Old 02-19-2007, 08:55 PM   #101
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Originally Posted by ka mano View Post
I always use distilled water but my shop says the stuff from the tap is fine.
Tap water is fine, but you must check the jets more often for minerals buildup. Thats why distilled water is preferred.
El Gato is offline   Reply With Quote
Old 02-20-2007, 01:07 PM   #102
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Thanks for the feedback guys...yea, I'll def. be using distilled water to be safer.
aps2fast4u is offline   Reply With Quote
Old 02-25-2007, 09:46 PM   #103
albie1kanobi
Member#: 101607
06 Subaru STi
How about more info running Meth vs Denatured Alcohol.
Meth is harder to find.
Meth is cheaper.
Meth has a higher octane rating.
Where as Denatured Alcohol not as corrosive as Meth.
Denatured Alcohol could be found more locally like at a hardware store.
It is also found to be more expansive.
please, anyone, correct me if im wrong on any of this. also add any other info that is missing or useful.
albie1kanobi is offline   Reply With Quote
Old 02-25-2007, 09:50 PM   #104
testes1010
Member#: 47145
2012 Gas Saver
HEET @ Walmart OR heating oil supply stores. 99% pure methanol.
testes1010 is offline   Reply With Quote
Old 02-27-2007, 03:14 AM   #105
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
wow i just installed my perrin progressive system this helped alot... is it ok to run a product called heat? its a 90% methanol and 10% alci mixture no water?
STIFLYBY_RANGER is offline   Reply With Quote
Old 02-27-2007, 03:14 AM   #106
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
yea heet thats it .. is it ok to run just heet or do i need to add water to the mix?
Old 02-27-2007, 09:05 AM   #107
testes1010
Member#: 47145
2012 Gas Saver
you can mix or run straight. The yellow bottle of HEET is 99% methanol, the ISO-Heet is a mix of methanol & isoprophenol
Old 02-27-2007, 10:38 AM   #108
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
^^^seems like that would get quite expensive....isn't heet like $2-3 per small bottle??
Old 02-27-2007, 10:46 AM   #109
testes1010
Member#: 47145
2012 Gas Saver
nope less than $3 for a 6pack...
Old 02-27-2007, 02:14 PM   #110
psmBoXer
Member#: 90354
2018 STI
WRBP
I really recommend www.alkycontrol.com custom made kits and Julio is great to deal with. Had mine installed by him last year when I had the STi and getting it done on my Cobra soon.
psmBoXer is offline   Reply With Quote
Old 03-01-2007, 12:54 AM   #111
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Originally Posted by testes1010 View Post
you can mix or run straight. ...
Yep, but the two need two different maps.
The alky's a fuel that's not getting gauged by the fuel injectors.
ka mano is offline   Reply With Quote
Old 03-01-2007, 01:27 PM   #112
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Can you run just water injection without methanol?
Yes, but you will not be able to take advantage of the octane boosting properties of methanol, thus you will get cooling from the water, but no increase in octane. Without methanol, you may not make as much power, as it acts as a detonation inhibitor, and you may not be able to run a leaner AFR as you could with it.
This is pretty bad information.
With all due respect, I recommend leaving the answer generic instead of providing misinformation:
Sure, just be sure to tune appropriately for water injection (alone).
jblaine is offline   Reply With Quote
Old 03-13-2007, 04:25 PM   #113
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
jblaine - So from what I gather from what you're saying, water injection by itself without methanol works too.
Migo is offline   Reply With Quote
Old 03-13-2007, 04:32 PM   #114
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
It most certainly does.
Old 03-14-2007, 09:38 PM   #115
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Yes... it'd be good if Tim or Mick were to clarify here how much they pushed the H20-only tune on the dyno that day.
Did you find out how hard they pushed the water tune?
WRXRallyBlue is offline   Reply With Quote
Old 05-10-2007, 06:15 PM   #116
tube
Member#: 139485
2004 16g WRX DomTune
Java Black Pearl
Denatured alcohol is NOT methanol, it's ethanol that has been denatured with things such as Bitrex and Methanol.
Isopropyl IS NOT methanol.
I would be careful just dumping anything labeled "alcohol" into my injection system.
tube is offline   Reply With Quote
Old 05-11-2007, 11:28 AM   #117
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
noOb to this conversation, but with a gt/30-sized snail in the garage, this is looking good. *subscribed*
cellobro is offline   Reply With Quote
Old 05-12-2007, 09:19 AM   #118
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
The first few weeks I was running water injection, it was with denatured alky. It works fine, just kinda expensive. Once I found a source for methanol in bulk, I went to that and haven't come back.
DP
DonkeyPunch is offline   Reply With Quote
Old 05-14-2007, 08:24 PM   #119
plus plus plus
Member#: 102013
Do I need engine management to run this? Yes, 100***37; absolutely you HAVE TO have, at a minimum, some way of tuning fuel. Because when this sprays you will go INSANELY rich, like 7-1 rich. That is rich enough to be dangerous and can cause bore wash (this is where there is so much fluid in the cyl that it rinses the oil off the cyl walls, and the rings tear themselves and the cyl wall up.)
I dont want a ton of power, I just want the safest car possible Then leave it stock. There are no absolutes and ANYTHING you do to the motor increases the chances of it blowing up.
HOWEVER, you can make your car a LOT safer than it would have been. If you are considering this as a precautionary mod only, you can leave the timing and boost alone, and only tune to a "normal" a/f ratio as if it didnt have alch injection. Note than a "normal" non alch a/f is richer than what is considered a "normal" alch injection a/f, at least a little(in most cases).
Once installed do I remove fuel out of my fuel map to remove this insanely rich condition or can I leave my fuel map at 11:1 and use as a safe guard? or will my 11:1 map at 91 octane go rich....? These statements above seem opposing.
OK I see he is talking about the Actual AFR ratio not fuel map values....
In Speed Density using the UTEC I use 0's for values for my modded stock 850 cc injectors in my fuel map to get a slightly rich base map to start tuning with a 650/420 settings in parameters for injector size.......
What would be my new starting point using injection?
How much fuel must be pulled?
Any Ideas?
plus plus plus is offline   Reply With Quote
Old 06-02-2007, 09:29 PM   #120
Mel Adjusted
Member#: 143372
Many All Different
The rainbow
For all you users of spray (nitrous) users, if you run water/alky injection you won't need to retard your timing as much and you'll have much cooler combustion chamber temps. It makes spraying much safer. I swear by it.
Mel Adjusted is offline   Reply With Quote
Old 06-12-2007, 09:15 PM   #121
Davenow
Member#: 23676
denatured alk works 100***37; fine and is no worse for your car/system than methanol is.
You dont get the same effect that you would on meth, however the difference is pretty small and denatured will still yeild huge gains.
I ran 50/50 distilled water/denatured alk in my alk cars (and will be doing the same again in this one once I hook it up) and it was awesome. 4+ degrees of timing, 12.5-1 a/f and 23lbs of boost on the stock STI turbo.
no knock, ever.
Davenow is offline   Reply With Quote
Old 06-13-2007, 07:06 PM   #122
siegelracing
Member#: 45173
1999 2.5 RS
White&Gold All-Suspension
You only lean the AFR out with between 100***37; water and about 70% water, 30% meth. With pure meth you run MUCH richer.
Stoich on gasoline = 1 Lambda = 14.65:1 AFR
Peak power on gasoline "near" 11:1 AFR = 0.75 Lambda
Stoich on methanol = 1 lambda = 6.47:1 (yes six and half)
Peak power on methanol = 0.8 lambda = 5.2:1 AFR (yes, vehicles that run straight methanol run in the FIVE to ONE Air to Fuel Ratio at WOT)
So adding 100% methanol to gasoline = moving from 11:1 AFR toward 5.2:1 AFR = getting richer.
With more than 30% water, the water is absorbing so much energy that you have to lean it out to make power... with more/straight meth, you actually run richer than you did on pump gasoline.
(flame suit on)
SS
siegelracing is offline   Reply With Quote
Old 06-13-2007, 07:34 PM   #123
testes1010
Member#: 47145
2012 Gas Saver
Originally Posted by siegelracing View Post
You only lean the AFR out with between 100% water and about 70% water, 30% meth. With pure meth you run MUCH richer.
(flame suit on)
SS
Whats on paper doesn't always apply to real life. Stoich of E85 is well below 10:1 but in the real world it is safe to run it to 12.5:1. Thats why you don't always believe what you read on teh interweb....
Old 06-13-2007, 09:40 PM   #124
siegelracing
Member#: 45173
1999 2.5 RS
The World's Fastest Stock Block Stock Tranny EJ205 WRX runs 10.2 to 10.4 AFR on an Innovate Wideband... Granted that's near 0.5 AFR richer than other wideband's might show, but it's still sub 11.0... At 10.5 AFR it pings...
SS
Old 06-13-2007, 11:37 PM   #125
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
SS
And 40 other people have proof that they gained a good 10-15whp on pump gas when leaned from 10.5:1 to 11.5:1 even leaning near 12:1 from 5500RPM onward with no water, meth, or 50/50 spray.
We've all heard it before: Every single car has a single unique tune best suited for it.
At any rate, a 50/50 mix injected at a 1:5 water+meth:gas ratio (20% as typical) has a whopping 10% meth combusted. Given straight water tunes that run fine at 12.5:1 (with no power gained by richening, BTW), it's damn safe to play around 11.5:1 with a 50/50 mix at 20% spray.
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 08:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
