Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 04-10-2011, 12:06 PM   #26
squashman
Member#: 71718
07 STI LTD
Medium bump from the dead.
Might be a dumb question, but is there a way to transfer just the tracks from the GD's base onto the GR base? Looking at those pictures, the "track" is where both seats are bolted to the bar. If it was possible to remove just the GD tracks and fit them to the GR seat bases, it seems like it'd be a LOT less work.
...that's assuming the base/tracks can be separated.
squashman is offline   Reply With Quote
Old 07-13-2011, 02:02 PM   #27
antho!
Member#: 159057
2004 ts wagon
aspen white
hahha, bump from the dead...i just had someone pm me a question
Originally Posted by mattinct View Post
Nice work, how long did the job take to do?
probably a good 4 hours or so
that would be easy, but i think the rails are designed differently
antho! is offline   Reply With Quote
Old 07-26-2011, 11:41 AM   #28
BoostinChick
Member#: 218971
2007 WRX
I picked up 08' STi seats, hoping that the 07' WRX rails will be the same!
BoostinChick is offline   Reply With Quote
Old 07-27-2011, 03:39 AM   #29
Enlefo
Member#: 235627
07 STI
Oooh looks nice I wanna do this... I wonder if the side airbags can be made to function correctly.
Enlefo is offline   Reply With Quote
Old 11-06-2011, 07:25 PM   #30
BoostinChick
Member#: 218971
2007 WRX
I attempted this today on MY07' and looks like it cannot be done. The rails are designed completely different and even have different bends. I even tried to swap the rails, but the bolt holes did not line up.
I was able to complete the install and MY07' has the side air bags so this was a bit of a touchy/fun swap. No CEL! And my passenger detection system works fine. You are using the bottom/guts of your stock seat just swapping the materials over, so you shouldn't have to re-wire.
Old 03-04-2012, 07:29 PM   #31
antho!
Member#: 159057
2004 ts wagon
aspen white
i don't think the body changed from 02-07 because people interchange those seats all the time, so i don't know how you weren't able to install the 08 sti seats by following the instructions in the OP
Old 03-07-2012, 11:21 AM   #32
moss
Member#: 10197
Because the attempt was just to swap the sliders/tracks, not the entire slider/rails etc.
I'm about to do this soon
moss is offline   Reply With Quote
Old 03-07-2012, 11:41 AM   #33
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Can you elaborate on this more? Are the fittings the same? GD STi seats have to be the most uncomfortable seats past 30 mins of driving.
EtoS is offline   Reply With Quote
Old 03-15-2012, 01:09 PM   #34
antho!
Member#: 159057
2004 ts wagon
aspen white
are you asking about the air bags or the actual seats? for the actual seats, go to the first page of this DIY thread
Old 03-15-2012, 01:18 PM   #35
BoostinChick
Member#: 218971
2007 WRX
Exactly as moss said, I attempted to do it by only swapping the sliders/tracks only and confirmed it does not line up. You need to swap the entire seat base as per your instructions in the OP.
You are swapping out the entire base. The high back/upper half bolts directly onto the seat base.
Old 03-15-2012, 01:19 PM   #36
FastfreddyRs
Member#: 64808
2004 FXT & STI Wagon
all i did to install 08 sti seats in my 00 rs is swap rear seat mounts. the parts riveted and welded to the seat rail, i used a spot weld remover drill bit, a pry bar and a hammer and a dremmel with a cut off wheel. I bolted the 00 RS rear mounts in the car, then placed the 08 seat in the car, to see where it lined up. once i was happy with the fit i welded the rs mounts to the 08 sti seat rails. I've had this in my car since decemeber with no problems.
FastfreddyRs is offline   Reply With Quote
Old 06-18-2012, 04:29 PM   #37
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
+1
I'm also interested if the BRZ seats fit in the GD.
I sat in a BRZ last night and the seats are WAAAAY better than the GD WRX seats.
chimchimm5 is offline   Reply With Quote
Old 12-01-2012, 12:16 PM   #38
Scotty Dosent Know
Member#: 252642
2006 WRX Wagon
People on this forum always seem so scared of fabrication.......wouldnt it be easier to just cut the left and right rear seat rail tabs off the GR seats and fab up new ones that work and weld them on?
The guy said the fronts line up so seems like it would be a quick fix to make new tabs.
Scotty Dosent Know is offline   Reply With Quote
Old 01-13-2013, 06:07 AM   #39
Mischaru
Member#: 288760
Thanks for the help
Mischaru is offline   Reply With Quote
Old 01-22-2013, 04:32 AM   #40
RLucky82
Member#: 277631
2006 SGM WRX STi
o7 Forester Sports XT 5mt
untill you get into an accident and a cheap ass weld breaks sending you into the windshield. If you like pizza face then "fab" away.
RLucky82 is offline   Reply With Quote
Old 01-22-2013, 07:58 AM   #41
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Because stock/manufacturer stuff never fails or has a defect resulting in same thing. Its a risk regardless, if somebody is willing to fab something in general its because their willing to do the work, willing to go a little over board for extra protection, etc. You don't need to go around saying because its custom fab its sucks and your going to die.
talvai is offline   Reply With Quote
Old 04-03-2013, 06:46 PM   #42
Blubullt02
Member#: 221344
2002 impreza wrx
wrx rally blue
Unhappy
So I purchased some 2013 wrx seats to put in my bugeye, and when I took the trim price off the side like in the first pic but there aren't 2 12mm to remove the back Of the seat. So I'm guessing I cant use my bugeye rails notes gr seats.
Blubullt02 is offline   Reply With Quote
Old 04-03-2013, 11:15 PM   #43
dirty_sanchez
Member#: 111682
1981 Yugo hatchback
Can you describe the problem a little more clearly? And you please post some pics of the 2013 seat rails and bracket? Are there welds instead of bolts, or what?
dirty_sanchez is offline   Reply With Quote
Old 09-21-2013, 01:38 AM   #44
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
Bringing the thread back. I am in the process of the mod. The rail swap is easy enough but I'm wondering how people deal with the airbags and the heater plugs? I'm putting the seats into my 04 FXT.
RE3Rotor is offline   Reply With Quote
Old 11-22-2013, 10:25 PM   #45
unlimitedMIKE
Member#: 371442
2002 WRX (v7 STI)
bringing this thread back. anyone who has done this conversion notice a height difference in the seat bottom?
does the seat sit higher or lower in the car?
unlimitedMIKE is offline   Reply With Quote
Old 11-29-2013, 09:53 AM   #46
BoostinChick
Member#: 218971
2007 WRX
My GR front seats are not heated, so no plug for that. And I cut the plug from my original seat and soldered it onto the GR seat plug/harness for the airbag.
You are using your original seat base, so no height difference...or not one that I noticed.
Old 12-01-2013, 05:44 PM   #47
Caveman431
Member#: 374988
2005 Impreza WRX STI
The back seat looks cramped is that cause the seats are moved back or are the seats just that big
Caveman431 is offline   Reply With Quote
Old 12-31-2013, 04:36 PM   #48
Speedster329
Member#: 214652
2004 STI !
really looking to get this done to my STi and get rid of the blue interior. i just found a nice set of the front 13 seats but need ti do all that custom fab. it will be worth it in the end though !
Speedster329 is offline   Reply With Quote
Old 12-31-2013, 08:48 PM   #49
rubrduk
Member#: 126587
16 Silverado
honestly this looks like a very easy fab job...toss in a couple of gussets and and extra stitches and it'll be good to go
this seems like a reasonable option
rubrduk is offline   Reply With Quote
Old 01-20-2014, 02:57 PM   #50
geedar
Member#: 224617
03 WRX
6-sp. vf39
Has anyone looked at the gap/distance between the side of the seat back and the B-pillar on a GD and then compared to that of the GR? I am wondering if there is enough room for the airbag to deploy correctly. If not, having the GR airbags active in a GD chassis could be bad.
I used to have a GR and still have a GD. If memory serves me correctly the GR has WAY more open space between the seat and the B-pillar. Another concern is that you are getting rid of your 04-07 seats then you no longer have head protection for side impact.
Side note: Supposedly the 02-03 seats only have side body air bags (no head protection)
geedar is offline   Reply With Quote
FS clear jdm fogs, enduratech front strut tower bar, GR front seat rails antho! SCIC Private Classifieds 16 04-21-2010 07:40 PM
GC rear seats in a GD? erich Interior & Exterior Modification 6 06-11-2009 06:44 PM
It is possible? stilover Texas Impreza Club Forum -- TXIC 3 07-31-2004 10:30 PM
Is it possible to switch front seats left <-> right ? il96 Interior & Exterior Modification 5 01-22-2003 12:46 PM
just fyi, it IS possible to have traction problems, even with AWD and Azenis tires jmott Texas Impreza Club Forum -- TXIC 13 03-27-2002 08:14 PM
