11-03-2020, 01:34 PM | #1 |
Member#: 508145
Vehicle:2007 WRX Wagon Satin White Pearl |
Quiet and Slow
I put in a new downpipe about a week or two ago and got it tuned, and it was running really well.
Yesterday it was running fine. Today I started it up, and it was quiet, like stock exhaust quiet. I was hitting target boost still but it felt much slower and much quieter. The only thing different is that I put new exhaust hangers on the car. Also, over the past few days it, the feedback knock and fine knock learn have been hitting higher numbers. Like up to -10, usually at least -5. The DAM is fine though. Any ideas what's up? Maybe it's just in my head but it feels like an entirely different car.
11-03-2020, 02:25 PM | #2 |
Member#: 338863
Vehicle:PSM 05 WRX WGN 5MT 95 Caprice 6spd Track Rat |
One of the catalytic converters clogged? Baffling in the muffler loose/shifted, blocking exhaust?
11-03-2020, 07:26 PM | #3 |
Big Ron
Super Moderator Member#: 18062
Your downpipe will not make an appreciable difference to the dB out of the tailpipe. That's not a thing, despite what the internet tells you.
11-03-2020, 07:35 PM | #4 | |
Member#: 497893
Vehicle:2011 Sti Hatch New color coming soon. |
11-03-2020, 08:34 PM | #5 |
Member#: 508145
the cat is intact and I can't find anything clogging the muffler. it was moderately louder when I first installed it, and people were commenting they could hear me coming from before I got to the neighborhood, but now I can sneak up to people until I'm a few houses away (might just have been exaggerations). Honestly, I like the quietness of it now, but I was mostly just concerned. It's quieter both in the cabin and outside, mostly in it doesn't really have much rumble to it anymore. All I can smell right now is pb blaser but I'll check once I get that cleaned up. I'l reflash it and check everything out I can think of
11-04-2020, 10:06 AM | #6 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
What make / model downpipe?
Some brands are known to be quite loud by design. If you have one of those, and all of a sudden it gets quiet, then it sounds like something is clogging the exhaust. What else did you change? |
11-04-2020, 10:33 AM | #7 | |
Member#: 428511
Vehicle:2016 STI |
the honeycomb inside breaks apart I had this happen to me, a tennis ball sized chunk came out and clogged the muffler so bad I could only drive in 1st gear, any other gear was so restricted the car couldn't move Maybe you have a small issue, but if it drives the same and you don't feel like pulling pipes apart all you can do is wait and see if it gets worse |
11-04-2020, 11:07 AM | #8 |
Member#: 508145
It's a Cobb catted downpipe. I didn't change anything since it dropped in noise except for the exhaust hangers which I have no idea how those would change it. I'm going to take it apart tonight and check for things inside of it
11-05-2020, 10:20 AM | #9 |
Member#: 21145
NESIC
Cobb's are loud exhaust but you did say just the DP.
I side with the possible failed cat. If old enough, they can fail and come apart, then clog your exhaust and you will have big problems Last edited by Samurai Jack; 11-05-2020 at 10:26 AM. |
11-05-2020, 08:25 PM | #10 |
Member#: 508145
the new downpipe only has about 1k miles from the person I bought it from and under 1k from me. it was taken off a totaled car though. Saturday I'm going to take everything apart. Thanks everyone for all the information!
11-07-2020, 12:52 PM | #11 |
Member#: 126131
SCIC
Vehicle:11 wrx sedan black pearl |
So... its not a new downpipe. I'd be skeptical about what someone tells me regarding a part and how many miles it was used for. Unless you know them personally.
11-14-2020, 07:02 PM | #12 |
Member#: 508145
ok so i just got around to everything. reflashed the tune and it's the same, took the downpipe out and the cat is clean and intact. used one of those camera flashlight string things to check in the catback muffler and it's all clear.
i think what happened is there was a leak originally and when i put the lower exhaust hangers on it fixed the leak and that why it's quieter. BUT something still seems wrong, dam is perfect but i'm getting around -10 feedback knock at least once every time i drive. I forgot to mention it also as a pretty significant delay in throttle response that it never had before. Its much harder to hit max boost as well. Last edited by knesek; 11-14-2020 at 11:11 PM. |
11-15-2020, 12:24 AM | #13 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
any other info? What do the fuel trims look like?
11-17-2020, 12:17 PM | #14 | |
Member#: 208672
TXIC
Vehicle:2013 WRX STI Limited Obsidian Black |
11-17-2020, 08:27 PM | #15 |
Member#: 508145
Ok thank you everyone! I took everything apart and cleaned it up and couldn't find anything but somehow when I put it back together everything worked like before. I did find a tiny bit of BRIGHT orange stuff in the cat that looked almost like rust. Knock, throttle response, and power are all good again. It is on an OTS tune (I know) but it's one of my top priorities to get it pro tuned, just can't afford it at the moment with covid.
