#1 |
Member#: 3102
NESIC
Vehicle:2018 Mazda CX-5 Storm Trooper White |
![]() Is it possible (practical) to add a rear camera to the '12 Impreza Sport Limited? I have the Limited stereo (non Nav), could it be integrated into the stereo?
The notch cut out in the rear door for a camera is there, but it wasn't even an option surprisingly? Thoughts? |
#2 |
Member#: 314731
South East
Vehicle:2014 WRX SWP |
![]() i am not sure the option even exists for the stock NAV. Ask your dealer maybe the same HU is in a different model that does have the option.
#3 |
Member#: 309901
BAIC
Vehicle:2012 Impreza 2.0i 5D Black |
![]() The JDM accessories PDF does show a rear/backup camera. That's what the cut out is for. Not sure if the wiring is there, I wouldn't hold my breath (but yes, when I get around to replace the base factory HU, I'll look into it.)
#4 |
Member#: 316658
Vehicle:2012 Impreza limited 5dr silver |
![]() If you have the limited non-nav stereo, it seems that there are hooks for a backup camera built-in on the stereo.
Check this out. Put the key in acc position. Turn off the stereo. The holding down '6' and turning tune dial until a firmware version info screen comes up(it takes ~5 full turns). Press the tune dial in once and you get the 'firmware update' screen. So there is potential to update firmware for things like bluetooth, ipod interface, etc If you press the tune dial one more time, it actually brings up the CAMERA!!! Well, there is no camera attached, but if you connect it, presumably, it will show the rear view camera on the stereo screen. Currently when I get to that screen, it shows a blank screen, with backup markers. If I press some other number, it turn on/off the back up marker, or brings up different size markers. I would assume that there is a video input jack in the back of the HU. In the regular screen setup menu, there is even a setting for choosing NTSC or PAL video format. I hope someone would try and hook up a camera to the stereo to see this really works. Maybe there's even a way to have it automatically switch the display to the camera when you are in reverse. Myabe down load the firmware from a forester or outback? Last edited by bobdole888; 04-12-2012 at 05:58 PM. |
#5 | |
Member#: 3102
NESIC
![]() Quote:
I'm going to try a combination of the two, $30 camera, run wiring myself, spliced to a factory harness Thank you for instructions on how to access a firmware set up! |
#6 |
Member#: 309901
BAIC
#7 |
Member#: 316658
![]() I've seen after market cameras for cheap on ebay.
search for 'impreza camera' and you'll find some for $18. Personally I would look for something built better for quality, but there are cheap cameras out there. Brys, please let us know how it goes. I'm very much interested in this also. |
#8 |
Member#: 309901
BAIC
![]() sorry, I was under the impression the quoted $169 was for an '12 Impreza specific OEM camera, not the "fleaBay stuff." I be interested in finding out if there are any camera(s) that would be a perfect fit to the factory "cut out" on the '12 Impreza as well.
#9 |
Member#: 316658
![]() Genuine camera from Subaru is $169.
http://parts.subaru.com/subaruparts/...cat5=0&retval= This is camera only. No display. You use the stereo's display. |
#10 |
Member#: 310672
Vehicle:2012 Impreza Ltd 5Dr Dark Gray Metallic |
![]() Just to verify: this info is for the 4.3" non-nav HU (CM631UD or PF-3391A-A).
There are two unused connectors on the back of the unit, next to each other. The schematic shows: 8 pin connector (J901) pin 1: CV(+) pin 2: N.C. pin 3: CAM +5V pin 4: N.C. pin 5: CV(-) pin 6: CAM DET pin 7: GND pin 8: N.C. This connector appears to be for the backup camera. A reverse signal is also present on the main connector, so I'm assuming this selects the backup camera video if CAM DET is grounded. The camera composite video should be connected to CV(+) (signal) and CV(-) (ground). Although the schematic shows pin 3 as +5V, it's really +6V. 12 pin connector (P903) (I'm going by what's shown on the schematic signals, not the text description next to it, which doesn't match) pin 1: SCAM_COMP pin 2: N.C. pin 3: N.C. pin 4: N.C. pin 5: VTR_AUDIO_L+ pin 6: VTR_AUDIO_R+ pin 7: VTR_AUDIO_R- pin 8: VTR_AUDIO_L- pin 9: N.C. pin 10: VIDEO DET pin 11: VIDEO_GND pin 12: N.C. This connector appears to be for another video input. It also looks like grounding the VIDEO DET pin will enable this video. I think this is what the PAL/NTSC select in the hidden menu is for. The video should be connected to the SCAM_COMP input. No guarantees on any of this! I'm just reporting what the schematic shows; I haven't connected video to any of this pins. Maybe SVXdc has found a source for the backup camera connector by now? |
#11 |
Member#: 328357
![]() I'm new to this forum & Subaru's...we just bought my Lady a 2012 Legacy Limited which has the Harmon Kardon Premium Audio. She didn't want to spend the big $$$ for the Nav Unit but now wishes she had a back-up camera. Does anyone know if the Harmon Kardon HU has the connectors for a camera feed (not sure if audio units are the same across Subaru Models) and if so does SVXdc have a cable that will work with this vehicle? Also, the new Legacy does not seem to have the same set up as the earlier ones so it does not look like the camera listed as a direct drop in will work. It appears that it has the knock out just like the new Outbacks etc so any source for a factory like camera would also be appreciated. Thanks in advance!
#12 | |
Member#: 309901
BAIC
![]() Quote:
#13 |
Member#: 294791
Vehicle:2012 Impreza Sport |
![]() I opened up the hatch and the wires are not there, nor is the mounting bracket for the factory camera. One could probably be fabricated or purchased from a Forester. I switched to a Pioneer so I now have a spare camera if anybody is interested.
#14 | |
Member#: 320185
Vehicle:2012 Impreza 2.0i |
![]() Quote:
http://subaruonlineparts.com/pdf/H001SSC700.pdf It appears, Forester has a special bracket pre-installed for aiming the camera. Do we have the same bracket on Impreza, or what is the go? |
#15 |
Member#: 316677
![]() Can you hook up a camera to the OEM Nav Head Unit.
#16 |
Member#: 316658
![]() It looks like someone might have gotten this to work with a similar HU from forester.
http://forums.nasioc.com/forums/show....php?t=2323331 The person bought a harness from svxdc to hook up a cheap ebay camera to the HU. My biggest concern would be that the Forester does have the camera option, so the HU might have different firmware that enables the camera. The if the impreza has a different firmware than the forester, then it might not automatically display camera on reverse. |
#17 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
![]() The rear camera input on the Impreza model CM631UD HU is functional. It uses the same 8-pin socket (and same pin-out) as that 2011-2012 Forester HU, as well as the 2008-2011 OEM Kenwood Navi HUs.
The Impreza HU is already wired to the reverse gear signal. It just needs to see that a camera is present for the feature to start working. I make an adapter harness with an RCA jack for an aftermarket camera. (and yes, I did finally obtain a large quantity of the 8-pin plugs for that) I can also make an adapter with plain wires for anyone who wants to connect an OEM camera. The factory wiring is not present in North American Imprezas (and apparently not all Foresters, either). So you'll need to add a long segment from the HU to the camera. I'd love to make a harness for the "VTR" A/V input, but haven't identified that 12-pin socket yet. The 2012 Impreza/Forester Fujitsu Ten nav HU also has a rear camera input, on its 16-pin socket. See this post. Since the cars already have a factory harness there (Imprezas without the camera wires), the easiest way to connect a camera is to add a new female RCA jack whose wires have the appropriate pins to snap into the factory plug (which I can also provide). Just recently, an installer used my cable and confirmed that this camera input works. Anyone who wants to contact me, see my profile (click on my username) and read the visitor message. Last edited by SVXdc; 10-13-2012 at 03:49 PM. |
#18 |
Member#: 3102
NESIC
![]() Harness and camera ordered, now i wait. I'll do a how to write up once it all arrives.
#19 | |
Member#: 316658
![]() Quote:
I'm worried about routing the video signal to the HU being messy work. I see some wireless option on ebay for ~$30. That might make the install a little less overwhelming. Although, I'm not sure how well it would work with the HU. Especially I would want to have it turn on automatically on reverse. |
#20 |
Member#: 309509
Vehicle:2012 Impreza |
![]() Honestly? It won't. The wireless would let you skip running the video line from the rear to the front of the car, that's it. Since the camera needs power, you still need to get a wire from the camera through the tailgate to a source of power (probably the reverse light circuit unless you want to hunt down a constant +12 back there). And that is (in my opinion, anyway) the hard part. Getting from the back to the front is easy, it's snaking wires through that damn boot to the hatch that's annoying.
#21 | |
Member#: 316658
![]() Quote:
I don't know how hard it is to route a wire from the hatch to the HU. It seems that Brys found some passage to route the AV wire. Does this need some special tool to pull a wire through? |
#22 |
Member#: 309509
#23 |
Member#: 3102
NESIC
![]() I finished about an hour ago, having installed a billion subwoofers, amps and various other components over the years, it was a breeze!
It was only 1 AV cable that ran to the radio, everything else (2 cables) ran to the reverse light, i snaked it all through the factory rubber passages. It's certainly not OE, but it cost under $60 complete. I used a $35 camera from a US Ebay seller. The worst part was dremeling a hole in my brand new car! Thank you SXVdc for the help and the harness! ![]() ![]() ![]() |
#24 | |
Member#: 316658
![]() Quote:
Does it really automatically turn on when reversing? Did you have to do anything other than using SXVdc's harness to enable the camera? Could you share with us which camera you got from ebay? How is the video quality? Did you need any special tool to run the AV wire from the hatch to the HU? |
#25 | |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
![]() Quote:
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 06:34 PM |
Finally got the chance to retrofit my 2012 Impreza Sports Premium | JDMSTA | Electrical & Lighting | 287 | 08-05-2014 06:03 PM |
95 legacy rear crossmember into 95 impreza? | greg donovan | Subaru Conversions | 1 | 10-02-2010 02:07 AM |
2000 2.5 rs rear lsd into 97 impreza abs?s | oooo | Transmission (AT/MT) & Driveline | 7 | 07-01-2009 11:15 PM |
anyone retrofit hid's into their impreza? | scooter4483 | Mid West Subaru Owners Club Forum -- MWSOC | 15 | 09-29-2008 05:35 PM |
