Welcome to the North American Subaru Impreza Owners Club Thursday November 26, 2020
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 10-24-2020, 01:02 PM   #1
picturegeek
Member Sales Rating: (1)
Member#: 205748
1998 RS/STi
black
Default NJ 1998 Subaru RS EJ207 V9 - Caged-Flared-6 Spd-360WHP- $18,250
Year, Make, Model: 1998 Subaru RS modified
Mileage: Last reading (see disclosure) 98,643
Transmission: 6 Speed WRX
Pictures: https://img.nasioc.com/picturegeek
Description and Mods: See below
Any problems: See Disclosure
Contact Info: Email is located in the pictures
Additional Pics : https://www.flickr.com/photos/pictur...57716585073756
Watch below if you don't want to click through yourself
JDM Subaru Impreza WRX Sti EJ207 Version 9 - 360 WHP @ 23.3 PSi - Open Source Tuned 93 octane
-Blouch Dominator 2.5XTR Compressor Housing, 100cm Turbine, Sti Oil Line
-BSC Oil Cooler 25 Row 7 3/4 x 13 wide
-DCCDPro VSSPro Controller for Vehicle speed readout
-Apex'i AVCR (used for data only)
-Cobb EBCS Boost Control
-Walbro Dual Fuel Pump
-Tial Blow off recirc. valve
-Front mount Intercooler (brand?)
-Water temp + Oil Temp Gauge Accutech
-Killer B Ultimate Oil pickup
-BKR7EIX stock #2667 Spark Plug - 2.0l WRX one step colder
-BGrimmspeed Uppipe
-Invidia Downpipe
-Stromung 3" Cat-Back Exhaust
-Invidia Equal length Race Exhaust Manifold headers
-6 Speed WRX transmission (FA20T )
-Perrin Shift Gate (shifter feels almost like a sequential!)
-Boomba Racing 2015 + Subaru WRX Short Shift Transmission plate
-Comp Clutch LGT + WRX stage 2 Clutch w/flywheel
-Enkei rpf1 wheels with 275/40/17 toyo r888r wheels.* 90% treadware left.
-5x100->5x114 spacer 25mm Rear
-5x100->5x114 spacer 15mm Front
-Stoptech Gen 2* Stoptech BBK Front + Rear (rebuilt/refreshed 2020)
-Ohlins Coilovers -16 step rebound, 16 step compression* (serviced 2020)
-CUSCO rear differential
-Whiteline ALK
-Whiteline 24mm Front swaybar
-Whiteline 24-26 Rear swaybar
-Whiteline Adj. Lateral Links
-Whiteline Rear subframe bolts
-Whiteline Rear diff bushings
-Whiteline Bump Steer Correction Kit
-Whiteline Steering rack bushings
-Helix Rear endlinks
-Superpro Trailing Arm Bushings
-Cusco V1 Brace
-Cusco Front tower bar
-Cusco Rear Camber plates
-04 STi Front Aluminum Control Arms
-OMP Champ R - Driver Seat
-Sparco Evo L - Passenger Seat
-Schroth 2/3inch 6 point harness
Disclosures:
This car carries a reclaimed salvage title due to an accident involving the rear right quarter panel prior to my ownership (which began 2009).* Repaired Damage can be seen from inside trunk pics.* Carbon fiber hood has been repaired and repainted - Shows sanding dips marks prior to painting.
No speedo or ODO. The chassis ODO reading stopped at 98,643 in June 2018 (which was accurate for the chassis up to that point) when the 6 speed WRX transmission was installed.
- The 2nd fuel pump confuses the fuel gauge.
-Fuel reads 1/2 full until its below 1/2 a tank where it reads accurately after that point.
-Rear fender flares where installed based upon flat bottom of rear suspension. They appear higher than the fronts - there is no tire rubbing.
-Imported JDM motor appeared to have 10-15K miles on it when installed in June of 2018, and had OEM factory installed plugs and timing belts that appeared in nearly new condition. This was a barely used engine. Since the the Odometer reading stopped at 98,643 I estimate I have put on 1,000 miles or 20 hours including one day on the track day to test out the new motor!
-Some exhaust fumes are present during WOT, most likely due to muffler placement, not leaking from any gaskets.
This has been the most complete version of this car since I have owned it. An absolute head and lap turner. It's currently registered in New Jersey, but it has been a California car it's whole life until 2017, where it spent zero time outside in the winter. No rust other than exposed components under car.
picturegeek is offline   Reply With Quote
Old 10-25-2020, 05:18 PM   #2
picturegeek
Member#: 205748
1998 RS/STi
black
Daily B
Old 10-26-2020, 09:50 AM   #3
Liberty Subaru
Vendor Sales Rating: (0)
Member#: 384278
Beautiful car! Tastefully modded.
Liberty Subaru is offline   Reply With Quote
Old 10-26-2020, 12:12 PM   #4
picturegeek
Member#: 205748
1998 RS/STi
black
And you can still play your top gun cassette tape in it
Old 10-27-2020, 07:35 PM   #5
picturegeek
Member#: 205748
1998 RS/STi
black
Roll cage info and pics of cage added
Old 10-28-2020, 10:51 AM   #6
picturegeek
Member#: 205748
1998 RS/STi
black
Forgot to add - It has a sunroof!
Old 10-29-2020, 02:54 PM   #7
picturegeek
Member#: 205748
1998 RS/STi
black
Thanks bud
Old 10-30-2020, 12:13 AM   #8
kaneda3
Member Sales Rating: (5)
Member#: 8057
99 rs-t & 02 sti
95 s14.5
maybe edit the descprition a little?
what bolt pattern is that? 5x100 or 5x114
kaneda3 is offline   Reply With Quote
Old 11-01-2020, 01:41 PM   #9
picturegeek
Member#: 205748
1998 RS/STi
black
Wheel Spacer info added
Old 11-03-2020, 02:32 AM   #10
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Hey
Would you be interested in trading plus cash for some subaru parts. Im going to be rebuilding a 2.7 firelock block with cnc iag stage 5 heads and 14mm studs and some other stuff. I was planning another build but this peaked my interest
Twitch_PA is offline   Reply With Quote
Old 11-05-2020, 01:28 PM   #11
picturegeek
Member#: 205748
1998 RS/STi
black
I have a too many wheels problem and can't do trades. Believe me if I had the space....
Old 11-09-2020, 01:28 PM   #12
picturegeek
Member#: 205748
1998 RS/STi
black
Dyno Info Uploaded
Old 11-15-2020, 09:53 PM   #13
picturegeek
Member#: 205748
1998 RS/STi
black
Daily Bump
Old 11-18-2020, 10:51 AM   #14
picturegeek
Member#: 205748
1998 RS/STi
black
Good morning, Details on listing updated
Old 11-19-2020, 10:25 PM   #15
gm4classic207v9
Member#: 504582
1996 Impreza
Down to 2 colors only!
Sweet deal and good luck with the sale!
gm4classic207v9 is offline   Reply With Quote
Old Yesterday, 01:57 PM   #16
picturegeek
Member#: 205748
1998 RS/STi
black
Thank you!
