled on merp mod I have no clue. I ran smilar VE values down low but for some reason the car would just not behave.
Old 12-11-2020, 06:07 AM   #4
pcampbell
Member#: 437670
2005 2.5 SC OB
Where do you get it?
I want to run SD or hybrid on an NA (supercharged car) ecu so I need a little extra support. About to peg my MAF sensor on a 70mm ID housing. My IAT is relocated to post IC hopefully that is good.
Not sure if I want hybrid or straight SD. Bypassing the huge air flow on the supercharger is a bit of a pain so SD vent to atmosphere would be nice.
pcampbell is offline   Reply With Quote
Old 12-11-2020, 02:55 PM   #5
benflynn
Member#: 515308
Someone has to edit a rom for ur ecu, I doubt it’s out there. There was a speed density forester, I had one, was 1999ish.
I think a turbo ecu if possible w/sohc. cam sensors or get someone to mod ur rom . All this is on romraider site
Old 12-22-2020, 07:40 PM   #6
alexmartynyuk
Member#: 191967
2005 EVO VIII
Dimemod will only work with 32 bit ecus equipped with an immobilizer. As for the patching service hit up @dime_spb on Instagram since that’s who I purchased the patched rom from.
Old 12-23-2020, 12:12 PM   #7
jon7009
Member#: 394646
2003 WRX Flex Fuel
Pv=nRT
note: when using merp for speed density, you have to crunch the Sd/IAT load comp into the MAF g/s IAT comp table
Dime has a traditional/cobb/carberry sized sd/IAT load comp
jon7009 is offline   Reply With Quote
Old 01-17-2021, 06:07 AM   #8
pcampbell
Member#: 437670
2005 2.5 SC OB
Is it literally only cars with immobilizer or just drive by wire cars? Can’t really think what the immobilzer has to do with it.
Old 01-30-2021, 02:44 AM   #9
alexmartynyuk
Member#: 191967
2005 EVO VIII
Unfortunately its only on cars with an immobilizer. The reason being is that the patch is not free and that's the only way the developer can get consistent income. He vin locks the patch so that you cannot use it on a different car with the same rom. The only way that can be done is through the immobilizer, that's why he can only do it on immobilized roms. And also because the non immobilized roms don't have enough space to make the patch work.
Old 01-30-2021, 08:38 AM   #10
pcampbell
Member#: 437670
2005 2.5 SC OB
Can you put tell me how to contact the developer?
I am pegging my MAF now, need to decide to go bigger draw through, blow through MAF or something else. There is , as far as I can tell not enough support for me to do MerpMod.
Sorry you said already on IG... I'll see if I can find them. I am not on IG!
Old 02-02-2021, 03:45 AM   #11
alexmartynyuk
Member#: 191967
2005 EVO VIII
If you are on RomRaider send him a message, his username is DimeSPb, or dime_spb on instagram.
Old 02-03-2021, 08:36 AM   #12
pcampbell
Member#: 437670
2005 2.5 SC OB
Thanks found him just waiting for some more details. He did say he could do my rom.
Old 02-04-2021, 01:40 AM   #13
alexmartynyuk
Member#: 191967
2005 EVO VIII
Awesome and good luck!
Old 06-23-2021, 03:02 AM   #14
TIMOSH97
Member#: 525098
Unhappy
Dimemod will only work with 32 bit ecus equipped with an immobilizer. As for the patching service hit up @dime_spb on Instagram since that's who I purchased the patched rom from.
Good day! How are you?
Do you use with a dime mod?
Can you tell me how to calculate SD ve & Ve tip
Can you help I will be grateful. 4 week I can not tune in.
87022083030
TIMOSH97 is offline   Reply With Quote
Old 07-01-2021, 04:22 AM   #15
alexmartynyuk
Member#: 191967
2005 EVO VIII
87022083030
I replied to your private message sir, sorry been busy so haven't been on for a few days.
