08-14-2020, 02:44 PM | #126 |
Member#: 76228
Vehicle:2005 STI Aspen White/Seibon carbon |
updates
I want to ditch the STi side skirts and do WRX skirt setup Mishimoto thermostatic oil cooler (I need to modify the bracket to pull it up just a bit) More interior stuff came in and the old stuff got taken out. Still have to remove all the airbag wiring, passenger airbag, and airbag control module Sparco Ergo ll These will mount to a Planted seat base. (forgot to take the picture)
08-14-2020, 02:51 PM | #127 |
Member#: 76228
Test fit
Allot of cleaning to do inside. Some parts need to have some surface rust removed and be re-sprayed. I have some carbon plate coming in that I have some plans for, and I still need the weld-in-cage to get here to mount the seat. I have a ton of projects to finish up, so going to take a break to save up some funds and try to get as much done in the next two weeks as I can. Colder weather will allow me long days in the garage. |
08-20-2020, 08:30 AM | #128 |
Member#: 76228
More work on the interior. Made
A switch plate out of carbon to delete the radio. And pulled the car out to clean the shop in anticipation of the rollbar. Into the night which ended with beers with friends Last edited by stikid2005; 08-20-2020 at 08:36 AM. |
08-20-2020, 11:17 AM | #129 | |
Member#: 517901
That lip is awesome
08-20-2020, 04:20 PM | #130 |
Member#: 122306
Vehicle:2002 Sti PTE 6262 Interlagos Blue 610/580 |
Ive been following along still on I.G. The car is looking awesome!
08-21-2020, 02:14 AM | #131 |
Member#: 76228
08-21-2020, 02:15 AM | #132 |
Member#: 76228
08-21-2020, 10:36 AM | #133 |
Member#: 34361
Vehicle:04.7 STI WRB IG @got2boostit2 |
08-21-2020, 06:07 PM | #134 |
Member#: 76228
@concept0
08-24-2020, 02:27 PM | #135 |
Member#: 253498
SCIC
Vehicle:02 RSTI MURK'D |
bruhhhh you don't need those panels, send to me!
car is looking great. |
08-28-2020, 12:56 AM | #136 |
Member#: 76228
08-28-2020, 01:03 AM | #137 |
Member#: 76228
Some updates. All the airbags, sensors, and contoler are out and I am working on the harness now. Next will be the door panels and all the speaker crap.
started to get rid of the minimal rust. I removing all of the OEM seam sealer. (this is a old pic the front footwells are almost done) removed the rear bumper support because it was roached. Bonded the hood vent. Looks crazy but I wanted to make sure it was flush. And done. Last edited by stikid2005; 08-28-2020 at 01:11 AM. |
08-28-2020, 01:44 AM | #138 |
Member#: 253498
SCIC
I'm not one for a melting pot of carbon but something about your car in raw form i like. I see you mentioned paint in Nov. Are you (and your pops) tackling this?
08-28-2020, 01:05 PM | #139 |
Member#: 76228
Two option. One is having a friend of a friend come over and we paint it at the shop. Or the option I'm leaning towards is a new place I got recommended to that does awsome work. As I get closer I will contact them to get a rough number.
09-04-2020, 09:22 PM | #140 |
Member#: 76228
More work
floor panel progress. Everything will be coated with POR15 clear and the POR top coat Test fit the rear panels... and man do these fit perfectly! Going to look great with some nice hardware and the lexan windows with the carbon trim! Cage/roll bar work starts soon getting excited. |
09-09-2020, 07:34 PM | #141 |
Member#: 76228
Got the Autopower roll bar in. Waiting on so other material to fab up the trunk bracing, chassie mounts for the wing, and rear strut tower brace.
Removing more of the airbag harness. Last little bit. and some fresh RPF1 center caps. (Those are just smudges on the rims... evything on the car is filthy). |
09-09-2020, 08:24 PM | #142 |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
Looks like its coming along nicely. Maybe I missed it, What suspension are you on???
09-09-2020, 08:51 PM | #143 | |
Member#: 76228
Tein Flex coil-overs. Not sure when they were installed but appear to be in ok condition. I will be replacing them with a 2 way setup. Either BC HMs or KW club sports (spring rates pending). Also, the entire TTS fab catalog and some Whiteline part mixed in. |
09-09-2020, 11:32 PM | #144 |
Subtly Outspoken
If you are going to drive it in the winter... I HIGHLY reccomend the KW's as they are stainless and won't have much of 'winter' issue that others brands seem to have.. just my 2 cents..
09-09-2020, 11:41 PM | #145 | |
Member#: 76228
This car will come out when I want to have a good time or an event I want to attend. |
09-16-2020, 08:29 PM | #146 |
Member#: 76228
updates.
So some kinda woodland creature decided to set up shop above my gas tank when the car was sitting for all those years. This is the result.... I will be replacing all of this with a fuel cell and the rust on the body was not to bad at all... Roll Bar mocked up needs to go back further. Progress on the wiring this is allot of work I will post a whole bunch of pictures when that done. Switch plate it coming out awesome. Allot of trimming and fine tuning. |
09-16-2020, 09:31 PM | #147 |
Member#: 34361
Critters!
09-21-2020, 01:12 AM | #148 |
Member#: 76228
more work to center dash.
still have to box in the switch panel and test fitted the front carbon door panels |
09-21-2020, 09:17 AM | #149 |
Member#: 476295
Fire ***128293; in for progress ***129305;
09-23-2020, 09:11 PM | #150 |
Member#: 76228
some new pictures
Stole these on ebay |
