Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 05-26-2019, 08:08 PM   #1
panel
Member#: 352704
1965 Vw panel bus
with an EJ20 Turbo Swap
Default Stainless heat shield gauge thickness for turbo?
I was wondering if anyone knew the gauge thickness of the stainless heat shields for the turbo chargers. I'm getting a custom one made and wondered what the gauge thickness was of the aftermarket brands out there.
panel is offline   Reply With Quote
Old 05-28-2019, 04:11 PM   #2
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Depends on if you plan to add stiffening ribs to it or not. The OEM shield is stamped with stiffening features and is quite thin (don't ask me how thin...). The aftermarket ones I've inspected are generally folded and sometimes welded, most are x2-x4 more thick than the OEM shield.
I would stick with the OEM shield if you can and trim it to fit. It gives better coverage than any aftermarket shield could ever hope to.
car_freak85 is offline   Reply With Quote
Old 05-28-2019, 11:58 PM   #3
panel
Member#: 352704
1965 Vw panel bus
Thanks car_freak85. I don't have an OEM one and mine is not in your typical engine bay so it would probably hit something Was hoping someone could just measure their aftermarket one for me.
Semi recent pic:
Old 05-29-2019, 10:25 AM   #4
fartbox420
Member#: 483915
2004 wrx
my Cusco heat shield is like 3/32 thick.
fartbox420 is offline   Reply With Quote
Old 05-29-2019, 12:03 PM   #5
mitch808
Member#: 10228
2002 Subaru WRX
Or take off turbo, disassemble hot side, send to jet hot coatings or similar for a colored heat coating. Itll add bling and additional protection to your engine bay and added HP. https://www.jet-hot.com/thermal-barrier
Later you could fab up a simple 1-3mm SS plate with a brake alone
mitch808 is offline   Reply With Quote
Old 05-29-2019, 03:40 PM   #6
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
It really depends so much on construction method. If you have a means of bead rolling and forming, I'd go with two thin layers and roll the inner layer so that it leaves and air-gap. Then you tack weld it in place.
Old 07-30-2019, 12:24 PM   #7
Lindy19
Member#: 504761
I used 3/16 SS on mine.
Lindy19 is offline   Reply With Quote
Old 07-31-2019, 09:08 AM   #8
Homemade WRX
Member#: 33782
96 3MI Racing
3/16" sounds more like a scatter shield
Old 08-04-2019, 01:01 AM   #9
panel
Member#: 352704
1965 Vw panel bus
Ended up getting an aluminum one done. I'd like to get it powder coated . Do you think the powder coating will crack after awhile ?
Old 02-05-2020, 10:44 PM   #10
CarbideCarGuy
Member#: 489895
2005 STi
I make these heat shields out of 304 hardware and Aluminum sheet.
The aluminum sheet is .050 thickness and works pretty well. They can move around and clamp to similarly size pipes. For smaller pipes i just get a smaller clamp and bend a tighter radius. Hope this gives you ideas!
I can always make one for you too, I sell them for $25 + shipping
CarbideCarGuy is offline   Reply With Quote
