Welcome to the North American Subaru Impreza Owners Club Monday November 23, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Normally Aspirated Powertrain
Old 04-06-2017, 02:14 PM   #1
SubieOS04
Member#: 432831
2004 Impreza Outback
Default Fa20D vs FA20F what's the difference
Just bought a brz motor with a spun rod bearing so I was wondering what can I do with it and what the difference between brz motor and 15+ wrx
SubieOS04 is offline   Reply With Quote
Old 04-06-2017, 04:14 PM   #2
2008STiguy
Member#: 368522
2008 STI
drivetrain and ecu. Unless the frs/brz trans can be mounted directly then really just ecu side of it. I haven't done much research but I wanted to do the same thing.
2008STiguy is offline   Reply With Quote
Old 04-06-2017, 05:03 PM   #3
JRowland
Member#: 454620
2017 WRX
Red
BRZ has higher compression and combines direct and port injection. I think there are more differences but the 2 I said are all I'm sure about.
JRowland is offline   Reply With Quote
Old 04-07-2017, 02:56 AM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
from what i heard the brz has bigger ports too
Old 04-08-2017, 10:34 AM   #5
Buddiiee
Member#: 401168
2009 WRX
Spark Silver
Wow that car could only be 5 years old max, and it already spun a bearing? Dam...
Buddiiee is offline   Reply With Quote
Old 04-10-2017, 11:47 PM   #6
Johnhalgat
Member#: 465855
2016 WRX STI
Hyper Blue
Brz likes the boost
Johnhalgat is offline   Reply With Quote
Old 04-10-2017, 11:48 PM   #7
Chuckable
Member#: 447566
The BRZ engine will not bolt up to the WRX bellhousing.
Also, check out Element Tuning for some great tech info on the motors.
Chuckable is offline   Reply With Quote
Old 04-11-2017, 02:37 AM   #8
WGMGR
Member#: 419029
IIRC quite a bit. heads and such are different, with the brz motor being the better one last i remember. but its been a couple years since I researched this so it could be different now.
WGMGR is offline   Reply With Quote
Old 04-13-2017, 10:03 AM   #9
SubieOS04
Member#: 432831
damn not as mix and match as the ej series
Old 06-21-2020, 08:21 AM   #10
Gundy21
Member#: 515777
Possible to swap the bellhousings?
Gundy21 is offline   Reply With Quote
Old 06-23-2020, 02:38 PM   #11
GoFrogs
Member#: 507317
2019 WRX
Pure Red
were you planning an All MOTOR build? What were you power plans; max rpm?
GoFrogs is offline   Reply With Quote
Old 06-23-2020, 09:06 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
They are different blocks. Not swappable.
You'd run into issues with the heads, upper pan girdle, and many other things.
Old 11-10-2020, 11:21 PM   #13
irax
Member#: 317994
The bell housing pattern is the same an FA20F and FA20D will bolt to the same transmissions. The only thing that can be swapped would be the heads with their matching timing covers. Everything else you have to get matching to the block. For a turbo BRZ owner like my self it doesn't make sense to do so without the willingness to machine the block to allow starter clearance. If the WRX owner wants a cheaper high compression motor its a lot more straight forward since the FA20D(BRZ engine) is the one used in all non turbo applications and has the starter mount on both sides. They still would need to swap heads and matching timing covers. Oil pan would have to match the block. So anything that the WRX pan has that the BRZ doesn't, you would need to modify.
DSport has a great article on building the block
https://dsportmag.com/the-tech/educa...s-of-the-fa20/
Also this a great article as well.
https://dsportmag.com/the-tech/tomei...a20-flat-four/
irax is offline   Reply With Quote
