08-29-2013, 09:38 PM | #1 |
Member#: 137902
Vehicle:---- living life to the least!! |
Car repair thread-post your queries and tips/tricks here!
It seems we have how-to threads for home/technology/kids/wives/minivan dog problems/sailboats but not for questions, tips and tricks to utilize the collective knowledge of Ot to help answer questions, etc about with someone's car problems....
Currently I have an old saturn SL1 with 221k on it. I was pretty sure the left front CV axle was shot. I jacked up that corner and gave the wheel a wiggle, just to see and HOLY HELL! The bearing is so shot that when i wiggle the wheel around it feels about like if i had backed the lug nuts out about 1/8 inch. I'm still suspect of the axle, but let's face it, that's a lot of miles, i'm sure they should be replaced anyway. I've had a few cars with wheel bearings gone bad and it seems like every damn time it manifests itself differently. so my q's are: would a bad alignment wear out bearing quick? would a bad cb axle cause bearing failure?
08-29-2013, 09:45 PM | #2 |
Member#: 45204
NESIC
Vehicle:16 you don't respond to danger |
08-29-2013, 09:46 PM | #3 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Bad CB axle? Breaker one niner for a radio check.
08-29-2013, 09:57 PM | #4 | |
Member#: 6590
Be thankful it lasted this long. Vibration and an unaccounted for load (see: ******** that put huge offset wheels on their car) can cause bearing failure. A bad CV joint shouldn't cause the issue, but if you're going it to replace the bearing, might as well do the axle at the same time...plan on doing both sides. |
08-29-2013, 10:07 PM | #5 |
Member#: 2072
My best tip:
When removing tie rods or ball joints, instead of using that tool which pushes them out, hit the side of the tie rod end/ball joint housing with a sledge hammer a few times - good and hard. The joint should pop out within a few blows. |
08-29-2013, 10:13 PM | #6 |
Member#: 339032
The axle does not locate the wheel so any play can be attributed to wheel bearings, ball joints or tie rods. Was there more or less play when shaking top and bottom or side to side?
08-29-2013, 10:21 PM | #7 |
Member#: 137902
about the same. I've had a few bad wheel bearings, and none ever got this bad. Weird part is the noise just started yesterday morning afaik... frickin weird. I have 2 new bearings on order...
08-29-2013, 10:23 PM | #8 |
Member#: 6590
Are the pressed or a bolt-in hub?
08-29-2013, 10:28 PM | #9 |
Member#: 137902
pressed Not sure if either is better, but my last car car had a bolt in hub and that was tons easier than having to take the steering knuckle with the whole damn hub assembly to a shop and have them do their thing....
my uncle is a mechanic and has a press, so When i get my parts, I'm going to have him do it... |
08-29-2013, 10:38 PM | #10 |
Member#: 242205
Vehicle:2009 I don't know Dirt |
To stop my battery posts from corroding I delicately apply a thin layer of grease
Works for knobs too |
08-29-2013, 10:51 PM | #11 |
Member#: 4562
NWIC
Vehicle:2014 Electric Datsun 2005 Adventure van |
Check the axle nut, if its loose it will cause play I the bearing (and failure)
08-29-2013, 10:56 PM | #12 |
Member#: 124254
NESIC
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
08-29-2013, 11:01 PM | #13 | |
Member#: 6590
08-29-2013, 11:15 PM | #14 |
Member#: 42454
SWIC
Car sitting, never run in over 5 years. On tires that aren't flat and still fuel in tank. Steps to take to get it running?
Empty fuel and flush tank? Change plugs? What else? |
08-29-2013, 11:20 PM | #15 |
Member#: 4562
NWIC
08-29-2013, 11:22 PM | #16 |
Member#: 42454
SWIC
Fuel wouldn't be all gunky or something?
08-29-2013, 11:35 PM | #17 |
Member#: 242205
08-30-2013, 08:31 AM | #18 |
Member#: 240621
Vehicle:2014 Mazda 3 |
I'd drain it and put new fuel in regardless. Not the best idea to run 5 year old stagnant fuel through the system if you can avoid it.
08-30-2013, 08:47 AM | #19 | |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
Overtorqued by 80ft/lbs. Took some time, but the noise came back within 6 months. Replaced bearing again and used correct torque. |
08-30-2013, 09:20 AM | #20 | |
Member#: 93193
South East
Vehicle:'03 325iT Mysticblau |
I'd change the fuel first, and your tires are likely to fall apart in the very near future. |
08-30-2013, 09:31 AM | #21 |
Member#: 124254
NESIC
Seafoam.
Gallons of Seafoam. |
08-30-2013, 10:41 AM | #22 |
Add Lightness
NESIC
Take breaker bar and 32mm socket. Put socket on CV axle end. Pick up whole car by that nut and carry it to car dealer. Drop car and tell dealer that you'd like to trade the car for a new car.
08-30-2013, 11:21 AM | #23 |
Member#: 41713
NESIC
Vehicle:. sprayfinishing supplies.com |
08-30-2013, 11:55 AM | #24 |
Member#: 133597
SCIC
When changing the oil filter on an is300 expect to get oil every****ingwhere.
Pro Tips - Tips from the Pros |
08-30-2013, 12:03 PM | #25 | |
Member#: 13772
RMIC
Vehicle:16 Frontier Red |
I saved myself the trouble and would take in to get the oil changed. There was a 1.5" flat metal bar that ran directly under the plug. Unscrew plug, oil hits bar, oil splashes everywhere. Who the hell thought putting a bar under the drain plug was a good idea? |
